Question about Ricoh Aficio 2022 Black and White Copier
I have a SC564 code with Ricoh Aficip C6000...can anyone help??
    Problem Solver:
  • 16 Answers
Check power supply board or replace tirmistor and thermostatic sometime lamp could be week
Posted on Nov 02, 2013
2 Suggested Answers
  • 13 Answers
SOURCE: MY RICOH AFICIO MP C6000
That is a "second laser synchronization error". Try this: Hit the yellow button, press numbers 1, then 0, then 7, then hit the orange key. When it goes into SP mode, turn off the copier and unplug it. Wait 15 seconds then plug back in and turn on. If that does not fix it then you need to call a tech to service the machine.
Posted on Mar 05, 2011
Hello ,, I have Ricoh c 6000 and I have problems with functional with copier ,, can help anybody
the purpose of this site is to help you. So, post the image/error and we can help you, so everyone with that problem can see the solution
Nov 20, 2014 | Ricoh Aficio MP-C6000
Ricoh mpc 6000 hdd change
hello when i replace two new hard drive in the machine sais can,t not format the hard drive can somebody help me to fix the problem
Jun 04, 2014 | Ricoh Aficio MP-C6000
Ricoh aficio mp c4500 factory reset
Selam Ashraf, user manual should be available on ricoh.com. I use it too asI have a ricoh lazer printer. It is easy to use
Huseyin
Feb 03, 2014 | Ricoh Aficio MP-C6000
Ricoh aficio mp c6000 factory reset
1. Press the * key and the # XXXXX on the Ricoh copier at the same time and hold for 10 seconds.
2 After 10 seconds or so, the printer will restart itself and will be factory reset.
Dec 09, 2013 | Ricoh Aficio MP-C6000
Ricoh Aficio MP C6000 Printer Offline
check weather u have connected all cables properly
then check for your printer driver
after checking if everything is proper then right click on mycomputer select manage then serch for the installed driver then right click on pirticular driver go to properties then select driver tab then select rollback option if this dosent works then go to control pannel then go to printer n scanner option delet the installed printer and add it again
Jul 02, 2012 | Ricoh Aficio MP-C6000
Service code SC564? How to fix?
reset machine yellow cancel and 107 and hold on 5 seconds on red cancel
Apr 12, 2011 | Ricoh Aficio 1035 Copier
I had a functional problem sc 546 with my copier Ricoh 2022
Hi mkpack,
The error code SC546 that you're getting with your Ricoh Aficio 2022is related to unstable fusing temperature. There are two possible causes for this issue. These are, the thermistor is already defective and/or the crusted toner on the fuser roller. To reset this error code (SC564) you might to follow these steps:
1. First, press the yellow clear all button.
2. Then, select 107.
3. Hold the red stop button until the machine switches to SP Mode.
4. Afterwards, press the copy SP or system SP button.
5. You have yo shut your machine off and then turn it back on.
If after doing these steps and still you're encountering the issue you might need to remove the fuser and clean it. Also, you miht need to replace the thermistors. It's the black aluminum roll in the fuser unit.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Ricoh Aficio 2022 Black and White Copier
MY RICOH AFICIO MP C6000 IS SHOWING AN ERROR CODE SC326
Mar 05, 2011 | Ricoh Aficio 1035 Copier
I have sc564 trouble with my ricoh aficio 1018. I called ricoh suport, someone should have passed thusday, we are friday and nobody!! I call again and we talled me "peraps on moday,..." I've...
look my friend this problem belong to thermistors are corrupted change it and it will work correctly there are many ways to solve this problem temporally but it revealed again 1 hour 6 hour and raise again thus change it byy
Dec 03, 2010 | Ricoh Aficio 1035 Copier
Ricoh Aficio 2022 Black and White Copier Logo
143 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
