Question about Car Audio & Video
KEEPS CUTTING OUT
The head deck wont play cd's for more than 3sec before it turns off and when you turn the volume up on the radio it turns off the head unit, it continuely does this... the fuse is fine, the wires are connected fine whats wrong with it
  • ian slight Jan 10, 2009
    what bout it cutting out the radio when turned up
  • 23 Answers
Put a cd cleaner in it and play it a few times should do the trick even if it won't play but for three sec.
Posted on Jan 10, 2009
The cd player will start playing for seconds and then volume stop but cd keeps playing
are you running the deck through an amplifier? if so, you may be using the antenna remote wire (blue) instead of the amp remote (blue/white stripe) to turn the amp on.
Aug 11, 2010 | Car Audio & Video
I have been through the menu. i can't find a place to turn it on. the manual says it is a option by pressing the SRC button. All that shows is tuner and cd. Any help would be appreciated.
if this is a kenwood deck then by pressing the SRC will turn on the deck. tuner which would be radio and cd being cd player if the deck didn't turn on then it wouldn't show you any of that it would stay blank. for me to fully answer your help request I need to know the exact make and model of your deck. if there is no sound when you turn the deck on then try play with the volume as it may be turned down to 0 or 1 if there is still no sound then they didn't hook up your speakers to the deck. on the older kenwood decks there is a upside down triangle that is the SRC button on the newer decks it might be a rectangle button that says SRC. I hope i have answered your question, if so please vote and leave high marks. Thank you very much.
Aug 03, 2010 | Car Audio & Video
Radio/tape deck keeps cutting out. clicking noises lo volume no volume. then turn it on days later and seems to work fine. radio or amplifier problem?
radio problem. very common of fords with factory radios. best to get a used one. or try your local best buy and see if they can give a factory fit. they are pretty big with air included in the housing. best of luck
Aug 06, 2009 | 1996 Mercury Mystique
CD wont play
if it is new you may have left the screw in the back of the radio you have to takje this screw out for the laser to function it should have a plastic box on it
Jan 01, 2009 | Alpine CDE-9852 CD Player
Alpine CDA 7843E head unit
if this unit has a motorized face the ribbon cable is bad and will need to be replaced
Nov 25, 2008 | Alpine CDE-9852 CD Player
CDA 9885 No idea why it suddenly stopped working
It sounds like you have a bad ground connection. You need to take the radio out and check all the connections. I bet you have a loose one somewhere. That is what the problem was with my bronco
Sep 08, 2008 | Alpine CDA-9885 CD Player
Kenwood cutting out
rewire the radio strait to your battery that will make share that you wont make a short
craig:)
Jan 15, 2008 | Kenwood KDC-MP228 CD Player
Stored settings and auto eject
Hi. SOunds like another case of power problems. Your deck has 2 power wires. One is yellow th eother is red. One is constant 12 volt battery power, the other is a switched 12 volt power, only has power with the ignition key on or on accesory. Get yourself a test light. I almost bet you do not have the constant 12 volt power to the deck, therefore your deck cannot hold its presets...
Sep 25, 2007 | Dual XDM6830 CD Player
Auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Mar 15, 2007 | Alpine CDA-7892 CD Player
Car Audio & Video Logo
43 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
