Question about IBM System Storage TS3200 Tape Library Model L3H - Tape library - 17.6 TB / 35.2 TB - slots: 44 - LT... (3573L3H) Tape Drive
What is the ts3200 service default password? - IBM System Storage TS3200 Tape Library Model L3H - Tape library - 17.6 TB / 35.2 TB - slots: 44 - LT... (3573L3H) Tape Drive
IBM ts3200 tape library default service password
You will need to contact IBM support and after providing proper I.D. verification , they should be able to give you a password which you will be able to use. Due to security issues with stored info, you will have to provide the proper ID info as the original purchaser. Best Wishes
Sep 01, 2014 | IBM System Storage TS3200 Tape Library...
How to shutdown ts3200
1.- wait for the busy led to stop flashing
2.- keep finger on power off button (5 seconds or more)
Apr 03, 2014 | IBM TS3200 LTO4 TAPE LIB W/ SCSI (3573L4H)...
IBM TS3200 Code 9F 08
The manual is online with IBM.
Chapter 8 explains the error codes and 9F (mean Error code) means Rotation range out of specification 08 9sub error code) means error during rotation initialisation, get range failed.
Then the manual says: "Isolating a library controller card versus accessor enclosure problem" on page 7-11
But I guess you better look it up yourself. If you don't have any parts, you have to contact IBM.
Look yourself? start in chapter 8, page 225 of the manual under this link.
http://publibfp.dhe.ibm.com/epubs/pdf/a320545c.pdf
Feb 16, 2014 | IBM System Storage TS3200 Tape Library...
Ts3200 dropped log out
Hi Edson
It sounds like the new drive may also be faulty.
Dont forget to make sure that all the scsi ID jumpers and switches are set exactly the same as the one you removed.
Aug 28, 2013 | IBM TS3200 LTO4 TAPE LIB W/ SCSI (3573L4H)...
HE: drive broken: needs repair
Then raise a call with IBM Hardware:
How do I create a PMR (aka Service Request) for support?
http://www-01.ibm.com/support/docview.wss?uid=swg21507639
Apr 17, 2012 | IBM System Storage TS3200 Tape Library...
IBM TS3200 is a single tape library or multiple?
ibm ts3200 is a single tape library with 2 versions, 2U and 4U, the 2U version support 2 drives HH and the 4U version support 2 FH and 4HH.
Jun 11, 2010 | IBM TS3200 LTO4 TAPE LIB W/ SCSI (3573L4H)...
IBM TS3200 has how many tapedrive exactly
Hy ,according to manual it can have up to two drives.
Jun 10, 2010 | IBM TS3200 LTO4 TAPE LIB W/ SCSI (3573L4H)...
I want to know about IBM TS3200 tape library. In that which library is mapping with which tape drive?
trial and learn...
place only one tape drive in a deck and tell it to do a backup till it doesnt give an error. then move to the next drive.
IBM System Storage TS3200 Tape Library Model L3H - Tape library - 17.6 TB / 35.2 TB - slots: 44 - LT... (3573L3H) Tape Drive Logo
343 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
