Question about Stiebel Eltron DHC Instant Tankless Electric Water Heater
Need to push the reset bottom in order to have hot water... This is for a Siebel DHC
At the beginning the unit worked just fine. This started recently. The unit have three years.
2 Suggested Answers
  • 6 Answers
SOURCE: No hot water in our tankless water heater
Take off front cover, on the top of the two cylinders in there (the heating system) there will be a small red button. That is the Safety Thermal Cut out, depress that red button. It is similar to a circuit breaker. If the red LED comes on when you turn on hot water at a sink then that was the problem. I have on that trips periodically. Its annoying but not enough to replace the part yet. Good luck.
Posted on Dec 06, 2011
Have 2 Bosch tankless water heaters model 2400 ng. Won't maintain temp.
This could be a heating element going out do a ohms check on the elements
Jan 29, 2014 | Bosch Water Heaters
I recently had my primary heat exchanger chemically cleaned. My thermostat changed ad it had been re pressurised. The radiators all are working fine, but my water is still going hot and cold. What could it...
Could be the HW sensor, When you ask for HW, a switch ion the boiler will operate, usually part of what is know as 3 way valve. Different types of switch, you will have to have a look, could be a microswitch, in a unit to the side, you will be able to see if operating. But more likelly to be the 3 way valve itself, The internals do not switch fully, internal leaks etc. So inconsistent HW. Very easy to replace yourself, Turn off cold water, and isolate all the CH side, drain down the boiler, replace unit, reopen all valves, check pressure, off you go. You can get service kits for the 3 way valve unit, But for price diference, just replace, ebay a good place to to get one from
Mar 04, 2013 | Water Heaters
Bosch GWH 715 ES flashing EA code. This unit was working fine for over a year so I am assuming gas pressure can't be the problem? The spark is flashing and the unit lights for about 2 seconds then...
http://www.digelair.net/pdfs/TECHLIT/BOSCH/MANUALS/Bosch-ProTankless_AM.pdf
http://www.bosch-climate.us/files/201009031238250.GWH715ES_English_12.2008.pdf
Above are the manuals required to diagnose and service your error code.
EA: No flame ionization detected with water flow.
Verify that all manual gas shut off valves are open. Check gas type. Reset error code and open a water tap to cycle the heater in an effort to purge air on new installations. Cycling hot water tap on and off multiple times may be necessary. If heater still faults with EA error code, have a licensed gas technician properly purge air out of the gas line leading to the water heater. Check three wire connections to ignition group on the lower front of the heat exchanger are secure. Check gas pressure. Check venting specifications are met. Improper venting may cause premature failure of the flame sensor rod. Check that the minimum power fan speed has been adjusted to the proper value. Observe inside the viewing window of the heat exchanger when a hot water tap is opened. Sparking should be followed by a steady blue flame. If flame is unstable or yellow with proper gas pressure.
Jul 07, 2011 | Bosch & Tankless LP Hot Water Heater
Error code C4 76. Water heater shuts off (only with shower use). Will reset and work 4-5 min. then off agin. works fine from sinks. Unit is app 3 years old and did work fine.
Before calling service technician, open following link for Rheem tankless resources, including error codes and general help for homeowner.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
C7 76 is communication fault with remote control.
Remote is connected to tankless with a wire.
Usually you remove wires from terminals on tankless, and see if tankless functionality returns.
If tankless works fine, then it will heat to default 120 degrees.
Clean terminals and put them back.
If problem returns, then problem is then narrowed to bad wire, bad remote control, or problem inside tankless.
Since new remote control costs about $99, it might be cheaper to have service technician review the problem and catch up with maintenance.
Error codes are considered starting points for troubleshoot since error can have different soultion than same error on another unit.
Read manual for advisories, error codes, and required maintenance.
For example tankless might require monthly water filter cleaning, and yearly de-liming, and yearly burner cleaning.
Your service technician can advise what is typical for your region, since altitude, incoming water temperature, quality of water, water pressure, venting, are factors for maintaining water heater.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 25, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
BOUGHT THE UNIT IN JULY 2009 WORKED FINE UP UNTIL THREE DAYS AGO WHEN I RUN THE HOT WATER IT RUNS FOR A FEW MINUTES THEN SHUTS OFF.
1) Rheem offers on-line chat, which you rarely see for typical tank-type water heater
http://www.rheem.com/products/tankless_water_heaters/customer_support/
http://www.rheem.com/hrc.aspx
2) Call local service technician, and put that person in your rolodex-wallet for future help.
Ask technician for tips and tricks for keeping unit working and needed maintenance.
They will gladly offer a yearly service.
3) Read manual several times to get accustom to yearly maintenance required for tankless water heaters. Tankless water heaters are maintenance heavy. All costs are energy.
4) Read manual several times and notice word troubleshoot appears many times.
Since tankless are complicated machines, many internal and external factors can affect operation, especially as unit ages.
5) Look at label on unit to identify exact product number. Identify same/similar product at Rheem, and become familiar with Rheem website
6) Read other question/answers at fixya about Rheem tankless to become familiar with the tankless era
http://www.fixya.com/tags/rtg_74pvn
7) Install DIY tank-type gas water heater and avoid the whole headache
http://waterheatertimer.org/How-to-install-gas-water-heater.html
8) Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 14, 2011 | Rheem EcoSense by 4.2 GPM Tankless Water...
I keep getting a C2 11 error code. Unit lights and immediatly goes out showing that error. At other times it operates fine. The problem seems to be occurring more frequently. It has been in service...
that error code means not enough gas.
however, there might be something going on with your venting. it could be sucking exhaust air back into the unit. this will cause the same error code.
if your problem is intermittent, then I would suspect the venting to be the issue.
Aug 22, 2010 | Rheem Paloma Tankless Water Heaters...
I have an Amtrol WH7L and the control panel is making a buzzing sound? Other wise it is working fine.
In a while the control unit will fail
On the Amtrol units the control is their weakness.Once it starts to buss it will last somewhere between a couple of weeks and a year, but it WILL eventually fail.
And while Amtrol advertise a "Limited lifetime warranty" the "Limited " part includes not putting any warranty on that control unit.
Jan 27, 2010 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
When the water stops flowing, there is a sharp-thud sound presumably in the unit.
If your thermal expansion tank is older than three years, it is probably time to replace it. There is a diaphragm inside the tank that goes bad over time. Before replacing this tank, if you have recently purchased a new washing machine, this may be the problem if it does not have hammer arrestors on it as well.
Nov 18, 2009 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
Bosch gwh-425ef nat gas on demand heater
sound like pcb board is failing - control board
Nov 09, 2008 | Bosch & Power Vent Water Heater
Stiebel Eltron DHC Instant Tankless Electric Water Heater Logo
107 people viewed this question
Top Stiebel Eltron Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Stiebel Eltron Water Heater Expert? Answer questions, earn points and help others
