SOURCE: astar ltv 19bs lcd
If you still have the TV, the remote has to be re-set. Hold the Enter button down approximately 10-seconds. It should re-set itself.
SOURCE: astar 32" lcd tv
No code yet.. still looking but the web page I found..
http://www.astarelectronics.com/
SOURCE: Astar LTV-32ASB will not power on.
The power board is defectived, just e-mail me the power supply picture and I will help you go throuth the problem. [email protected] or call 323-767-6030
SOURCE: REMOTE CONTROL CODES FOR ASTAR TV
Have you tried a Code Search with your remotes. If that does not work try calling or emailing Astar they may be able to help.
Astar Electronics
Tech Support:: (626) 851-2528
[email protected]
SOURCE: astar lcd model ltv-3201 does not power on
read yesterdays posts, the capacitors in the power supply are bad(not all just the puffed up ones), I replaced 8 of them and all is fine now for 4 months
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface.
Note:
Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand a way from the TV (Remorve 5, 4mm or 5/32" Allen Bolts from back of TV.)
For Mordels
26HL67
32HL67
32HL67U
37HL67 = My TV
42HL67
Herb
