Question about Ricoh Aficio MP-C6000
Error message SC54...can anyone tell me what this means? Came up after sending print job to it. Thank you.
When I go to print I get message load mpf 024-969
This error typically means that the Size of paper defined in the print job being sent from the application does not match the size of the paper the printer has set for the MPF. (in this printer, MPF = Manual Feed)
For example: If you send a Letter size job to the printer from, lets say MS-Word, but the printer currently has Legal size paper assigned in the MPF, this error will result.
Change the Windows printer to default settings
Apr 03, 2014 | Dell 3010cn Laser Printer
HP 4350 ERROR MESSAGE: 49.2F90
"the printing operation has been aborted.
The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
If the above action does not solve the issue, contact HP or authorized service provider."
Mar 15, 2008 | Office Equipment & Supplies
Laserjet cm1017
Will it make a copy?
Do you get an error message?
Mar 18, 2014 | HP Office Equipment & Supplies
'check paper size' error has come up and nothing can now be printed. If turned off and on the last print which had caused the error prints out then the error message appears again. How can i clear this
This is usually caused by data within the print job. Microsoft Office sends paper size and job data with each job. Clear all print jobs in the computer sending the job.(Start/Printers/double click the canon printer and delete all jobs in the print que. Clear the Canon by off/on. Open a program and print a standard letter size document to test. This can be corrected by going to the page/document setup choices under "File" or the Ball in MS Office. Usually this is set to A4 or Bypass by mistake within the application.
Thanks
Jan 06, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
Printer showing error message ...."printing
This means that your machine has received a print job that is teling it to print on paper that is loaded or supposed to be loaded in the bypass feed tray. You will either need to delete the print job using the operation panel or simple load some letter size paper in the bypass tray over on the right side of the machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 18, 2010 | Panasonic Workio DP-3030 Printer
We've a problem with our TEC printer B-SX55. Sending a job via parallel interface only results in an error message showing up: XS;I,0001,0012C5 Can anyone tell me what to do to get it up and running...
This type of error message usually means a command error has been found in a command received by the printer. 16 bytes of the command error, hence the XS;I,0001,0012C5 message. It starts from the command code, XS.
I am not sure of all the command codes but I would suggest starting by re-installing the printer driver.
Dec 17, 2010 | Toshiba B-SX5T Printer
Printer stopped
Try simply adding a printer. If you get an error when you select "add printer" then you may need to check your print spooler.
If there is no error when you select "add printer" then the driver is corrupt and you will need to uninstall and reinstall (make sure you are the admin).
Thanks,
Pat
May 20, 2010 | Brother MFC-8460N All-In-One Printer
Action :
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job,.
Mar 15, 2008 | HP LaserJet 4350 Printer
Miele GS2220 Sci error message F84
Call Miele they will send a copy of the instructions booklet, I did and I got one
Nov 18, 2007 | Miele Premier-Plus Built-in Dishwasher
Error message unable to print
Send it back. The printhead voltage is innnnn disorder. Netxt will be Error 41 (Every Error starting with 4 means probs with printhead and in 99,9% the head has to be changed and cant be fixed!)
Sep 20, 2007 | Brother MFC 420CN All-In-One InkJet...
Ricoh Aficio MP-C6000 Logo
Top Ricoh Computers & Internet Experts
Chris Braid
Level 1 Expert
Are you a Ricoh Computer and Internet Expert? Answer questions, earn points and help others
