Question about Ingersoll Rand Air Tools & Compressors
Ingersoll rand 7/41 cutting out
Starts runs for 20 min the cuts out
  • 1388 Answers
SOURCE: Honda 5.5 hp air comp. no spark wont run
Most honda engines have an oil sensor that prevents the engine from starting if the oil level is low or oil is dirty. Test coil by disconnecting oil sensor wire. With sensor disconnected coil should fire. If still no fire, check kill wire for short. If still no spark, coil may need to be replaced. enjoy
Posted on Nov 29, 2008
  • 76 Answers
SOURCE: Ingersol T30 won't shut off and blows pressure release valve
the wire juction box on your compressor has a pressure switch that may be wound in to tight take the cover off the box there should be a switch with a machine screw with nut and washer and spring back this nut off and see if that helps if you go to far you just crank it back in until the switch hit although it may be the other way around you may have to tighten to lower the pressure some of them are made that way if this does not solve your problem send me a picture of the switch and can solve it from there
Posted on Jun 26, 2009
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Posted on Sep 25, 2009
  • 3600 Answers
SOURCE: ingersol rand model SS3-E runs but does not build
the back pressure valve has failed it costs about 15.00 and can buy from any truck parts store That's Peterbilt trucks or any large truck stores it's one of two sizes 1/2 inch or 3/4 inch when you pull it off be sure you know which way the air flow is or it will not build up.
Posted on Nov 26, 2009
  • 243 Answers
SOURCE: my tow behind air compressor ingersoll rand 185
press load button or toggle switch
Posted on Feb 08, 2010
WHY DOES A SM75 INGERSOLL RAND COMPRESSOR CUT OUT ON LOW PRESSURE OIL
Low oil pressure. Are you adding a lot of oil. Have you check the oil level. Switch could also be bad.
Dec 08, 2014 | Ingersoll Rand Air Tools & Compressors
Whare can i get picture of ingersoll rand type 30 model 234 with serial no 645261
Hi Omran,
The capacity of your compressor is 7.46 if the motor drive is 2 hp. 9.79 if the motor drive is 3 hp.
Hope i can help you.
Sep 13, 2012 | Ingersoll Rand - Rand Type - 30...
My 15 HP Ingersoll Rand Air Compressor doesn't start at times due to some load. Heard that there is some air getting caught in the Piston Head post its cut off point and hence there is too much
These pumps have unloaders to help the motor from being overloaded at startup, one type is centrifugal that is built to work off the crank, the other can be a pressure release valve that is set up to release the pressure in the chamber after it shuts down after full pump up. This is typically head as air escaping right after the compressor stops running after a complete fill.
Here is more information on the pressure release unloader.
http://www.about-air-compressors.com/unloadervalve.html
Good Luck,
Brian
Sep 05, 2012 | Ingersoll Rand Air Tools & Compressors
I have an ingersoll rand 30t model 253 compressor 80 gal tank. what should the start and stop pressure settings be? what is the run time to fill tank and cycle off?
Hi
I'm not sure but I operate my'n at about a 145/150 top and about 110/120 min.
However others my have a differant perspective
Cheers
John
Jul 09, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
Hello. I have a Ingersoll Rand air compressor, model 2475. I was wondering if there was a way to adjust the pressure gauge to create a larger differential. It is currently running between 150 and 160...
You can adjust almost all pressure switches
Compressors,Well Pumps,etc
Take off the cover & there should be a screw
to do just what you want to do,lower the cut out
pressure
Good idea, as the compressor will last many years
longer, the less it runs
Jun 29, 2011 | Ingersoll Rand - Rand Type - 30...
Ingersoll Rand type 2475 - The piston has seized on the crank - how do we remove
if it is seized the connecting rod to the crank u will probly have to cut it with a torch or grinder. be carful not to start a fire with the oil. if u cut the rod u may be able to salvage the crank and have a mechine shop turn it down then replace the piston and rod. but it may be scrap if u seized the connecting rod to the piston the u may be able to cut the piston pin but thats a tight spot u will probly need to cut the connecting rod to remove the piston and crank but like i said be carful u dont start a fire with the oil. . you may be able to get them loosed up a little if warm it up a little then u can work it back and forth to get it out. hope this helps good luck
Nov 18, 2010 | Ingersoll Rand - Rand Type - 30...
I am changing from 460 V to 230 V on a Ingersol Rand Compressor motor # 32036006 and I cant get it to start it turns real slow is this supposed to have some sort of a motor starter capicitor set up ?
Recheck the way you have the motor leads hooked up, make sure they are correct. You did re connect the motor leads didnt you? You are not trying to run it on 230v single phase are you? Assuming it is a dual voltage motor, the leads will have to be re connected from hi voltage to lo voltage. Also when you cut the operating voltage in half the operating current(amps ) will double, all this info should be on the motor name plate. This motor does not use a capicitor to start it
Mar 15, 2010 | Ingersoll Rand - Rand Type - 30...
Air Tools & Compressors Logo
37 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
