Question about Arris SURFboard Gateway SBG6580 DOCSIS 3.0 Wireless Cable Modem
How do you change the settings on a sbg 6580
Recently changed to this modem router the leg for the computer seems to work better and faster. But the leg that goes to the xbox 360 the kids do online gaming now seems to be worse and its like it lags downloads stuff slower. is there a better set of settings that could get put into the admin settings and what are they?
dante777
  • 623 Answers
SOURCE: Motorola Router SBG900i blocks download from particular server
The best page for portforwarding can be found here.
It mainly depends on the software and the ports used, so it might differ from application to application.
Portforwarding.com has excellent user guides.
Posted on Jan 07, 2009
  • 7 Answers
SOURCE: Moto Surfboard SBG900 and VPN Client = SLOW
Please see the specicification, also check with you company
IT Admin, to release it to the Max speed or to check the
net work cable, may be too long, also Test the cable with a Data Test meter and conform the data quality. Or change the port from main router.
Otherwise change the whole networking router.
Regards
Posted on Jan 06, 2008
djxtreme979
  • 151 Answers
SOURCE: Switched to cable(arris modem) can't set up network
cable dsl same thing. Did you switch providers and get new modem from them? If so. Just delete previous netowrk and install new one let pc discover new one. Also, with your router you got a disc. It should install correctly. Perhaps it is previous network that is hindering you.
Posted on Dec 30, 2008
SOURCE: Need to change the security of my SBG 900 wireless router
Plug your router in with an ethernet connection and type 192.168.100.1 into your browser address bar. This should load the modem login screen. Unless you have changed the username / password they are admin / motorola. From here you can click on wireless and configure the SSID and security setup.
Posted on Feb 08, 2009
  • 256 Answers
SOURCE: cannot connect router to arris modem
You will have to unplug your computer from the modem to plug in your router. Then you will have to plug the two computers into the other ports on the router. If this doesn't help. send more information on how you have it set up now, type of router and type of computers (desktop or Laptop, Wired or Wireless).
Posted on Jun 02, 2009
I have a motorola SBG 6580. I would light to stop my IP address from changing?
Then you need to approach your network provider and ask for a static IP.You can check for your static IP after getting it from IP Details.com
Sep 27, 2014 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Tip
How to set up router
Router set up is very easy. You will need to access the router set up interface to make changes on the router.
If you are not able to go online using the router then you will need to check the settings of the router.
First make sure that your computer is able to go online when connected directly to the modem without the router.
If your computer is able to go online through the modem only then your modem is working properly, we will need to check the settings of the router.ind network key.
Router set up for Cable Internet service provider :
This connection type uses the MAC address of the main computer to identify your connection. They generally register the MAC address of the main computer. So the MAC address is everything in this connection type. Now we set up router using the MAC address of the main computer. Main computer is the computer which was able to go online through the modem. Use only the main computer to set uo the router.
Connect the modem and the computer to the router . Check the IP address on the computer.
According to the Default gateway value open the set up interface of the router. Once you open the set up interface, you will need to clone the MAC address of the computer. Then change the wireless settings on the router and your router is ready to go.
Router set up for DSL Internet service provider.
What is DSL connection?
DSL (Digital Subscriber Line) is a high-speed Internet service that competes with cable Internet to provide online access to local customers. DSL operates over standard copper telephone lines like dial-up service, but is many times faster than dial-up. In addition to being faster than dial-up, DSL does not tie up the phone line. Coexisting with telephone service in this way allows users to surf the Net and use the phone at the same time.
There are two types of DSL connection
1 ) PPPOE : In this connection type you will get user name and password from the Internet service provider. Your computer will not be able to go online when connected to the modem only. You can open the router set up and change the Internet connection type to pppoe and type the user name and password for the ISP. After that change the wireless settings of the router and it will be ready to go.
2) DHCP : In this connection type your computer will be able to go online when you connect it directly to the modem.
you don't require the user anme and password for the ISP.
In this connection your computer will get a private IP address from the router. According to this the IP address of your router will change. Change the wireless settings of the router and it will be ready to go online.
Click Here for step bi step instructions
on Dec 03, 2009 | Computers & Internet
Red world globe lit up on the front of the router - I have tried to un plug and plug back in that doesnt work ...this all started after my power was off 9hrs after recent storm. my cable modem moto...
hold the reset button on the back of the router for 10 seconds and the router should reset back to factory settings and you have to set it up again. Here's the manual though. bottom of page 62. instruction if you forgot password. But it works the same.
http://static.highspeedbackbone.net/pdf/D-Link-DIR-615-Manual.pdf
Jun 27, 2011 | D-Link DIR-615 Wireless Router
Routers modem light keeps flashing and booting me off line but when i hard wire computer to modem as i am now it works fine. changed cables and reset computer and modem
Flashing lights on a router are routine - they indicate connectivity and traffic.
Seems to me the simple answer here is stay connected by wire. Wire runs much faster than wireless. Wireless is 10 <> while wire is usually either 100 or 1000. If you have to have wireless, do a hard reset on your router and also reload the drivers. Check with the manufacturer for any soft or firmware grades they may offer. If you find a firmware upgrade - make sure you understand the instructions before you start. If you fail in this department, you will have to replace your router. Had you given a little more information on this, I could have done better with links and such.
Mar 03, 2010 | Computers & Internet
No internet connection
If your computer is able to go online through the modem only then your modem is working properly, we will need to check the settings of the router.find network key.
Click Here for more info
Dec 18, 2009 | Belkin Computers & Internet
I cant configure my mbr624gu router with usb 598 mobile 3g internet
Click here for step by step instructions
Can't configure my router to my modem, i follwed the instruction already from the manual. it still didn't work. still can't connect to the internet
Nov 16, 2009 | Cnet CWR-854 Router
Cant lock my signal was trying to find a alternative way because i lost the disk??? i have a SBG 900 and any one can get on my internet signal
There's another option to configure the security or encryption using your SBG 900
Connect your computer to one of the LAN ports
Access the configuration of the modem (example 192.168.254.1)
The if you got the configuration page open find the wireless settings and configure the WPA or WEP security using your modem.
Mar 08, 2009 | Arris SURFboard SBG900 Wireless Router...
Feb 07, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Arris SURFboard Gateway SBG6580 DOCSIS 3.0 Wireless Cable Modem Logo
412 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
