Question about Zebra Stripe S500 Thermal Label Printer
Font too small on zebra 500 fedex label - Zebra Stripe S500 Thermal Label Printer
4 Suggested Answers
  • 6 Answers
SOURCE: Zebra printers & MS Word
HI Les1810,
You should be printing faster with Zebra fonts.
Which driver are you using? Version?
I strongly recommend the Zebra Designer V1.3.08, available at Zebra.com
To isolate the problem, capture the output to a file.
Define a local port as C:\output.txt and set that as the port in driver properties.
Now print your document. The printer commands will be in C:\output.txt.
Send c:\output.txt directly to your printer.
For LPT1, use the DOS copy command to send the file. (Copy C:\output.txt LPT1)
For serial connections, use Hyperterm to send the file.
For network connections, use ftp.
No easy USB method is readily available.
Does this print faster than printing the original document from Word through the driver?
If yes, then update your driver.
If no, debug your communication to the printer (LPT1, serial, network, etc.)
Posted on Sep 25, 2008
  • 6 Answers
SOURCE: Zebra TLP 2844 Controlling the font size w/iSeries??
Hi Burgymon,
The font that is used under the barcode will use the last font properties described prior to the barcode in the output. You may want to suppress the human readable option and create a separate text field to display the text version of the barcode contents.
SOURCE: No option to use with Stamps.com
I am having the same problem and it is bugging me. I can print the test page through printer configuration but it will not allow me to select the thermal labels in stamps.com!
Posted on May 07, 2010
Testimonial: "This helps, I am calling stamp.com for solutions"
Zebra 105sl printer labels print too small
There are 3 different DPI Printheads for Zebra printers if you print a label set up for a 200 DPI Printhead on a printer with a 300 DPI Printhead installed it will be about 66% of the size.
Feb 13, 2014 | Zebra 105SL Thermal Label Printer
I have a zebra zp 500 plus and it wont work with ups
Ensure its drivers and everything are installed on the machine and you can see it under printers as online. From there Call 1800 Pick UPS and the service tech will assist in getting it up and running with the UPS site. It can be used for UPS from what I am seeing.
Sep 20, 2012 | Zebra Zp 500 Plus Thermal Label Printer
How to adjust horizontal start position of label
is it possible to track the label stock with some guides?? before the printhead sometimes zebras use guides. some zebras also allow you to set a margin in the software or control panel itself.
Jul 11, 2017 | Zebra GX420d Thermal Label Printer
How to change the font size in ZEBRA 220Xi4
You would change the font size in the label design software that you are using. Click on the text box and then adjust the font and font size.
Jul 08, 2011 | Zebra 220Xi4 Thermal Label Printer
Font height is big in printed barcode. how can I adjust the size of the font?
check if the setting FORMAT CONVERT is with some numbers, please change for NONE.
This seting change the resolution from Printhead 200dpi or 300dpi or 150 dpi or none, none mins, if you have 200dpi printhead, print 200dpi resolution(small fonts). if have 300 dpi, print with 300 dpi resolution, if have 300 dpi(very small fonts) printhead, can print 150dpi(big fonts) if change this setting.
if ok, check the driver or your software.
Dec 05, 2010 | Zebra Z4Mplus Label Printer
I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this issue?
I am trying to print a label on the zebra 105SL but the font ...
www.fixya.com/support/t5406223-am_trying_print_label_zebra_105sl
Jul 11, 2010 - I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this ...
db:: 4.67::Crystal Report Label Won't Send To Zebra k9
www.hivmr.com/db/k99xad9dfspspddfs1scm9fzxxkdz9dj
My routine can print the label to any other laser printer, but the Zebra. ... I am tryingto find a way to print actual time a smartform label gets printed out on a zebra ... In this i want to changeCross Tab expert Row Label Font,Cross Tab expert ..... And labelpaper too. ..... DB:2.73:Zebra 105sl And Crystal Report Label Issues 1d.
db:: 5.16::Help My printer is printing in 3x5 documents and I ...
www.hivmr.com/db/xkzpajp81937ap7zdf87sdmsxmcm179m
DB:4.06:Printing 3x5 Continuous Feed Labels On Hp Officejet 6100 d8 ... Are they toosmall? ... I want to help you but I am not sure I can be of much help until I know what kind ... If the paper size is 3.5x5 but you are trying to print a 3x5 photo (which seems to be ...... I have a label format issue on a Zebra 105SL label printer.
db:: 4.15::Custom label sizes md - Hivmr
Jul 11, 2010 | Office Equipment & Supplies
I need the driver for Zebra LP 2844 for MAC OS X.
OS X 10.5.2 and above have built-in ZPL and EPL drivers. Plug the printer in to USB, go to System Preferences > Print & Fax, click + , and choose the Zebra driver. For the LP2844 you choose the EPL2 driver.
Apr 09, 2009 | Zebra LP 2844 Thermal Printer
BAR CODE FONTS FOR LITTLE LABELS
Depends on what software you are using, but you can use any True Type Font for the human readable, and any propritry barcode font available as downlaods.
However these barcode fonts tend not to print very small, it is a matter of trial and error.
www.lancerlabels.co.uk
Feb 10, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Wont print
Check to make sure you have direct thermal labels. You can test this by scratching your fingernail across the label quickly. You should see a black line. This printer uses the same paper as a ups or fedex label. test a ups of fedex label with the fingernail test. Does it look the same? or call Andrew @ 908-725-1699
Jun 17, 2008 | Zebra LP 2844 Thermal Printer
Zebra Stripe S500 Thermal Label Printer Logo
74 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
