Question about Kenmore 24032\24036 Top Load Washer
Kenmore lid switch model 24422300 diagram - Kenmore 24032\24036 Top Load Washer
huuum
  • 750 Answers
SOURCE: need a diagram for a lid switch
Hello jafarrell
What is the exact model # ?
This was the part number!!
You said, you need a diagram of the Kenmore top loading washer, model 20432 lid switch.
This is a Kenmore part # you supplied, so here is where you can get it from Kenmore.
Part # 20432 lid switch as you supplied in our communications!.
http://www.searspartsdirect.com/partsdirect/retrievePartActionHome!search.action?productGroup=N%2FA&partNumber=20432&pop=flush
Thank you for using Fixya.
Huuum
Please remember to leave a rating
Posted on Oct 08, 2008
  • 1122 Answers
SOURCE: defective lid switch
you can bypass the lid switch,remove thw 2 screws on the console one on each side,flip the console up,you will see a 3 wire jack in the middle on the washer,disconnect the jack,the wires going to the console clip the 2 outside wires leave the green and wire nut the others together,plup back in and your done,let me know how you do-mike
Posted on Oct 26, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore 80 series lid switch
The following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch DOES require replacement, a new one can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. Just use your model number as your search criteria. All three sites offer competitive pricing, so shop all three for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
Posted on May 11, 2009
  • 92 Answers
SOURCE: kenmore washer spins very slow or not at all
yes the problem is that the bushes are badly worn on the motor,they are easy to replace and cost about £10.00 to renew
Posted on Jun 07, 2009
jsrock516
  • 5911 Answers
SOURCE: How do I remove the top of a Kenmore 110-24422300
This advice is for just about all Kenmore and Whirlpool model TOP LOADING washing machines. This is an easy repair that anyone with a little know-how and determination can perform.
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
If you have questions,, please let me know. I hope this helps you.
Posted on Jun 28, 2009
I replaced the lid switch on a kenmore model # 24422300 . it was actually broken apart. i had to partially take the back of the washer off to attach the ground screw . now it works but does not spin. It...
check the coupling,unplug it,take off the end caps on the top console,remove the two phillips screws that are under the clips,flip the console back to the wall,unplug the lid switch and with a screw driver pop the two clips,stick it into the hole and push to the back wall and the clips will pop out,tilt the back of tub up and and forwards to remove frame,on bottom pop off the two pump clips and pull the pump off,remove the two screws that hold the motor clips on and pop off the two clips,slide the motor out,now you can see the coupling,if any of the arms are broke off or the rubber is damaged replace it,if that looks good sounds like you have a bad transmission,touch the bottom of tranny. if any oil is there the tranny. is blown
Jan 21, 2018 | Kenmore 24422 Top Load Washer
MODEL 110-24722300 KENMORE WASHER. LID SWITCH DOES NOT WORK AND HAS COME LOOSE. HOW DO I PUT IT BACK TOGETHER?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024722300/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet. See the Sears diagrams on the control panel and cabinet to see where / how the switch connects.
Nov 24, 2010 | Kenmore 22422 Top Load Washer
24032 \ 24036 Top Load Washer my kenmore model 110-24422300 will not start wash cycle. Will fill tub to set level and stop.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024422300/0582/0153200?searchedModel=24422300&blt=06
Nov 06, 2010 | Washing Machines
I need the installations instructions for a Kenmore washer Mod 11020882990 for the lid switch Stella
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11020882990/0582/0153200?pathTaken=
Oct 26, 2010 | Kenmore Washing Machines
My switch is out of adjustment or needs replacing on my mod #24422300----how do I get the lid off of the machine to get to the switch
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24422300&pathTaken=partSearch
It has diagrams of all major components and their relationships.
Next, see the following for how to release the console and remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=affe8ede600431516767e8e3f033eb7a
Basically, if you snap off the end caps, you should see a phillips head screw on each end of the console.
Remove the screw, pull the console to the front and up.
Jun 04, 2010 | Kenmore 24422 Top Load Washer
I have a Kenmore 70 Series that is not draining the water or spinning. It is a top load. Model # 22722. Do you know what is wrong and can it be fixed? Cost to fix?
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts. You can find the complete model number (110.########) by lifting the lid.
A complete Lid Switch (See the diagram of the cabinet on the Sears site) is about $36.92.
Although I CANNOT recommend it, if cost is a real problem, you could likely leave the jumpers in place.
May 06, 2010 | Kenmore Washing Machines
Kenmore model # 110. 24422300. Will not do anything. Full of water, won't drain, spin or re-start in any way.Worked fine last week. Tired it on Thursday still won't drain on Saturday.
Assuming that you cannot hear the motor the problem is likely the lid Switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
washer back in.
If it works, the Lid Switch is a relatively inexpensive part.
Mar 13, 2010 | Kenmore Washing Machines
Ho do you access lid switch
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
To get to the lid switch on a Kenmore Top Load, you have to remove the cabinet.
See GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Basically, you will remove two covers if your model has them, two screws, unolug the lid switch from the console and pull the cabinet forward.
Sep 05, 2009 | Kenmore Washing Machines
Need a diagram for a lid switch
Hello jafarrell
Huuum
Sep 18, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
55 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
