Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Verbatim portable not working - SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
It want come up on my computer
Step 1:
Problems with Verbatim portable hard drives vary depending on your model of hard drive, your operating system and your computer hardware. Some problems can include insufficient USB power output, the file system format, and potential overheating due to enclosure materials.
File System b> Verbatim portable hard drives come formatted for use with Mac computers. If you're using it with a Windows or Linux computer, you will need to format it to a file system that your operating system will recognize; Windows computers typically work with NTFS, while modern Linux distributions use ext4. If you have computers with mutliple operating systems, FAT32 is usually considered easier for all operating systems to recognize. Verbatim does not recommend switching a portable drive between PC and Mac computers once you've formatted the drive one way or the other. Adequate Power While most computers supply adequate power with one USB port, older computers can have insufficient power output. If your computer doesn't seem to be powering the drive, use of a Y-shaped USB cable, designed to be plugged into two USB ports, can get more power to run the drive. Additionally, consider trying different USB ports on the same computer; some USB ports get more power than others. Drivers b> Make sure that you have any relevant drivers related to the hard drive that you have purchased. If your drive didn't come with a setup disc, you can check the Verbatim website for product drivers. Overheating b> Of Verbatim's seven portable hard drives, four are enclosed in plastic; of the other three, one is enclosed in aluminum, one in leather, and one in rubber. While all the drives are tested to run well with their enclosure, metal enclosures conduct heat away from the hard drive and help to prevent overheating. Plastic, on the other hand, is an insulator, so plastic enclosures may contribute to heat buildup. Check plastic-enclosed drives for overheating and avoid leaving them plugged in when not in use.
Apr 05, 2013 | Verbatim SmartDisk Firelite Portable USB...
How do I use your Verbatim? Please give me instructions
From Verbatim "Installing your portable hard drive is extremely simple - just use the included mini-USB cable to connect your hard drive to any free USB port on your computer. On Windows computers, a new icon will appear in My Computer representing your hard drive. On Mac OS systems, your hard drive will appear on the desktop as a new disk."
Jun 11, 2011 | Verbatim 320GB USB Portable Hard Drive
I bought a Verbatim Clon USB Portable HardDrive to back up files from my Mac Computer. When I click and drag, I get this pop up " items can't be move because verbatim can't be modified." It says the hard...
You have to partition your Verbatim Drive to work on a Mac. Go to Macintosh HD / Applications / Utilities / Disk Utility. When in Disk Utility select the 232.9 GB SAMSUNG HM250HI Media to the left.
Dec 19, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
My verbatim portable hard drive usb 2.0 250 gb does not work anymore. I need to install usb driver ı think what u recommend
Friend:
You need to describe this prpblem with more detail....
No signed of power, have power but no access to data, spindle spins, ettc?
Thanks
D
Dec 16, 2009 | Verbatim SmartDisk Firelite Portable USB...
Verbatim portable hard drive not recognized by XP - works in 2000
Restart XP and connect e/hd and it should pick it up. Some systems are plain lazy after a while, so manually install it.
Aug 27, 2009 | Verbatim SmartDisk Firelite Portable USB...
My Verbatim 320GB portable drive will not work with my iBook G4
Called Verbatim support and they said it is a power issue. They will send you a USB Y cable to get power from both USB ports. Hope it works.
Jun 29, 2009 | Verbatim 160GB USB FireLite: The "drive...
When I plug my portable hard drive into my computer it flashes
i speak only a little english. my problem is the next : i can´t see the portable hard drive in my pc ( windows xp ) . i would like to know the answer to this problem. thank you
Nov 18, 2008 | Verbatim SmartDisk Firelite Portable USB...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
59 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
