Question about Zenith Televison & Video
Screen has rainbow pattern and colors, is it worth repairing?
    Top Expert:
  • Zenith Master
  • 74,383 Answers
The picture tube base connection socket should be suspected. If the focus connection to this socket has damaged, this kind of fault can occur. Replace it. screen has rainbow pattern and colors, is it worth - 11_27_2012_8_04_54_am.jpg
Will look like this. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Posted on Nov 27, 2012
salt56
  • 373 Answers
SOURCE: Sony Trinitron Color Rainbow
Usually when a tv is dropped the phospher screen inside the picture tube will detatch making the rainbow color This cannot be fixed as it requires changing the picture tube. Only other thing is demagnatize it with a demagnitizing coil (used by tv techs) but not likely to fix it since it was dropped. You have a bad picture tube.
Posted on Dec 30, 2007
rey jr
  • 149 Answers
SOURCE: TV repair
hi there, yes it is worth fixing for a 32 inch tv. , check up the connection inside and some loose connection or some cold solder. do some cleaning and check up. ty
Posted on Jan 29, 2008
alxz
  • 89 Answers
SOURCE: I have a rainbow of color about the screen
sounds like a degaussing (magnetizing) problem.could be that the posistor inside the TV set got loose when the tv fell down. If you have experience soldering electronic components, you should be able to fix it by re-soldering. Otherwise, call a tv tech to do it.
Posted on Jul 15, 2009
SOURCE: Rainbow of colors on screen
I just had a rainbow of colors on my tv screen...i thought it was a problem with my TV...however the screen went the "sign off" screen (verticle lines-red/blue/green) Then all of a sudden the picture came back and all was back to normal again.
So I say it's nto your TV it is a station problem!
Posted on Aug 04, 2009
tvtek
  • 1284 Answers
SOURCE: bullseye rainbow of colors
In some cases this is due to the fact the internal degausser stayed on too long and magnetized the CRT causing the rainbow effect. The only way you will know if the set can be repaired without replacing the picture tube itself is to have a technician use an external degausser to see if they can remove the magnetism on the tube and return the set back to normal. If that works then the internal degassing circuit will have to be repaired otherwise it will happen again when you turn it on the next time. If it doesn't work then the tube was damaged by the internal degausser and at that point you will spend over 300 dollars just in parts to repair it.
Posted on Nov 11, 2009
Bullseye rainbow of colors
This is either a purity fault which is caused by magnetism affecting the screen. You would need to call a service engineer to remedy this as a special tool is required called a de-gauss coil. However there is also the posssibility that it could also be a fault with the shadowmask which is caused by the CRT itself, if this is the case then the CRT will need replaced & this would probably not be economical.
Nov 11, 2009 | Samsung TX-P3075WH 30" TV
Have a Vizio P42HDe purchased in 2005. Right half of screen is fine. Left half is series of small vertical bars (various colors). Sometimes they go away and all of screen is okay. Any ideas?
I bought mine in Jan 2005 and today it did the exact same thing....doesn't go away. Seems like a 5 yr. lifespan on these.
Will try a Panny for Christmas !!
mikebc580
Oct 12, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Aug 04, 2009 | Panasonic Televison & Video
I have a rainbow of color about the screen. The TV fell out of the stand and now the color pattern is messed up. It fell face down.
Jul 15, 2009 | Sony KV-27V42 27" TV
Sound but no picture
Almost certainly the convergence IC's are shorted. Big job; perhaps $300 to $400.
Apr 09, 2009 | Sony KP-53S35 53" Rear Projection...
Screen going black
It sounds like the set is loosing high voltage to the 3 crt's. This usually ends up being an expensive repair, if the parts are still available. A new, or at least newer, set might be money better spent.
Sep 28, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Dec 30, 2007 | Sony KV-32FS13 TV
TV repair
Dec 29, 2007 | Philips 32PW6006 32" TV
Televison & Video Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
