When you are in the bios setup on the first page what do you change,on the second page is security setting do theses need changing and on the third page what order should they be in,to make the back up disks to work. cheers.
Normally you don't need to change anything, if the hard disk setting is set to auto (detect), the system will whatever hard drive is installed. You need to change th boot order to the CD as the first boot device so you can install Windows from the CD. If you wish you can change the hard drive as the first boot device after you install Windows.
If the Back Up Disk you mean the 2 Recovery Disks that you have burned from the eRecovery in Acer.
You have to enable D2D Recovery on the BIOS Setup, it's usually on the second page of the BIOS Setup on a Acer Aspire Laptop.
Please Rate, Thanks
