Question about Bright Starts Ingenuity Perfect Place High Chair, Bella Vista
I can't get the latch on the Bright Starts Ingenuity Perfect Place High Chair to work. Any help?
How do I fold up the playpen
It's a struggle!
Pull up on the handle in the centre of the floor till it is as high as it can go.
On each of the sides there is a plastic piece in the middle. If you feel around them you can find a little button sticking out (it's on the side facing out of the playpen). Push that little button and push down on the middle of the top bar and it should collapse. There are 4 sides to the playpen - and 4 little buttons.
Nov 28, 2012 | Kids II Bright Starts Ingenuity Sleepeasy...
My son's high chair tray is stained. How can I get it out?
Try using lemon juice to get the stain off his high chair tray. It may not take it away completely but should help. Don't be tempted to use bleach or other harsh chemical cleaners as this is not safe around young children.
Aug 29, 2012 | Chicco Baby Gear
I want to buy a high chair cover / pad for my grandaughter's new high chair but I want something a bit different. I don't mind paying more for it. Where should I look?
Have you tried the Etsy site? They have some really nice stuff - not the cheapest that's for sure, but definitely a bit different. This link shows a pink paisley design that I thought was gorgeous.
Unlock scooter seat
Try some lock cleaner\ lubricant, use liberally, press down gently on the seat locking latch. If that doesn't work try shocking the mechanism with my favorite tool, a rubber mallet. If the key turns that part of the mechanism works. Put the key in to the release position. Go to where the latch is, use a bright light, see if the latch is engaged, Usually this kind of lock uses a hook latch. The hook is literally apart of the key barrel so if the barrel moves the latch hast to be moving too. Check the chair itself that its not stuck. WARNING Lubricate with pure silicon spray only it wont stain your chair. Lub all rotating joints and see if you can move it.
Hope this helps
Jun 21, 2012 | Health & Beauty
Chair booster seat legs won't collapse for storage
This should help. I've included a section from the user guide for Cosco's On-the-Go Fold Up Booster (41767B)
The full User Guide can be found here: http://www.coscojuvenile.com/usa/eng/DJGFiles/ProductDocuments/87_9-25-2006_124247.pdf
Jun 01, 2012 | Baby Gear
How do i take apart my baby's booster chair to clean it
The removeable eating tray should be dishwasher safe, making it the easiest way to clean & sterilize the most important portion of the chair...the place where the food goes first and little hands love to mix it up :). As for the remaining sections of the chair, although the base and back do not appear to be designed to separate without possibly damaging and/or disabling the seat permanently, even to facilitate cleaning. Although the cover/seat padding is removable and easily cleaned with your choice of cleaning product, that also disinfects without damaging the material or leaving behind residue that might be harmful to your little one...leaving only the base and back of the seat left to sanitize. At this point, I find that sometimes the easiest, even old fashioned approach works best. For extreme cases, it might just be best to toss out the one you've got and purchase a new one that allows for more flexiilityas your child Don't be afraid to take the bare seat ou
Mar 22, 2012 | Safety 1st 3 Stage Reclining Booster Seat...
I just recieved a new Oster Golden A5 single speed from Amazon. The clippers worked fine with the no. 10 blade that was mounted on clipper. I removed the blade and now I can't get it back on or the 4f...
ok the blade latch only holds the blade into place.
the hinge assembly which the latch sits behind needs to be open, there is a silver piece with two ridges on, place a flat bladed screwdriver behind the hinge and this will lever open you can then slot the blade onto the hinge and close shut with the clipper running.
Jul 15, 2011 | Oster 78950-100
Bright Starts Ingenuity Perfect Place High Chair, Bella Vista Logo
41 people viewed this question
Top Bright Starts Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Bright Starts Baby Gear Expert? Answer questions, earn points and help others
