Question about Yamaha RX-V863 Receiver
I need an HDMI pc board for a Yamaha rx-v863
I have an 863. HDMI ports quit working. Sent it out for repair, they said the HDMI PC board was bad and needed replaced at a cost of $500.00. Thought if I could find a board at a reasonable cost I would try replacing it. Just not sure where to find it?
  • 236 Answers
SOURCE: Yamaha RX-V 800
Go to yamaha service direct they should have the parts. impossible for this model to be phased out. this is a model about 6 years ago only. they still have the parts for that. Power output and driver transistors are industry standard, replaceable too byt other newer model. you just need to find a real good techie for yamaha... i mean yamaha expert
Posted on Mar 19, 2008
Ajkill
  • 2035 Answers
SOURCE: Strange Flicker with HDMI components
Reset the yamaha player to factory sttings and check if the issue still exists ,unplug all the cables and replug the cables if the issues still exists its the problem with the Yamaha receiver, please get it changed as its a new player................................
Posted on Jun 10, 2008
Benimur
  • 6966 Answers
SOURCE: Yamaha RX-V663 - HDMI doesn't work.
Hi and welcome to FixYa,
Initially, a workaround:
  • as you posted, audio out of the DVD goes to the receiver;
  • HDMI out of the DVD goes to the Schaub Lorenz LCD.
Even if it were a compatibility issue or HDMI processor issue on the receiver, the above should get you going.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 20, 2008
SOURCE: Verizon Fios connection issue with RX-V663 Receiver
I had the same problem with RXV3900, was told by verizon and yamaha it's a software issue with the box. Verizon is suppose to be working on a new update, but no time frame for now. I'm using component to receiver, and hdmi to tv with no issues.
Posted on Mar 24, 2009
dunnbiker
  • 8546 Answers
SOURCE: Unable to play DTS-HD & True-HD
What do you hear? Do all other modes work ok?
If Audio Select (Page 44 and 98) is set to HDMI you will hear silence if no HDMI signal is present. I think AUTO is the best choice here.
On Page 98 of the manual it says a bunch of things concerning automatic signal detection and input selection.
Initial configuration D) INIT. CONFIG
Use this feature to select the settings of the audio input jack select, active decoders and extended surround when you tum on this unit.
Audio select AUDIO SELECT
Use this feature to designate the default audio input jack select setting (see page 44) for the input sources connected to the DIGITAL INPUT jacks when you tum on the power of this unit.
HDMI set E)HDMI SET
Use this feature to select the component to play back HDMI audio signals.
Support audio S. Audio
Use this feature to select whether to play back HDMI audio signals on this unit or on another HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = RX-V663
FUNCTION
Plays back HDMI audio signals on this unit. The HDMI audio signals input at the HDMI input jacks of this unit are not output to the HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = OTHER
HDMI component connected to the HDMI OUT jack.
NOTES
This unit transmits audio and video signals input at the HDMI input jacks to the HDMI out jack only when this unit is turned on even if "S.AUDIO" is set to "OTHER".
I'd look in these areas for specific guidance.
Posted on Apr 27, 2009
HOW DO I CONNECT MY YAMAHA RX-797 TO MY PC-LAPTOP
does laptop have a 3.5 mm stereo output port for sound ?
HDMI is video
YAMAHA rx-797 is a stereo amplifier audio
so you have a RCA phono input port
you need a 3.5 mm stereo lead to rca phone plug
may look like
http://www.4cabling.com.au/stereo-socket-to-2x-rca-plug.html?utm_source=google_shopping&gclid=CO30uN-Muc0CFUEDvAodscUI3w
with red and white plugs ..
Jun 18, 2016 | Yamaha Audio Players & Recorders
Yamaha rx-v663 no video from hdmi out
Unfortunately the most common cause of this is the HDMI transmit IC on the digital board. Sometimes replacing this IC will work, but most of the time you will need to replace the digital board - this is expensive. If you don't have a warranty that is still valid, it may cost more than a new receiver.
Dec 23, 2012 | Yamaha Audio Players & Recorders
Just set up RX-A700 two things seem wrong. 1. HDMI 1 won't show video if HDMI is plugged in, once plug on HDMI is removed from receiver HDMI 1 works perfectly. 2. HDMI output needs to be held tight or else...
sounds to me like a bad HDMI cable. Just replace it.
If HDMI still wont show, move to another HDMI port. But based on having to hold HDMI cable with hand to steady the connection, it is either a bad HDMI cable, or a bad HDMI port on the receiver. Good luck
Jan 23, 2011 | Yamaha RXA700 Receiver
How to perform a master reset
Unhook all HDMI connections unplug the yamaha and your tv from the wall outlet then try again. Most cases a copy protection kicked in or the hdmi had a error on the port, Worse case is hdmi controller board failure in ether the TV or the yamaha.
thanks and do be considerate and leave postive feedback and ratings for those that have helped you today, Thanks
May 29, 2010 | Yamaha RX-V2600 Receiver
What kind of up-grades are for the yamaha
There are no "upgrades" however, if your having problems with HDMI switching or "not working" You can send it to Yamaha and they will replace the HDMI board at n/c. It's still version 1.2 and the current version is 1.3a soon to be 1.4. What is it that you need to have upgraded? Post a comment with what it is you would like your receiver to do and I can help you further. I work with Yamaha daily
Nov 25, 2009 | Yamaha RX-V2700 Receiver
I have the LG Dn798 hooked up through my Yamaha receiver
Does it work via component or in a different HDMI port? If it does it sounds like either a bad HDMI input on the tv or a bad HDMI output on the receiver.
I would also verify that the receiver is 100% compliant with the HDMI standard as not all devices are.
Jun 03, 2009 | LG DN798
Mar 15, 2009 | Yamaha RX-V663 Receiver
Problems connecting Yamaha & BluRay player on Portable Computer.
hi i had similar problem, you need to change the settings in the bluray player output to hdmi or auto in other to get sound after the settings turn everything off even from the socket and then turn it back on for that setting to take effect. try this
Jan 12, 2009 | Yamaha RX-V661 Receiver
Yamaha RX-V863 Receiver Logo
116 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
