Question about Keurig Elite B40 Coffee Maker
Does not fill large cup gives same amount if push for small cup
  • 1,511 Answers
Reset controls. See manual for instructions.
Posted on Jan 31, 2014
  • 60 Answers
SOURCE: my coffee maker will only dispense a half of cup
Descale every 3 months if you dont then you may need to descale more than once to get it clean
Posted on Mar 23, 2010
  • 60 Answers
SOURCE: my Keurig B60 will only fill a small cup when set
You need to descale your brewer
heatman101
  • 43501 Answers
SOURCE: My Keurig B60 is inconsistant
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Apr 02, 2011
heatman101
  • 43501 Answers
SOURCE: when i try to brew a large cup it has started
heatman101
Posted on Aug 07, 2011
heatman101
  • 43501 Answers
SOURCE: When I press for a large cup, it doesn't seem
heatman101
Won't dispense all the coffee from the disc. Have to push button at least two times. Descaled Help
The discs tell the machine how much water to dispense through the disc. Some discs dispense a small amount for an Espresso, others give a larger drink. Normal cups will not fill, you need smaller coffee cups for most Tassimo drinks.
Check the packet to see how much it dispenses and check with a measurement jug to see if it is working properly, you may be surprised to find it is working fine.
Oct 03, 2014 | Bosch TASSIMO Coffee Makers & Espresso...
When I press for a large cup, it doesn't seem to fill in with as much coffee as before. I only seem to get a small amount each time.
heatman101
Jun 15, 2011 | Keurig Special Edition B60 Coffee Maker
My Keurig B60 is inconsistant in filling the cup. When I push the large cup to start brewing, it sometimes gives me 1/4 cup, 3/4 cup or a full cup.
heatman101
Mar 24, 2011 | Keurig B60 Coffee Maker
Tried to set it up for the first time and the small cup & large cup both flashed ... I pushed the small cup and nothing happened so I turned off machine and unplugged and started again ... still same...
Call Keurig's customer service office. Their customer service rep will attempt to troubleshoot the problem by phone or replace the unit if unsuccessful.
Mar 02, 2011 | Keurig Elite B40 Coffee Maker
When i select the large cup on my keurig, only a small amount of coffee is made. if i select the large cug again, it makes a large cup
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
';';';l
Feb 06, 2011 | Keurig B60 Coffee Maker
When we push the option Large Coffee instead of giving us a large cup it gives us a small cup and strong. We push the small coffee and also get a small cup. What can we do to fix it?
HI
It needs to be reprogramed. If some one holds a coffee button down to long it will reset itself back to small coffee.
Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button.
If that doesn't fix it, then you might need a new flow meter.
Jan 13, 2011 | Saeco Vienna Digital Coffee Maker,...
Machine stopped working and both buttons are flickering, if I push the left (small coffee) button then the machine starts to pump cold water. If I push the left (large coffee) button nothing happens. Not...
May be busted, but before you take it to the shop try these few things. 1. Unplug machine for 30 seconds 2. Then plug back in, (lights should still be blinking) Take silver handle that you lift when you put in coffee pods and gently push back handle as far as you can for 3 seconds. This should reset your machine,back to factory settings. To then reset coffee cup settings to your personal taste by: 3. You can adjust the fill of coffee by holding the large coffee cup down for as long as you want to fill it. Try holding the button down for 20secs., next cup of coffee should automatically fill for 20 seconds. Do the same for small coffee side. Hope this works,it has for me; just not sure because of the cold water pumping out issue. good luck
Nov 11, 2010 | Nespresso Essenza C100 Espresso...
When you press the button for a large cup of espresso (Nespresso Essenza) only small amount comes out
You can adjust the fill of coffee by holding the large coffee cup down for as long as you want to fill it. Try holding the button down for 20secs., next cup of coffee should automatically fill for 20 seconds. The small cup that you are currently getting was probably set at the factory. Good luck
Nov 19, 2009 | Nespresso Essenza C100 Espresso...
How do i make bigger cups of coffee . I push the "large button but the amount of water is for a very small cup of coffee. is there a way to change the water level?
Hi
Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button.
Nov 10, 2009 | Saeco Magic De Luxe Espresso Machine
Keurig Elite B40 Coffee Maker Logo
61 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
