I have a dark shadow on the bottom right corner of my new laptop
I got this computer on black friday 2012, and since the first time i got it set up the bottom right corner is darker than the rest of the screen. its very dark in the corner to where you can barely see the time and then it slowly fades to the right brightness over the rest of the screen. half of the screen is dark :( i dont have time to send it back and i already went back to the store and they dont have them anymore. I really like this computer and id really prefer to just be able to fix it! Please help!
  • Computers & ... Master
  • 5,660 Answers
OK Mel, it's your dime.
The LCD screen is bad. It may be just the Backlight, but since you purchased this baby new; it will have LED backlighting. There is NO replacing the backlighting, there is ONLY replace the LCD screen.
Primer if I may;
An LCD screen does not produce light.
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
(Click on the monitor image)
An LCD screen needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
(Light Emitting Diode)
A CCFL is a Cold Cathode Fluorescent Lamp. (Bulb)
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch. (-> O <- approximate thickness)
Average length is almost as long, as the LCD screen is in height.
General example,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
(View the last 8 photos)
Newer laptops like yours use a series of LED's.
A screen Inverter is used to convert the power (Electricity), from the laptop, for the LCD screen, and Backlight.
LED backlighting does NOT use a screen Inverter.
When an LCD screen that uses LED backlighting, has problems with the backlighting, the entire LCD screen is replaced as a unit.
Is the problem with the LCD screen itself? Could be. The entire LCD screen is replaced. Either way, replace LCD screen.
Now,....the above is just GENERIC information.
I need the laptop manufacturer name, and model number. The model number may be on the Palm Rest Cover, to the right of the Touchpad.
It WILL be on the bottom of the laptop.
Post back in a Comment.
This way I can see if there is a link to give you for a free Service Manual, and perhaps some pictorial information also.
Then I will guide you step by step, and we'll get that LCD screen replaced.
It isn't hard at all, I assure you. YOU CAN do it.
Regards, joecoolvette
(Psst, they don't have them anymore because it was a special sale.
Whoever the laptop manufacturer is, though; is obligated to repair it. Kinda hard to get them to replace the entire laptop. DOES happen though.
Laptop was like that from the factory. Is not the consumer's problem, is the factory.
I don't care if it came from Best Buy, Tigerdirect, Newegg, or your uncle; the FACTORY is obligated to repair it. DOES NOT matter if it was a Black Friday sale, Christmas sale, or an Easter Egg hunt.
DO understand about the time frame thing, though. Plus DO commend you for your willingness to repair. It is people like you that built the world, not sat by and watched)
Posted on Nov 26, 2012
5 Suggested Answers
sk8er1707
  • 58 Answers
SOURCE: power saving problem
wait for your computer to die open it up log on go to the desktop right-click > Properties > Screensaver > Power... and set all to "Never" and your done
Posted on Jun 01, 2009
SOURCE: IBM thinkpad R51 pink screen
same thing on my wife's R51....I have replaced the backlight in other systems, however this was her work computer..took to a good reputable business class repair shop.....the backlight is in a complete unit that has to be replaced, and the piece cost $350...also, the shop said not to do this yourself, because you need to be in a "clean room" or the dust you get inside the screen will glow....the screens are sealed on the R51....so you will open it up to dust if you take it apart...best thing is to do a complete screen replacement...
Posted on Feb 23, 2008
Geekman
  • 32281 Answers
SOURCE: Screen is half dark and whistles when battery is unplugged
You could have a defective screen, either a faulty inverteror a CCFL lamp - follow this to determine the fault.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Apr 16, 2009
Geekman
  • 32281 Answers
SOURCE: dull laptop screen back light
You may have a faulty CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Posted on Dec 30, 2009
Black shade corner lcd tv screen
you'll more then likely have to replace the screen. laptopscreens.com is a good place to buy a replacement.
Jul 30, 2013 | Sony VAIO C Series Notebook VPCCB17FXW
Light black area that is gradually getting larger
If it looks like a water stain that is dark and it is on the screen, replace the lcd screen. it comes with all the things you need
Jul 14, 2013 | ASUS U52F-BBL9 Laptop
Dark shadow to the immediate right of my texts
Problaly you had a magnet near by that caused that Dark Shadow.
Feb 10, 2010 | HP Pavilion F50 17" Flat Panel LCD Monitor
Black corner on laptop screen and burnt smell
The problem you have is caused by a defective LCD inverter.
They really really fragile and the job of replacing them can be quite tedious.
There is not other reason for your screen corner to became dark.
Send it back and tell them that the replaced part is defective or it was not properly installed.
I hope this help you out.
Aug 10, 2009 | Dell Inspiron 8000 (6158u) Modem
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Canon efs17-85mm image stabilizer lens
This is called "vignetting". To me it sounds like your lens hood isn't mounted correctly. If you don't turn it on all the way, exactly this will happen, because the longer "leaves" on the hood shadows the edges of the frame.
So, try to turnt the hood all the way on. You might have to use a little bit of force, as the hoods can be hard to turn sometimes.
Hope this helps!
/Chris
Jul 09, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Flashing shadow area on olympus e500
While in playback mode, image is blinking, the word shadow appears in lower right hand corner, use the info button repeatedly until all disappears and image is pure.
Mar 25, 2008 | Olympus EVOLT E-500 Digital Camera
Shadow across photo
Shadows, especially circular shadows, are pretty common with the pop-up flash. What you are seeing is actually the shadow cast by the end of the lens. This happens especially on wider angle shots.
The solution is to find a way to get the lens out of the way of the flash. You can get an external flash, like a 430ex or 580ex, which elevates the flash far above the lens. That is an expensive option so first you might try making a diffuser for your pop up flash, which softens the source of light and helps eliminate some shadows:
http://www.diyphotography.net/diy-built-in-pop-up-flash-diffuser
http://www.flickr.com/photos/natuurplaat/10362363/
Dec 25, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Dark spot in bottom right corner of screen
Is this a DLP or a conventional 3 tube projection tv?
Sep 15, 2007 | Hitachi 50V710 50" Rear Projection...
Computers & Internet Logo
1,017 people viewed this question
David Payne
David Payne
