Question about GE Profile PSI23NCR Side by Side Refrigerator
Ice will not eject from door.
Two to four times a dayy, I hear this clicking on and off sound coming from the Freezer. I can see fan blades turning on and off as well. Everything seems to be working, except the ice will not eject from the front outside door of the freezer.
  • 163 Answers
Their is a control board on back of the ref. this board controls most of the components to ref.i have seen alot of the ge ref. with same problem.replacing control board should solve problem but the board is very pricey.is ice coming thru door worth a couple hundred dollars?
Posted on Mar 07, 2009
Can I simply defrost freezer to solve a grinding noise that stops when I open fridge doors and gets louder when I open freezer doors?
Not knowing the type of Refrigerator, frost-free or cyclic-defrost-
My opinion is, the noise may be generated from the Fan in the Freezer -compartment,
It is mostly situated in the freezer, behind a removable panel at the rear wall, The panel has a grill, or is slotted to allow the cold air to flow.
The fan may be worn out.
You may hear a grinding or squealing sound.
The fan-blade may be touching (striking) something,
The blade may have moved along its shaft and strikes the housing.
It may strike solid ice ,
the ice can form, if there is a fault with the Automatic-Defrost.
You need to confirm if the fan blade rotates freely.
Do you know how to do that?
K. AUS
Mar 11, 2015 | Refrigerators
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
Kitchenaid superba kscs25fkss01- Icemaker is makiing ice but I hear a rhythmic clicking sound now and again. I think the sound is coming fron the white icemaker unit inside the frezer. It is still making...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Aug 20, 2011 | KitchenAid Superba Architect KSCS25INSS...
Frigidaire FRT21INLH top frezer refrige its not cooling i hear clicking in the back,friend who use to work on them said sounds like start relay but dont knw if i trust him if that is it were is it located...
HI, sounds to me like ice build up in freezer and the clicking sound is fan blade hitting ice.If you can remove back panel inside freezer and if you see ice, you will need to clear ice which is also blocking vent that goes to frig to cool it.then i would recommend wrapping a heavy guage copper wire around heating element and putting other end down drain tube to prevent the ice build up.
Mar 05, 2011 | Frigidaire FRT21P5A Top Freezer...
Fride not working freezre works and the defrost times is aways on what do i do.
try advancing the timer with a staight blade screw driver turn it slowly till it clicks and see if it goes into defrost,if so you have a bad timer,open freezer door do you hear the fan blowing,if not you could have a bad evap fan motor,is there ice or snow on back freezer wall,if so you have a defrost problem,timer,t-stat heater or fan motor you need a meter to read them out to see what is bad next time send model number
Nov 07, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer is not staying cold. The freezer is on but its not staying cold enough to keep the food frozen. The Ice maker switch is turned on but ice is still melting. Turned the control to coldest but still...
Sounds like the evap. fan motor is not turning. What is the freezer temp. have you measured it ? What about the fresh food section, (fridge compartment).
Anyway, try this. Hold the door switch in the closed position with the freezer door ajar and see/listen for the fan coming on. If you can't be sure, the best way to do this is to first turn the thermostat all the way to the "off" postion, and with the freezer door ajar and holding the door sw. closed (pushed in). turn the thermostat back on. (you may need to turn off then back on first if your arms aren't long enough) You should hear the fan motor start.
NOTE; you may hear the compressor overload "click" off if trying to start it right after shutting down, this is normal (under short cycles or manual restarts). You may also hear the condensor fan motor run (under the fridge by compressor) this too is normal. try to indentify the freezer fan (evaporater fan motor) running or not.
good luck.
Sep 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Buzzing sound
If noise stops when you open the door, you may have a noisy fan (or could have ice build up, causing fan blade to hit ice and cause noise). I gather it is a frost-free model ie has a fan in the freezer compartment. If noise is caused by fan hitting ice build up, you may have a problem with the auto defrost system, as you should not get ice build up in a frost free.
Noise stops when you open door because fan turns off when door is opened.
Aug 09, 2009 | LG Refrigerators
Loud Buzzing Noise from Behind Freezer
Sounds like the freezer fan blade is hitting on a build up of ice or frost. You may have a defrost issue, or it may be a one time thing, like the door was open for a long time (object holding door partially open) or also check the ice dispenser duct door to make sure it is closing. Sometimes a chunk of ice hangs up in the ice shoot, allowing moist air to enter freezer, resulting in the extra frost / ice near the freezer fan. You might also check the door gaskets, especially the bottom side where sugary liquid spills might cause a gasket to tear. #2: Long run times: If cooling is good, don't worry. Older refrig's often ran less time, but used much more electricity than the newer refrig's, even though new one run longer. (Like having a 40 watt light bulb on for 20 hours a day uses less electricity than having a 100 watt bulb on for 10 hours a day)
Aug 27, 2008 | GE PFS22SBSSS Stainless Steel French Door...
LG Fridge making intermittent sound - like something hitting fan
GAIN ACCESS TO THE FAN IN THE FREEZER(EASIER SAID THAN DONE) AND INSPECT THE FAN BLADE AND FAN SHROUD. HAVE REFRIGERATOR TURNED OFF AND MANUALLY ADVANCE FAN BLADE. WATCH FOR SLIGHT CONTACT BETWEEN THE FAN BLADE AND OTHER OBJECTS NEAR IT-ELECTRICAL WIRING, FAN SHROUD, ICE CYCLE,ETC. ADJUST FAN BLADE OR OBJECT TO INCREASE CLEARANCE.
Mar 27, 2008 | Refrigerators
Coils are frosted but not frozen. And no ice is blocking the vents to the fridge, but there is ice builing up inside the freezer again. The freezer fan does not seem to be running thought he compressor...
Sounds like a bad freezer fan motor. Check and see if there is a button on the door frame. Depress the button and see if the fan will come on. Check for possible ice holding the fan blade from turning. If the fan blade is clear you have not power to the motor or the motor needs to be replaced.
Mar 12, 2007 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
GE Profile PSI23NCR Side by Side Refrigerator Logo
64 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
