Question about HP Compaq nc6320 Notebook
Hello, I have just formatted my hp compaq nc6320 which I now want to install Windows XP pro following system crashes due to being overloaded by viruses and spywares I had been trying to format via the bootable cd but the system could not agree, I removed the hdd (SATA) and formatted it via desktop (had some tools for that - D-Driver III USB 2.0 TO SATA IDE CABLE) Now I want to install and Windows Setup says "File \i386\l_int.nls could not be loaded. The error code is 7. Setup cannot continue. Press any key to continue Please assist
  • lemajunior Jan 10, 2009
    I actually don't think this is a problem because I got a new copy from a friend after trying my own cd over the same problem, it's bringing different errors every time i try to install. I have tried again and it now says File \i386\KDCOM.DLL could not be loaded, the error code is 8192. Setup cannot continue, press any key to exit. What can be the problem?
  • Jarish Castañeda
    Jarish Castañeda May 11, 2010
    What do you mean at the 1st attempt via bootable cd "system could not agree"? what message prompted?
  • 585 Answers
I believe the keyword here is SATA. Take a look at what Microsoft has to say about this.
http://support.microsoft.com/kb/313348
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Jan 12, 2009
  • 238 Answers
Hi, clean the disc with a smooth cloth, reboot from disc again. Make sure you have set your boot sequence to cd, floppy, hdd. If it still not work, there's an error while you were copying your friend's disc that some of the files from i386 folder of the operating system were not copied successfully that is why they're not found now. It acted like you have copied it successfully but it weren't. You should use PowerISO Tool for that. It will copy all the source files from the disc and will make your Operating System disc copy be completely bootable. You can download poweriso tool in the net or Nero also has a tool for that to make your cd bootable.
Posted on Jan 10, 2009
    Problem Solver:
  • 13 Answers
You need a new xp pro disc. the reason the file failed to load was probably because there is a scratch or smuge on the disc.
HP nc6230 freezes shen loading Windows XP Pro
Try booting from your Optical Drive. First insert your Windows XP Pro CD into the drive. Do not re-install the operqating system or you will lose all your files and programs! When prompted press 'R' to use the Recovery Console. You should be able to write a new boot sector to your hard drive.
If this doesn't solve the problem, you might need to re-install the operating system. If you can find a way to save all your files from your drive (perhaps by putting your drive in an external USB caddy and viewing its contents on a different computer).
If all else fails get a new hard drive and start again with your WIndows XP Pro CD. Use an external 2.5" USB caddy afterwards to get your documents and files back off your old disk. You will need to re-install your programs, though. If your disk is Service Pack 3 you should be able to get straight back on the internet via a wireless connection to update all your drivers from hp's website.
Oct 27, 2011 | HP Compaq nc6320 Notebook
Boot flash drive
Download the HP Format Tool and install it. Get your boot disk or the downloadable files and copy/extract them to a folder on your HD. Make sure anything on your USB Drive is backed up because we are going to format it...
Open the HP Format Tool
Start/Programs/Hewlett-Packard Company/HP USB Disk Storage Format Tool
It should automatically select your USB Drive.
Select FAT or FAT32 Under File System.
Select Create a DOS startup disk
Select using DOS system files located at and point to the folder containing the boot disk files.
Then click Start
Or you can download Win to flash ,follow the bellow link for details,
For Windows xp
http://www.intowindows.com/bootable-usb/
Or
http://www.makeuseof.com/tag/how-to-create-a-bootable-usb-drive-from-your-windows-cd/
For vista
http://downloadsquad.switched.com/2009/08/27/make-a-bootable-usb-installer-for-windows-xp-vista-7-with-wint/
Hope this helps.
Let me know if you need more information
Thanks.
Apr 26, 2011 | HP Compaq nc6320 Notebook
Bluetooth - Compaq nc6320
go to the HP site (www.hp.com) and look for the support page, find the downloads for your laptop and get the bluetooth drivers you need there
(here is the exact link ) http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1839154&prodTypeId=321957&prodSeriesId=1839146&swLang=8&taskId=135&swEnvOID=1098
Apr 13, 2009 | HP Compaq nc6320 Notebook
HP NC6320 - drive not detected or found during OS install
That is a possibility that it has a data protection. Try this http://www.ptdd.com/manual2.htm download the super FDisk and burn the ISO to a DVD. then boot off of it and delete all partitons on your HDD that way it will be erased so you can start over new. You might be able to do this on HPs boot disk too. Unfortunately you cannot update the HDD firmware after the drive has no OS on it. In this case you need an outside tool to totally erase the HDD so the install can see it again.
Feb 03, 2009 | HP Compaq nc6320 Notebook
Sir i have formatted my compaq c785tu laptop but i have no sound driver to install so my laptop is not working . what shall i do?
For XP go here
http://saysprasad.wordpress.com/2008/09/11/compaq-presario-c785tu-drivers-for-windows-xp/
For Vista go here
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=3739733
sorry cannot hyperlink,browser crashing!
hope it helps!
Nov 27, 2008 | Compaq Presario C700T Notebook
HP Compaq nc6320 pc notebook issue
it seems that its a not a problem with your hard disk at it load on to the windows succesfully. Chances are any one of these :-
1. Some one might have changed the user name or password.
2. The file that holds the password might be corrupted.
3.If you are using a network based login, ask your administrator for assistance.
The better solution is to Repair install or Re-Install the operating system...
( U might Lose your Data while doing it but not all the time)
Mar 28, 2008 | HP Compaq nc6320 Notebook
Still a problem...
You may have to press F6 when installing xp for raid / sata controller setup.
Nov 20, 2006 | HP Compaq nc6320 Notebook
Same problem in HP dv6040ca
Firstly, the system configuration is normally in management menu or similair on your programmes menu. If not you will find that the bios menu in most laptops are basic and normally the main settings are hidden; you will need to speak to HP Technical for assistance in that. There is no reason to not be able to upgrade to XP Pro; but with an upgrade you would need to keep your original XP Home installation, otherwise you will need to completely install XP Pro firsly using the format option when you insert the Windows disc. As with most laptops all programmes and drivers are usually on a seperate partition on your hardrive, so be aware you are going to lose all this when formatting, so back up all files and settings. You may also have restore discs, if this being the case all programmes and operating system will be on them, so no need to worry about losing anything from your hardrive apart from your documents. Why do you need to dissable SATA?
Can't reinstall xp pro on my hp compaq nc6320
Stephane, I ran into the same problem after wiping out my Compaq nc6320 and trying to install XP Pro. The fix is to disable SATA Native mode. To do this: Enter F10 Setup then System Configuration>Device Configurations>SATA Native Mode and disable it, save the changes and now you should be able to install XP Pro. Remember, when I did this the drive was blank, I don't know if that makes a difference or not. Best of luck! Bryan P.S. If you want to enable SATA native mode after you have installed XP Pro check out this link: http://forums1.itrc.hp.com/service/forums/questionanswer.do?threadId=1042050&admit=-682735245+1161793137260+28353475
Oct 04, 2006 | HP Compaq nc6320 Notebook
HP Compaq nc6320 Notebook Logo
300 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
