Question about Systemax Venture PC Desktop
New Computer Wont Boot!
I have a brand new Systemax PC with a 500W Power Supply. I swapped out the 2G's of memory for 4 and booted the machine up. The LED power siwtch lights up on the mother board and I was able to turn the power on in front. The fan spins and the computer seems to be on (No O/S installed). When I lifted it up on its side the machine turned off but the LED light remained on. Everything is connected and I can turn the power supply on and off but the button on the front of the machine is not turning the computer on. When I click it, the fan makes a noise like its getting ready to spin and then stops. I am not sure what to do next. Please help.
  • 883 Answers
When you say "the fan makes a noise like its getting ready to spin", which fan...power supply's or cpu? if you answer power supply, then the POWER OK signal is not returning to power supply and it then quickly shuts down to prevent further damage. double check a firm connection to mother board. If you answer CPU, then it becomes far more complicated. Try re-seating the memory chips.
Posted on Jun 05, 2007
New power supply don't work
New Power Supply installed, computer won't boot up ...
www.tomshardware.com > Forum > Components
Tom's Hardware Guide
May 22, 2013 - 6 posts - ‎2 authors
I have recently received my new power supply, i was very excited for it and just finished installing it. ... those were already 100$ on both the powre supplies, i don't want to .... Do you have another computer around that works?
New power supply now computer won't turn on [Solved ...
Jan 22, 2014 - 3 posts - ‎2 authors
Bought a new 500W power supply to replace the one of the same wattage. I wanted to ... This should turn the PSU on and the fans should work.
pc not booting after installing new power supply (pictures ...
Jan 01, 2016 | Computers & Internet
Dell 4400 won't power up Flea light works
For non-BIOS issues:
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button (this discharges any residual power in the capacitors).
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots. Try one stick at a time to see if you can get the PC to boot. If this works, then the remaining ram sticks are damaged.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker (20-25 dollars at local PC shop), get the supply tested at a PC shop (usually a free service), put the powersupply in a different pc, or try a different powersupply in the problem computer.
If the Powersupply checks out ok, then you will have to do a process of elimination to find out what part or parts are the culprit of the No-Boot.
Start by pulling all the ram sticks if you have not already. This is the easiest components to check and usually a culprit.
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives, other PCI cards. Do this one at a time until you find the culprit. If a POST screen, meaning you can see Anything from the PC brand name to Motherboard brand name appearing on the screen. The PC may not boot to windows, but it Does post at this point, and with that the problem is resolved. If windows does not load, then you have a new problem. Best dealt with asking a new question.
Brian
Jun 28, 2009 | Dell Dimension 4400 Power Supply ** FREE...
Wont boot up
Did you plug in the 4-pin ATX power cable from the power supply, to the motherboard? It's the power for your Intel processor. Looks like this, http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Apr 15, 2009 | ASUS Computers & Internet
Machine will not boot up
This could be several problems in order of cheapest to most expensive:
Memory: Take out the RAM and re-seat it, apply even but firm pressure. Try to boot again. If this does not work...
Power Supply: Your power supply might be dead, try to pick up a brand-name one and boot once more...
Motherboard: This is the worst case scenario, your motherboard went poof buying a new computer might be better than buying a replacement motherboard.
Dec 21, 2008 | E-Machines T6532 PC Desktop
Can not upgade memory from 2G to 4G
have you checked the frequency of the new ram you are using if its not of the same type and of same frequency as of the another one your system wont boot
Sep 14, 2008 | Acer Aspire™ T180 PC Desktop
PC wont Boot/start
The first thing you should do is swap the power supply for a known good one,
If this is a new build that hasn't worked from the start follow the instructions here:
http://forum.pcmech.com/showthread.php?t=132409
Aug 27, 2008 | Computers & Internet
Memory Upgrade and Computer will not boot
You need to do a BIOS Upgrade. First get the name of your BIOS when the computer boots up. Then go to the we site and find your BIOS brand and get a version update or upgrade.
Be VERY careful and follow the directons to the letter.
Let me know if this helps.
Jack
Jun 13, 2008 | E-Machines eMachines Desktop PC
Computer does not boot (new Machine)
Swap the power supply since you got two systems?
Feb 23, 2008 | Pine Technology XFX NFORCE LT 680I SLI...
Systemax ascent won't stay powered on
I recommend that you replace the PSU, Power Supply Unit with a new one, this is a simple task. Remove the plug from Motherboard remove the four screws from the PSU at rear and get a replacement one say a 450 Watt job. Install and ya be good to go.
Jan 30, 2008 | Systemax Ascent RTS A14 (980796) PC...
Systemax Venture PC Desktop Logo
171 people viewed this question
Top Systemax Computers & Internet Experts
Steve Allison
Steve Allison
pankaj rautela
pankaj rautela
Abhinandan  Patil
Abhinandan Patil
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
