When I push the flush valve no water comes out... Do I need to turn the lil knob on the right side to let more water thru. Not sure if that's what even that does. Thanks
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
I would try that screw that usually regulates the water flow.
Posted on Nov 26, 2012
  • 1003 Answers
SOURCE: Timer on maytag Atlantis
replace water inlet solenoid first if this doesnt work replace timer
Posted on Feb 02, 2008
jsrock516
  • 5911 Answers
SOURCE: water inlet valve Kenmore dishwasher
Okay handy Mike,
First of all, is this a new dishwasher? Or, is it a used one? The reason I ask is because there should be a warranty with a new appliance and you should not have to worry, or have to pay for, any repairs.
The problem you are experiencing could very well be a water inlet valve problem (good assessment), but may also be something more simple. The dishwasher has a float inside the tub that is supposed to shut the water off, when it reaches the appropriate fill level. Check the float to make sure it moves up and down and that you can hear the switch "clicking". Sometimes small items get stuck under the float and will keep in the up (or shut off position).
For some helpful part locator drawings refer to searspartsdirect.com and type in your model number. An illustration of the water inlet valve can be found under the "Frame" heading in the next page as item number 24 (part number 154195301). The float and float switch can be found under the "Tub" heading as items number 13 (part number 154144301) and 24 (part number 5300809863), respectively.
If you require further assistance, please let me know. I hope its something simple and you don't require parts. But, if you do, you know where you can get them. If you do not wish to order on line, use the part numbers provided and go to your nearest appliance parts retailer. I hope this helps you. Good Luck.
Jeff
Posted on Jul 09, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore W/D #110.88762793 keeps filling w/ timer in any position
If the washer does not shut off when filling, the pressure switch is usually the culprit. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
In many cases, the only problem is the air hose comes loose from the switch, or is cracked or punctured somewhere. If the air hose is intact, and the electrical connections are good (no broken, loose, or corroded wires), then I would recommend replacing the switch. The part is available at searspartsdirect.com. Just go to the website and type in the model number you have provided and go to the "Washer/Dryer Control Panel" heading for itme number 13 (part #3952465). I hope this helps you. Please let me know if you require additional assistance.
Posted on Nov 11, 2008
  • 864 Answers
SOURCE: won't stop filling with water
Does the water continue to run when the washer is unplugged from power?  If it does, then there is something stuck in the inlet valve that is keeping it open.  Could be the result of mineral deposits.  If the water stops when unplugged then the water limit switch is defective.  Unlikely since the water still flows when control knob is in off position.
Posted on May 29, 2009
woodchuck789
  • 4066 Answers
SOURCE: cold water constantly runs even when the knob is
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing. The cold side can fail independently of the hot side.
Posted on Oct 14, 2009
We have Toshiba whasing machiv AW8570S (we used for three years) now no water supply,what I do ?
The hot and cold water lines connect to a mixing valve that is (simply put) a solonoid operated valve. If you are sure that the water supply is turned on but do not hear an audible click coming from the valve as you rotate the selection knob thru its cycle then I would have a qualified technician check the operation of the mixing valve. It may not be getting the signal from the timer/selecter or possibly just needs replacing.
Mar 07, 2013 | Computers & Internet
No heat in my 98 expedition ,fan works,blend door works,but blows cool air
Make sure coolant (Water Is full)
The system is clog. Or Heater valve is not open when you slide the control knob to hot or cold.
-Check the heater valve by moving the control knob to hot and cold. The valve turns or not. If it turns then the system is clog. If not turn at all then the valve is not function. (the cable might be slip off/Hook or connect it back to the valve)
*If it turn then the system is clog.>>>Need to flush.
-Disconnect the heater hoses from engine (Both hoses) and flush it with garden water hose from both direction for couple minute.
Reconnect, fill or add more water to radiator to full then run.
You should be good to go.
Mai Lor
Feb 25, 2013 | Ford Expedition Cars & Trucks
I have. A 40 gal. 40,0000 btu natural gas , how do u lite the pilot light
Access is at the bottom of the water heater. There is a little cover you will have to take off. Look for the gas valve. (its where the gas will come in to the water heater) Follow the two lines that come off he bottom of the valve. They will lead you to the burner (big line) and the pilot(smaller line). The pilot is what you are looking for.
1. locate the pilot (it will be 8" or so in to the water heater)(right next to the burner)
2. Turn knob on top of gas valve to "pilot"
3. Push down the knob on top of the valve that you just turned to "pilot" or there may be a lever right next to the knob on some models
4.with a long fireplace match or bar b que lighter, while holding the knob down, reach your lighter to the pilot assembly. you may smell a little gas.
5. The pilot will light, do not let go of the knob for 30-45 seconds
6. After a few seconds let go of the knob and turn it to "on"
7. Check your thermostat make sure it is not on "vacation" and turn it up to see if the burner ignites.
You are ready for hot water if all works. Hope this helps you, have a good day.
Apr 18, 2011 | General Electric Water Heaters
I have a brita faucet filter. And the selector knob is getting harder to turn. If it gets any worse I will need to use a wrench. I wanted to try to lube up the movement if I can open up the casing. How...
I have a Brita faucet filter (model FF-100) that lately has become harder and harder to turn. I toyed with the idea of forcing the unit apart but, instead opted to lube the mechanism directly from the top, where the unit attaches to the faucet.
To this mean, you will have to 1) Detach the unit from the faucet. 2) Remove the filter. 3) Thoroughly wash the unit, inside and out, turning the knob to flush any debris that may be present. 4) Pour some drops of vegetable oil inside the mounting opening, coating the valve stem within. (Oil may pass thru the unfiltered water outlet, so choose an appropriate working space). 5) Turn the water handle (knob) to lube the valve repeatedly, until it loosens. 5.b) Optionally, you could let the oil sit for some time inside the base. 6) Rinse the unit and reinstall it on faucet (without the filter). 7) Turn knob to unfiltered position, and flush with warm/hot water. 8) Do likewise with knob set to filtered, but open faucet only slightly, to avoid over-spraying. 9) Remove base unit from faucet and repeat steps 3-9, as needed. 10) Reinstall unit with filter, as instructed by manual.
Water valves may seize due to mineral deposits. While you may be tempted to use detergents or solvents, be reminded that unless thoroughly rinsed, chemicals may corrode plastics, degrade your filter, or even wind up in your drinking water, so caveat.
Apr 04, 2011 | Microwave Ovens
Machine runs but doesn't allow water to come into machine
Don't know the history of your machine, sounds like possibly the hot water supply valve under your sink is turned off. To check this go under your kitchen sink and inspect water supply valves, (right side cold water) left side hot water valve feeds the machine. Vertical water line is for sink above, there should be a second water line coming off this valve that has its own on/off knob. Make sure this knob is turned on, (counterclockwise)if not sure turn it to the right (clockwise)till stops, then to the left till it stops. This allows hot water to enter dish machine. If valve is on and line is ok, there might be a kink in the line behind the dish machine or a restriction (clog) in the water line. May need to unplug machine and unsecure it to pull it out for inspection. Good luck,best regards.
Feb 10, 2011 | Maytag Dishwasher
When you turn the handle over to the hot side the water will stop coming out. What would cause this problem.
Your control cartridge needs to be replaced. If the water is turned on by pulling on the knob you need Moen service part #1225B. If the water is turned on simply by turning the knob counterclockwise you need serviic part #1222. Try to turn the water on briefly after either cartridge is out to flush any debris that might be still in the body of the valve. Get the cartridge beforehand. the come with a handy removal tool.
May 28, 2010 | Moen & One Handle Tub & Shower Faucet
Cold water constantly runs even when the knob is pushed in to turn washer off.
Oct 14, 2009 | Frigidaire FWS833A Top Load Washer
Got a travel camper for free they told me everything works has ac, fridge, stove, water heater ect. but never owning one before I dont know how it works. I now theres two propane tanks on the side dont...
have tanks tested and certified if need be install back on camper screw on hoses to tanks open valves spray soap and water on fittings make sure no bubles if bubbles repair leaks spray all fittings were propane fittings in system tighten to check for small leaks if no leaks proceed to lighting pilot lites on heater-hot water tank-stove(is in oven and possibly under burners)and fridge on back of fridge(everything should have instructions on it)turn knobs to pilot push in knob lite hold for a few minute till pilot stays lit then turn to on position-may haft to hold pilot for a while to get propane thru all pipes start with unit farthest from tank.(also if stove top doesnt have pilot you can get all air out by turn on burner till it lites-ac should work on 110vac may haft to remove top cover and clean fins with degreaser and hose-water system i will add a cup of bleach and ciculate thru system let sit then flush out entire water system(to prime waterpump hook up hose to side of camper turn on rack all valves turn off all valves pump should be primed)should have 12v deep cycle i use a semi truck battery same thing alot cheaper and heavy duty i buy at battery store for 30dollars instead of a hundred at walmart and last longer-keep top tarped as uv rays will dry out seams(if leaks i goto place that sells semi-trailer parts and buy vulcam one gallon $50.00 a gallon and paint on all seams on top-vents seams etc anywere it could possibly leak)always keep tarped and tarp will take uv rays and weather not roof tarps are cheap compared to leaks)make sure in fall you winterize keep battery inside house were warm drain all water out of system should be valve at low spot if not blow out system if you get all water out of entire system shouldnt need rv antifreeze stuff has terrible taste and hard to flush out!!!dont set camper on ground set on pallets or something instead of straight on ground!!!!goto library get book on rv's learn as much as you can and you will be prepared and wont ruin a good camping trip because of equipment failure!!!Best of Luck to You!!!!!amtnng@gmail.com
Jun 30, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Steamer/frother in-op
Hi
I think you steam knob is out of adjustment. This valve the the knob turns opens a needle, so when you close the knob it is just allowing the needle to seat. If you turn the knob harder you move the valve away from the needle, so when you try to steam everything has expanded and the valve does not touch the needle, and it won't open.
To fix.
The top comes off by removing the screw on the top back where the water tank locks in. Once the screw is removed the put both hands on the side of the machine near the top and with your 2 index fingers, push the top forward. This will push the top of the face plate forward and release the top.
Once the top is off hang it over the back for know.
You will need a #2 Allen wrench. Rotate the knob all the way counter clockwise. You will notice that there is a cam that rotates with the knob. On the back side of the cam you will find a hole. Inside that hole is a #2 Allen screw. Loosen the screw and then without moving the cam rotate the know all the way counter clockwise, then tighten the Allen screw. This is how you adjust the Solis SL machines steam valve.
To reassemble.
The top of the face plate locks into the bottom of the front part of the top, so when you put it back together slip bottom of the face plate into the machine, then put the top on the face plate so the front of both is flush whit each other. Then push down and back on the top and it will lock in. then put the screw back in and your done.
Aug 30, 2008 | Solis Crema SL-70 Espresso Machine
Washing Machines Logo
Top Washing Machines Experts
