Question about Polaroid FLM-323B Television
My 1.5 yr old Polaroid makes a loud buzzing noise for about 5 min
It does this for about 5 minutes and then stops. The picture is fine what can I do to fix this?
    Sniper:
  • 62 Answers
That would be the infamous color wheel. They become warped, cracked, and just plain worn out over time. A replacement is around 200 bucks. If you have intermediate mechanical skills you can replace it yourself. It is located right next to the lamp. There will be a "rounded" section with a few screws holding it in. Remove the lamp assembly from the light engine and the color wheel will b easilly acessable. There will be one set of wires leading from the wheel itself.
Posted on Jan 10, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Samsung model HLP4663WX/XAA with loud buzzing noise, need to know which part to replace.
See attached photo: you have a bad color wheel----it turns at about 12,000 rpm and bearings in the tiny motor go bad.
High pitched or fan like sound is classic symptom.
The wheel is available on the internet and You Tube has video instructions by model number for replacing it---Google the model number for the part number for your set to locate the part and instructions.
This for most people is a do it yourself job---takes like 45 minutes start to finish.
If color wheel slows too much set will shut down as its speed is monitored and the wheel can even shatter causing shutdown of the set.
Steve
Feb 28, 2012 | Samsung DLP HL-P4663W 46" Rear Projection...
5 yr old Maytag fridge stops working
solve dvb skystr 2TV//MAC:00-08-c9-A2-32-9F/satllit Eutelstw3 7E
Dec 05, 2009 | Maytag Refrigerators
I have a 46 inch polaroid lcd tv that when you turn it on everything is fine but after about a minute it starts making a loud squealing noise,even if you mute it, but it will stop after about 15-20...
my 46'' inch tv polaroid lcd has been working fine for 3 years. today my wife and I noticed the tv is shutting off the screen will go black and the power light does switch to red. you can here something inside the t.v clicking but you can turn it on and it will start back fine for 20 minutes then shut off again? Does anybody know whats going out on the tv? let me know
Nov 16, 2009 | Polaroid Televison & Video
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
My polaroid has sound and picture problems
This is a well-known problem with many Polaroid FP displays. Eventually, the picture will simply go black, rendering the TV useless. The solution is a new control board, ~$400.
Feb 27, 2009 | Polaroid FLM-4201 42 in. LCD Television
Loud buzzing noise when turning on
It sounds like a bad internal connection or a component failing. If the picture still is very good take it to a known good repair shop.
Nov 21, 2008 | Televison & Video
Buzzing and poor recption
I wish I had a solution--My DVD picture and sound is fine, but it takes about 30-40 minutes to get any kind of picture but it is broken--not clear at all - and the sound is all garbled, totally stops for seconds to minutes a a time. It is only a little over a yr old. I finally isconnectexd today and am going back to my cheap-o but dependable tv.
Aug 08, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Can you Help?
Check your blower inside the unit, blower frame may be deformed causing the blower to touch the frame make some noise.
Mar 06, 2008 | Refrigerators
Polaroid FLM-323B Television Logo
49 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
