Question about Samsung R580 Notebook
SAMSUNG LAPTOP PLUGGED IN NOT CHARGING
Low battery 9%, Plug in charger & it does not charge, finally the power level dropped enough to turn off the laptop even with the charger plugged in.
  • 564 Answers
Try removing the battery and just use the mains power. If the laptop works you may need a new battery. If it doesn't your charger is faulty.
Posted on Nov 26, 2012
  • 3 more comments
  • Samsung Battery
    Samsung Battery Dec 09, 2017
    This was nice post , you provide a information its knowledgeable thanks to share , If you have any issue regarding your samsung laptop we solve us and provide a good serviceshttps://laptopbattery.ae/samsung.html
  • Samsung Battery
  • Samsung Battery
  • Samsung Battery
    This was nice post , you provide a information its knowledgeable thanks to share , If you have any issue regarding your samsung laptop we solve us and provide a good services.
    samsung BATTERY
  • Samsung Screen repair
    Samsung Screen repair Dec 13, 2017
    We are now helping you to provide the service for your Samsung Screen for service contact our site.https://laptopscreen.ae/samsung.html
mastericpr08
  • 571 Answers
SOURCE: samsung laptop ( R517 )
if the power supply is workink replace the battery
Posted on Dec 14, 2010
  • 2567 Answers
SOURCE: My Samsung p400 laptop won't power on. There are
1. Take the battery out of the laptop & try to turn on the laptop using power
adapter only. If the computer turns on, then the battery is defective & needs to be
replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the
power adapter using a voltmeter. Compare the voltmeter reading to the nominal value
written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re
-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try
swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced
Posted on Sep 18, 2010
  • 2567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
6. The motherboard could be defective & needs to be replaced.
Testimonial: "thanks for the answers. "
  • 362 Answers
SOURCE: battery not charging samsung nc10-
try holding the power button for 30 secs with the battery out and unit powered off it allows a static discharge and might help its what my wifes g60 requires from time to time good luck and hope this helps you out some
Posted on Mar 22, 2011
SOURCE: my samsung r480 won't power on, or charge
First remove the battery and connect the charger, if power is coming,Then connected battry
Posted on Apr 05, 2012
My 7 inch Samsung galaxy tablet will not come on.
have you tried turning off tablet with charger plugged in and letting it charge up. You should see a battery symbol come onto the screen with a pulsing level indicating the battery is being charged. hold in power till unit turns off then plug in charger cable into tablet and switch on charger at power point . Do not try and push power switch to power up tablet see if screen indicates charging is occurring. I have experienced this exact problem on a samsung tablet !
May 03, 2014 | Tablets & eReaders
The orange light blinks a couple of times then goes off and after that the green power light blinks once with the antenna light
Blinking orange lights means no power or low power. Not enough to power the laptop. If it is plugged in and still the same, then your charging port or charger is damaged.
Mar 03, 2014 | Acer Aspire 5050-3371 Notebook
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
I'm borrowing a Jet 3 Ultra from the local Am. Legion for my Mom to use. They know nothing about it except they were told it had a new battery. I plug it in and all the LED's light up with the...
The batteries need charging and when you plug in the charger and the power is on the lights wil flash indicating that the charger is plugged in. Now look at the rear of the chair near where the charger cord plugs into the chair and you should see a voltmeter. With the charger plugged in the voltmeter will indicate about 5-6 amps and after charging overnight the voltmeter should be reading 0 amps. If when you plug in the charger cord and the voltmeter indicates 0 amps then I would suspect that the charger is not working or that the fuse is blown in the charger circuit. The only way to see if the batteries charge would be to borrow or find an offboard charger that will plug into the charger port located under the front of the joystick and after charging for 10-12 hours see if the battery level lights show full charge Hope this helps
Jun 25, 2011 | Pride Used Mobility Jet 3 Power Wheel...
NC10 battery not charging. The charging light flashes as normal but battery wont charge, tried another battery with same result.
Allow 1hour to charge it, if did not charge check the input & output of the charger if its properly insert, if not again off your notebook & charge it, always check if it is charging,
Note: Charging test try on, off, & unuse it allow to full charge the battery before using..avoid low bat your battery when using.
Jun 03, 2011 | Samsung NC10-14GW Notebook
I replaced my toshiba battery the 4000mAh to a new one 7200mAh 9 cells but it is not charging on windows its only charge when i shutdown the computer but the win 7 shows me that the cable is plugged in but...
The charger that you had for the 4000mAh battery was strong enough to charge and power your laptop at the same time.
Now that you have increased the capacity of the battery you need a charger that is powerfull enough to charge the battery and power your laptop.
You need to purchase a stronger charger/power brick.
Take care!
damnor01
Apr 24, 2011 | Toshiba LiIon 7200mAH 9 Cell Battery
Lenovo Y530 T 3200 3GHZ 4G Laptop not charging battery when plugged into outlet;also does not work on battery alone even though it is charged to 85%
Try to perfrom power drain. You must first turn off the computer. Take out the battery and unplug the power adapter. Press and hold the power button for 30 secs. Put the batter back in, plug in the power adapter and power ip the computer then observe.
Let me know if same issue will happen.
May 11, 2010 | Lenovo IdeaPad Y530-3231U Laptop Computer...
I have a toshiba laptop, and in the last few weeks something weird started happening. When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries,...
Change your AC charger.
It's NOT charging "When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries, and the battery level drops by about 1% every few hours"
That's the reason why: "battery has completely died"
If you do not change it you'll continue to "still it gives me the same low battery indication and will not turn on. "
Jan 04, 2009 | Computers & Internet
Battery charging
All lead-acid batteries contain highly corrosive sulfuric acid, generate explosive gases and have warning labels which should be observed closely. For best results, charge the battery as soon as you know it is discharged. To charge your battery, follow these steps and important safety tips: Before Charging: 1) Read the charger manufacturer's instructions. 2) Put on protective eyewear, rubber gloves, work clothes and remove all jewelry. 3) Place the battery in a well ventilated area. 4) Don't charge a frozen battery. Allow the battery to warm to about 60?F before charging. 5) If applicable, remove the vent caps and check the battery's water level and, if low, add distilled water to cover the tops of the plates. Do not overfill. 6) To determine if the battery needs to be charged, test it with a hydrometer to determine its specific gravity and/or with a voltmeter to determine its state of charge. 7) If applicable, reinstall vent caps before charging. 8) While the charger is unplugged, connect the leads to the proper battery terminals. Note: For side-post and studded batteries, we recommend that you use adapters to insure adequate contact. For additional information regarding adapters, contact Interstate Batteries. 9) Set the charger to the proper settings for your battery, e.g. 6 volts vs. 12 volts, low-maintenance vs. sealed, standard automotive vs. deep cycle. 10) Plug in and turn on the charger. 11) Don't wiggle the connections to check contact while the charger is turned on or plugged in. 12) Choose the lowest amperage setting initially. Once the charger is on and the battery is charging, you may want to choose a higher amp setting to reduce charge time. During Charging: 1) Keep the vent caps on. 2) Don't allow smoking, open flames or sparks near the battery. 3) Don't allow the battery to become hot to the touch. After Charging: 1) Immediately after the battery is fully charged, turn off and unplug the charger. Continuing to charge a fully charged battery will severely damage the internal plates and shorten battery life. 2) Disconnect the leads from the battery.
Nov 20, 2008 | 2004 Harley Davidson FXDL - FXDLI Dyna Low...
Samsung R580 Notebook Logo
1,965 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
