Question about Epson Stylus Office Equipment & Supplies
EPSON STYLUS SX105 WHITE LINES OCCUR ON PAGE BEING PRINTED
WHITE HORIZONTAL LINES APPEAR ON PRINTED PAGE
headstrong
  • 233 Answers
SOURCE: Epson Photo R265 Lines every 2.5 cm
clogged nozzle, run the clean head then test page in this order at least 5 times in a row, you should see an improvement on each test page, sometimes you need to keep doing this clean/print until the nozzle becomes unclogged, if you don't see a difference in the 5-10 clean/test page then you need a new head
hope this helps
Thanks for your rating
Posted on Jan 09, 2008
d2704
  • 101 Answers
SOURCE: Lost instructions for Epson Stylus SX105
Posted on Mar 06, 2009
gwbm
  • 353 Answers
SOURCE: Epson stylus C88 makes black horizontal lines on the print
This "banding" is caused by uneven ink flow through the print nozzles.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three
cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If you have already done lots of head cleans with no perfect results, are you sure you have good ink cartridges properly installed? The printer determines the amount of ink left in the cartridge by counting the number of ink "shots" when printing, head cleaning etc. This information is stored in the "chip" on the cartridge. Thus, it is not an actual measurement of the ink left, but an estimate calculated by subtracting the total shots from the original full ink quantity. This estimate can sometimes be grossly in error, usually due to a cartridge replacement not being carried out correctly. To eliminate this possibility, buy a new set of compatibles on E-Bay - they're very cheap. You can always re-use the old ones later if it turns out they DO have ink in them.
If none of the above works, then you may have blocked print head nozzles. You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid
comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any black ink on the nozzle check, then there is hope! Repeat the process until you get a full black nozzle check. If nothing, repeat the process once more.
If still nothing, post a new comment detailing what you have done and the results.
Posted on Apr 08, 2009
aicaxz
  • 511 Answers
SOURCE: Horizontal lines in photos
Do head cleaning. Print at best photo quality.
Posted on May 05, 2010
I have an Epson SX215, worked perfectly until today, any image with black on it is only printing in black bands. Have done numerous head cleans and changed the ink but still not working.
Posted on Feb 14, 2011
Horizontal lines on page
Your printer head - the ink cartridge in case of most HP deskjet printes, in most cases is defective and you need to replace it to have a clean print.
Anyway, read this tutorial, has some good tips:
HP Deskjet D2500 Printer Series Horizontal Streaks or Lines in the Printed...
For Epson printers, read this
Epson Stylus Color Ink Jet Printer
Epson Printer Horizontal lines
Same for Cannon priters
Horizontal lines when printing with Canon ip4500 Forum Thread
Aug 23, 2015 | Office Equipment & Supplies
Printing lines
White lines appeared? In vertical or horizontal?
Vertically white lines : clog on head. Check nozzle & head cleaning.
Horizontal lines : error in linear encoder.
Sep 30, 2013 | Epson Stylus Multifunction Inkjet Printer/...
White lines running through printed line
The white lines occur when the print-heads do *NOT* output coloured-ink when they should be.
Run the Epson printer-software to "clean-the-print-heads".
May 29, 2010 | Epson Stylus DX4450 All-In-One InkJet...
I need to re-install my epson stylus sx105 multifunction printer but after my pc was formatted but don't have the cd.
Hi my epson stylus sx105 is not printing, need help quick. can any one tell me where i can get the cd to re install.
Nov 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Horizontal lines (red) on first 1 - 2 pages of initial print-out
Do you refill ink tank? Print blank pages. Is there horizontal lines appear? It might be caused bay ink leakage. Check respiratory hole at ink tank and rubber seal at bottom of ink tank. Print blank pages until no horizontal lines and try to use new ink tank.
Aug 17, 2009 | Epson Stylus Photo 1270 InkJet Printer
check if those lines matches the positions of the rollers inside the printer - you can see some of them by opening the cover
Dec 24, 2007 | Epson Stylus Photo R340 InkJet Printer
176 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
