Question about Akai PT4298HD Rear Projection Television
Hourglass shaped red
After 2 years I turned on my Akai PT4298HD and the projected blue coloring was shaped like an hour glass on its side. Red and green were fine. I tried to manually adjust convergence (assuming that might be the problem) but it had no affect on the shape of the blue pattern. Can someone tell me what this might be ?
  • 1 more comment
  • Richard Szanti Jun 05, 2007
    I should have titled that Hourglass shaped RED. Please excuse my mental slip.
    Sorry ... Hourglass shaped BLUE
  • Richard Szanti Jun 08, 2007
    A pic of my display -
    President:
  • 3,130 Answers
I need to see a picture of the TV set. send a photo to techman32k@yahoo.com
Posted on Jun 05, 2007
  • Larry  Dillon
    Larry Dillon Jun 08, 2007
    You have bad convergence IC's
Akai pt4298hd 42 inch projection tv has red and green haze.part number stk392-040 were replaced 2 years ago.that fixed the problems.the symptons are the same.are these chips easy to acces ?
Yes they are But CK 2 resistors 2.7ohms in front of ICs if they are Bad they can cause same Problem to order new ICs $9.50 each Call Mats Electronics
1-800-628-1118
Dec 20, 2009 | Akai PT4298HD Rear Projection Television
Curved red image on 46" Akai rear projection TV
Yes! an idea that the flyback transformer is shot!
Please rate our help to keep the free service online
Aug 29, 2009 | Akai PT4298HD Rear Projection Television
My Akai Rear Projection Televison has a good
I'd like you to turn the color all the way down and let me know if the over-all picture looks Black&White or as we call it gray. Did this just happen or has it been changing over time?
Feb 28, 2009 | Akai PT4298HD Rear Projection Television
Hourglass shape picture
This is no easy fix it yourself job you need to take it to a repair shop.Ill bet you have a bad cap 16v220uf .its located on deflection board.Also these sets have poor solder connections. ThankYou for using FixYa . Have a Nice Day.
Feb 17, 2008 | RCA P52921 52" Rear Projection Television
Seeing double image in three colors
Its a convergence problem for sure ,,,if you cant move the red or blue (green is stationary) then your problem lies on the convervence module.. requiring ....mostly new output ICs like STKs your going to need a tech, for convergence is a common problem with rear projectors and requires patience and a expert to get it back just right. good luck
Sep 01, 2007 | Akai PT4298HD Rear Projection Television
Akai
yep you need convergence amp replacment for your set..very common prob call experienced repair person for this job use original replacements....john
Jul 31, 2007 | Akai PT4298HD Rear Projection Television
Akai tv
have a good tv guy repace you convergence amp's john
Tv picture shaped like hour glass
The link you posted has been deleted, so I cannot see the picture you posted. If the sides bow in like an hourglass and the red, green and blue colors are still aligned then there is a horizontal width or pincussion problem, but if the sides bow in and the 3 colors have separated and are no longer anywhere near aligned then you have a convergence problem, both of which should be serviced by someone with experience in servicing projection TV's.
Jul 03, 2007 | Akai PT4298HD Rear Projection Television
AKAI PT4298HD
If you have a good picture except for a missing color all the various circuits are working OK. Most likely you have a bad solder joint or component in the red circuit. This would also be indicated by the fact that ocassionaly the red pops in. If you have the experience remove the boards and inspect for cracked or cold solder joints. Resolder anything that looks suspicious. If this does not fix it you will have to troubleshoot the red drive circuits from the CRT back to the video IC. Another possibility is that you have a bad/intermitant red crt. I doubt that you have the equipment to check this but you can test it by moving the green crt board to the red crt. If it now works the red crt is OK. If all this fails you will need to find a reputable repair shop to look at it. If the unit is more than 5 years old it may not be worth fixing. Good luck.
Jun 02, 2007 | Akai PT4298HD Rear Projection Television
Akai PT4298HD Rear Projection Television Logo
97 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
KISHORE DESHPANDE
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
