Question about LG LFX21960 Stainless Steel Bottom Freezer French Door Refrigerator
Lg lfx23961sb replace ice maker fan
I have a LG LFX23961SB French Door refrigerator with the Error Code ER IF, which I know is the Ice Maker Fan error code. From what I have read it is either the control board or the motor itself. I am having trouble locating the part number for the motor so that I can order one and attempt a repair myself. I also am having a hard time determining where the part is located in the fridge. When I look at parts websites I can not find a fan labeled "Ice Maker Fan". The closest things I can find that make the most sense to me (I have never worked on a fridge before but have other electronics) is the evaporator fan located behind the back panel of the freezer. Can anyone confirm that or have the correct information? I do not want to pay someone hundreds of dollars to come out and fix a fan and if it is the board I will just live with my ice cube trays. The worst $1,800 I have ever spent was on this fridge. Thanks
  • Andrew Viglietta Nov 26, 2012
    I should also mention I have done the defrost thing many times, it as usually the freezer fan that was the culprit. Sounded like a plan was trying to land in the house. We can't leave the windows open for prolonged periods if it is a humid day, the ice starts to build up after 4-5 hrs.
  • Andrew Viglietta Jul 15, 2013
    Just as an update: I finally got LG to cover the parts and the retailer I bought it from to cover the labor. This fridge was a mess. I had to have the main board, water valve, display board and icemaker fan replaced in order to resolve the issue. I am glad I did not try to do anything on my own. The reason I was given as the most likely culprit was that at some point the flap on the dispenser must have gotten stuck open, pulling warmer air into the icemaker and subsequently the fan. Causing it to ice up and burn out. Doesn;t explain the main board and water valve, just glad it is fixed.
4 Suggested Answers
  • 210 Answers
SOURCE: LG Refrigerator LRBC22544st
Take off the back panel and cut the insullation as in the photo and this will never happen again. What happens is the water gets trapped and then ice forms and builds up and causes the blockage.
Posted on Jun 11, 2008
SOURCE: lg refrigerator LFX25960SW
do not purchase lg refrigerators or products. they are junk!
Posted on Jul 12, 2009
  • 5370 Answers
SOURCE: i have a lg bottom
The LG refrigerator "Er IF" error code is the "Icemaker Fan Error" message. As the name suggests, this error code indicates a problem with the fan that controls the unit's ice production. If this problem occurs because of ice buildup, unplugging the unit for 3 to 4 hours and allowing it to thaw may fix the issue.--------------------
The error "IF or FF" Both this error code are related to fan in the freezer section.
The error code is the freezer fan motor error. It could be a problem with your freezer fan motor or an issue with the control board not sending proper power to the board. Make sure there is no ice restricting the fan motor from turning. If there is ice then check the icemaker fill tube and make sure its in place properly and not leaking down on the evap fan blade. If the fan is not running, then its fan motor problem.Get the motor voltage checked.If its short, the motor has to be replaced.This will solve the problem. To order this fan motor. Click the link below:--- http://www.repairclinic.com/PartDetail/Damper-Fan-Motor-Assembly/1268059 --------------- This should help.Thanks.Helpmech.
Posted on Apr 12, 2011
Where is the ice maker fan for LG French Door Refrigerator?
The ice maker fan is located in the freezer and is part of the Grille Assembly ( LG part Name) Which is the removable back panel in the freezer. If you have an error code on the display such as ER/IF the fan is not rotating due to failure or ice accumulation in the fan blade. If you have no error code and the ice maker is not producing ice 2 things to check are...1. On the bottom of the ice maker there is a Test Button. Press and hold the button and the ice maker should rotate, Dump ice cubes and refill with water. If the ice maker does not cycle replace the ice maker. 2. Check freezer temperature. Freezer Temperature must be below 15 degrees to make ice. Ideally freezer temp should be 0 Degrees. If you have warm temps in the freezer there may be a sealed system issue preventing proper cooling.
Hope this helps.
Mike
Jan 15, 2018 | LG Refrigerators
HOW TO REMOVE OR REPLACE ICE MAKER FAN
No, there is a different error code if the control board is bad or there is a wire connection issue. The IF error is a comon error and either the fan needs to be replaced or something like ice is blocking the fan from moving. Check to make sure ice or frost isn't blocking the fan, and if it's clear, you need to just replace the fan motor.
Jun 30, 2016 | LG LFXS30766S LFXS30766S 36" French Door...
I have an LG fridge display giving me ER F1 code. i can unplug the fridge and plug it back in and the display resets for about 2 minutes and the the code comes back?
The ER 1F code usually means that there is a problem with the ice compartment fan, the ice maker motor or one of the control boards (the one for the ice maker or the main control unit). You can try resetting the refrigerator by leaving it unplugged for a day. Next check for ice build up on the fan that is blocking it from turning. Usually, if the fan hasn't been turning, you will have to at minimum replace the motor. It will burn out trying to force the fan to turn.
Sears Parts Direct has a diagram of the LFX23961SW case parts here: http://www.searspartsdirect.com/lg-refrigerator-parts/model-LFX23961SW/3204/0161000/K0810254/00001.html . The fan motor is part 405G.
I hope this helps.
Apr 15, 2015 | LG LFX23961SW French Door Refrigerator,...
We get no water or ice from control panel. On panel it says Er iF. What does that mean and how can we fix it. We have tried resetting the power and it goes back for a second then returns to Er iF.
Er IF - Ice-maker Fan Error - This can be caused by frost accumulation on or around the ice maker fan. Unplug the unit for 3-4hoursto allow this to melt off. If error code persists, call customer care to check & replace ice maker fan motor.Thanks.
Jan 29, 2011 | LG LFX21960 Stainless Steel Bottom Freezer...
Error code is 1F - the fan has stopped working
My 2 year old LG LFX23961ST refrigerator started showing error code Er IF. In searching help here,
I found out it meant the problem was with the Ice maker Fan. When I checked the ports where the cold air blows into the Ice maker compartment, there was no cold air coming out (you have to hold the door switch in to turn on the fan). I removed the ice maker module (two screws) and unplugged it. When I closed the door, the fan started running, but was making a rattling noise. I suspected ice build up.
Emptying out the freezer compartment, I pulled the rear cover of the compartment off and found what I had suspected. Cleaned out the ice, put everything back together and Voila! Everything working again.
As I write this, I can hear ice dropping into the ice holding tray. Not sure yet why the whole ice blockage thing happened though. Will keep an eye on it. It's been several hours since the repair and no issues. All seems well. It's not rocket science. If you can use a screwdriver, you can fix it too.
Dec 20, 2010 | LG LFX23961ST Stainless Steel Bottom...
LG LFX23961ST with error code ER IF
could be bad fan. sometimes the sensors on the them go bad
Apr 22, 2010 | LG LFX23961ST Stainless Steel Bottom...
Error code er 55? I am not getting water into ice
There are several issues with this ref.
Ref. Lamp cover melting.
Department of energy rework.
Contact LG for service repairs are free.
Jan 04, 2010 | LG LFX25960ST Stainless Steel French Door...
Error message on LG Refrigerator
The message is ERROR ICE FAN. You can order a new one from LG for around $65 and if you know someone handy they can probably put it in by just eyeballing the old one. WARNING>>>>this must be someone with common sense and some degree of problem solving skills as it does not come with the fan blades and that must be switched. This is a common problem with this model and usually the ice fan goes out in about 12-20 months. Use your owners manual to figure out how to get the door off and access the fan. Also, Lg employees are confused and may try to tell you there is just one fan......they did tell me that!
The ER IF is part # 46811B1029E---The ER FF (freezer fan) is part # 4681JK1004E and only a skilled repairman can modify them to be interchanged.
Dec 07, 2008 | LG LFX25960 Bottom Freezer French Door...
LG Refrig LFX25960SB
The service manual with the codes is available at:
LG LFX25960 Service Manual
"ER IF" show a problem with the ice maker fan motor.
Nov 06, 2008 | LG LFX25960 Bottom Freezer French Door...
LG LFX21960 Stainless Steel Bottom Freezer French Door Refrigerator Logo
413 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
