Question about Vacuums
Vacuum agitator won't turn
Agitator on my LG Luv400T has quit working. We have checked the belt, cleaned the agitator and tried the reset button. No luck.
3 Suggested Answers
  • 5 Answers
SOURCE: agitator stopped rotating, has checked for clogs, cleaned agitator, and pushed reset button, but still not rotating. Any ideas?
try changing the belt
Posted on May 19, 2009
SOURCE: Kenmore Model 116 upright beltless vacuum, agitator will not turn
I had the same problem. The agitator stopped turning after I sucked up a foreign object (my wife's watch) and it got jammed in the intake. After removal of the watch the agitator did not spin when turning on the machine, and the reset button never deployed (it remained buried in its housing and would not depress with a paper clip). The agitator was not bound and I could manually move it in both directions with ease. Faced with prospect of paying $125 or more for a repair, a good sharp kick to the chassis from the top promptly fixed the problem. I have found that kicking malfunctioning electronics often works.
Posted on Dec 05, 2009
I caught a piece of plastic bag in the power mate. The overload/ reset button is now lit and the agitator won't turn. I have taken the head apart removed the agitator and put it back in place, and there...
Try turning the agitator by hand-double check all is free and you have not missed anything-check manual for reset button-some buttons you have to hold down to reset-the manual should tell you how to reset
Jan 06, 2014 | Kenmore 28015 Bagged Canister Vacuum
Agitator manual
If the belt must be stretched to be installed it will lose elasticity after a few months. It might be as simple as replacing the belt. If that doesn't fix it you will need to dig a little deeper to find out why the belt is not spinning. Some vacuums have a switch that shuts the brush roll off and on, the switch might need serviced. Some vacuums have a separate motor that turns the belt, if so is the motor working?
Oct 31, 2013 | LG LUV300B Bagless Upright Vacuum
Agitator 'freezes', thus burning through the belt by the belt turning rod.
it will be the bearings at end of brushbar seized up and need replaceing
Sep 08, 2012 | Fantom Vacums FM740 Twister 300SE Bagless...
U6485-900 Self- propelled
The idler pulley is supposed to be loose on the belt so the brush won't turn until you recline the handle back
Jan 17, 2018 | Hoover Vacuums
I inherited this vacuum from my mother but I don't have the manual. I have 2 belts for it, but I don't know where they go. I can turn it on and it seems to work, but the bag doesn't fill up...
Most vacuum uses one belt at a time. The belt connects the agitator (beater bar) to the roller which is driven by the motor of the vacuum in the base of the upright vacuum.
To check if the belt is present/intact on the vacuum, look at the sides of the base for two latches. Push the latches away from each other then lift up to remove the cover so that you can check or replace the belt. To replace the belt, lift the agitator out of the base (first lift the right side). Cut off the old belt with scissors if it is still intact before pulling on the agitator. You may need to pull the bumper forward to get the beater bar out of the base. To put on the new belt, slide it onto the roller of the motor then onto the pulley of the agitator. Replace the beater bar in the housing. Start with the left end cap and make sure to keep the arrow pointing down on both sides of the part. Make sure that the agitator turns and center the belt before reattaching the cover.
While you have cover off, check for anything wrapped around the agitator. Remove anything that prevents the beater bar from turning freely. Make sure the area around the agitator is clear of any clogs.
However, if the belt is missing, the volume of dirt picked up will be less but not zero. It is more likely that the unit is clogged. There are several filters that need regular cleaning or replacement. The motor filter is at the bottom of the vacuum bag cavity. It should be cleaned with warm soapy water then rinsed completely. Squeeze out the excess water and then let it air dry. Wait until it is dry before reassembling the vacuum.
An exhaust filter also needs regular cleaning. This is behind the dust cover near the bottom of the area covered by the cover. To remove the dust cover, pull forward and then lay it down. To clean, put the filter under cold running water. Then air dry completely before reassembling the vacuum cleaner.
Finally check if the hose is clogged. First remove the hose by grasping it near the base and twisting it as you pull it away from the vacuum. Pull the hose completely straight then plug in and turn on your vacuum. Stretch out the hose and then let it relax into its storage configuration. Turn off the vacuum and then unplug it. Check for and remove any clumps of dirt stuck in the hose before replacing the hose.
If you have cleaned the vacuum and it is still not picking up dirt, try a different pile height setting on the vacuum. Also check if the agitator should be replaced.
Manage My Life has the manual for the vacuum here: http://www.managemylife.com/mmh/owner_manuals/15123/KENMORE-Vacuum-Upright-L0807740?brand_name_search=33078 . This manual gives the pictures of the various parts that need to be cleaned or replaced regularly. Sears Parts Direct has some parts for the unit; see http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Vacuum-Parts/Model-72136078600/0582/0645000?sid=PDVertical .
I hope this helps.
Aug 03, 2011 | Kenmore 33078 Bagged Upright Vacuum
My Kenmore Progressive keeps burning up belts even after I have changed the bag, cleaned the filters and checked to make sure the agitator was clean and free turning
The solution is to change the agitator. They wobble and displace the belt. Change it and you will have a new agitator with new bearings. It will keep it in line. It has to be in line with the system. Any shaking of the belt & lets go to the Kenmore store. I had the same problem.
Jan 17, 2010 | Kenmore Vacuums
Hoover wind tunnel 2 bagless vacuum not working
Place handle in low position and turn cleaner over so bottom side is up.
Remove the 4 screws in bottom plate and lift off.
Look on the left side of the agitator brush. You should see the belt there. Remove agitator brush roll and used belt.
Discard belt.
With lettering on outside of belt, slide new belt over motor pulley.
Insert agitator though belt and place belt in belt guide on agitator.
Grasp agitator firmly and fit it onto position by first sliding end opposite the belt into the rectangular slot on side of cleaner.Pull other side of agitator into place
Turn agitator making sure belt is not pinched between agitator and agitator shield.
If this does not take care of your problem, then check your filters for dirt and your entire vacuum for blockages. Both filters do come out. If you can't get a new filter right away you can gently clean the paper filter and remove a lot of dirt. (I recommend outside)! The other filter is washable.
Make sure it is well dried before replacing.
Good luck.
Aug 06, 2009 | Hoover U6630-900 WindTunnel Bagless...
Jul 28, 2009 | Kenmore 31913 Progressive Direct Drive...
Vacuums Logo
29 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
