Question about HP Computers & Internet
How do I restore my compaq SR2013WM to factory settings F10 does not work and I do not have recovery disk.
  • 564 Answers
If F10 doesn't work and you don't have a recovery disk then you will have to try and find a recovery disk from somewhere or re-install windows. If you don't have a windows disk and you can't get hold of one there is nothing you can do apart from taking it to be done somewhere.
Posted on Nov 26, 2012
  • Phyllis Harris Nov 26, 2012
    The reason why I want to put back to actors settings is because it is running really low it take forever for a website to come up. Do you have any solution
  • Gerald Manuel Nov 26, 2012
    the things you can do are to do a disk clean up and defragment your hard drive. if you can you can add more memory which should speed it up as well.
  • 68 Answers
SOURCE: restore factory settings
what i would do is go into dos. If you cant get into dos find a windows 98 setup disk 3.5" this will have the dos files that will allow the computer to reconize a generic cd rom. This should allow you to get your recovery disk working. Your software problem could of created a firmware problem also. Not reconizing the cd rom. This solution will provide the basics to get your cd rom loading the recovery disk for you. If you have questions or more problems feel free to contact me and i will take you through it step by step
Posted on Sep 19, 2007
drifterK
  • 4924 Answers
SOURCE: trying to restore to factory default using f10
try to remove the bios battery for a second..it will reset the bios to the factory settings ...it might just work ...
I believe that the problem its one that developed after you changes some settings or after you installed some device that use that key for a different action ...
Posted on May 28, 2009
Tnsiouxfalls
  • 617 Answers
SOURCE: I have an NEC powermate ML7 that I want to restore
http://search.hp.com/query.html?sh=1&charset=UTF-8&la=en&qt=how%20to%20use%20recovery%20portion
This is a walk thru on the use of the recovery portion of your drive.
Posted on Jan 04, 2010
Testimonial: "Very specific link provided. Thanks!!"
javaswing
  • 86 Answers
SOURCE: Where can I get a Restore disk for a HP Compaq
Compaq has restore disk.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07143&cc=us&lc=en&dlc=en&product=3300335#N989
Posted on Feb 26, 2010
  • 32 Answers
SOURCE: I forgot my e-recovery password, no recovery disks...
Don't you have created the password Recovery disk early?
If you do, you can sign into safe mode and recover the password.
If you don't have the password reset disk. you have to take use of the 3rd party utility,
Windows Password Recovery 6.0 is highly recommend. It is fast and easy to use.
Posted on May 25, 2010
I need to restore my acer to factory settings
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical support at 1 800 816 2237 and order for an Recovery Disk.
Thanks and regards,
Jitha
Nov 17, 2011 | Acer Aspire Computers & Internet
Where can I find a recovery disk set for compaq presario sr2013wm. compaq no longer offers the recovery disk.
Click HERE to find the download site. Enter the Operating System you have and you should be able to download what you need from there. If you are using a different pc, put it on a flash drive or cd and transfer from that to the Compaq.
Hope that helps
Joe
Aug 31, 2011 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Acer Aspire One D250-08K Need to restore to factory settings and i have no disc. Screen is black. On start up pressed ALT F10 then nothing happens
Thanks and regards,
Jitha
Aug 29, 2011 | Acer Aspire One PC Notebook
Compaq presario sr2013wm will start and show the compaq screen, Then goes to a blank screen with a flashing cursor in the upper left hand corner. Can use Escape to get into Boot Menu, F1 to get into...
try opening up your side of your pc boot it up and listen to the harddrive for noise with it ticking in a screen like you say it usually means your harddrive is failing or the boot is corrupt on it
Dec 12, 2010 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
How do I get my compaq presario back to the original factory settings without a recovery disk?? its a SR1120nx
there is a hiden partion on hd disk, you restore to the factory settings, when bios booting, look for "restore system" key.Press the key only bios booting and follow the instructions. If not available, well you can reinstall windows with OEM CD and Follow Instructions. Good luck
Dec 22, 2009 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Restoreing to factory settings
You will need to reinstall the OS (operating system) by using the disk that came with your system, it may be called a restore disk or operating system, and their may be more than one disk!
Oct 24, 2009 | Compaq Presario Notebook
Put wrong recovery disk into new computer.
have a look here
and more pertinent, the F11 option here. If you have the right disks, you should still be able to run them...you will just have to boot windows from the recovery disks...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 04, 2009 | Microsoft Compaq Presario C501nr Notebook
Restoring factory setting
you should have received some discs when you bought the PC...if not, try looking in your programs list for the application to create the Recovery discs.
Some, not all Compaq's have a F10 recovery (at boot press F10)
be sure to save your personal data to another source (USB stick, CD...etc)
Feb 02, 2009 | Compaq Presario R3000 Notebook
How to reset my compaq computer back to the factory setting
Reset your operating system software (Windows XP..)to Compaq factory setting : restarting your computer. Hold down F10 key, your computer will go into recovery software provided windows recovery was preloaded into your hard disk during installation.
Follow on screen instruction.
If it your Bios you want to restore to factory setting, restarting your computer hold F1 key, entering BIOS set up. Look and press the key assigned "Default Loading" save change and exit Bios set up.
Does that solve your curiosity
Jul 27, 2008 | Computers & Internet
Computers & Internet Logo
101 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
