Question about Home
I have a Alterna Amala Shower turn it to the hotest point not very hot.But the hot tapes are hot.
2 Suggested Answers
vincob
  • 718 Answers
SOURCE: i have a grohe avensys shower and even when the
Good answer! Go for it and also you might want to up the heat setting on your water heater.
Posted on Mar 12, 2011
How to remove the escutcheon plate for a Kohler Alterna shower trim piece
they are normally held on with two screws to the valve.
Nov 07, 2017 | Kohler Plumbing
My delta 400 shower is dripping
Take off the shower head and check the rubber washer inside. If it is cracked, off center, or missing, you will have a leak. Also, make sure you are using plumbers tape (teflon tape) around the male threads on the shower pipe that comes out from the wall. Sometimes the pipe leaks at the point where the pipe and showerhead are fastened together, but it looks like the shower head itself is dripping because water always flows downward so it goes over the showerhead at the top and drips off the side.
Nov 20, 2013 | Home
Why does moentrol bath valve give hot water pointed to "C" and vice versa?
Easy one.
Feel the pipes. The pipe on the right should be cold. If the pipes are correct, turn the cartridge 180 degrees.
Jan 20, 2013 | Moen & One Handle Tub & Shower Faucet
I have a grohe avensys shower and even when the dial turned to its hotest its just lukewarn I need to adjust the setting
Mar 12, 2011 | Grohe Home
New Pegasus shower valve that does not get hot water
single water handles are often put back in 180 degrees off, remove the shaft and turn it over
Aug 02, 2010 | Union Pegasus F1228100PBV Series 5000...
When we switch on our shower we have lack of water pressure when the dials turned to hot. When it is turned to cold the pressure is good but as soon as we turn it to hot it reduces the pressure, what is...
If your house was built before the "70's the most common reason is that the hot water trunk line to you shower has corroded shut to the point of reduced flow. It is not uncommon for this to happen on just one line. The controler its self could have an obstruction on the hot side. Replacing the internal part(s) should take care if this. Try to identify the brand of controler and research available part(s).
May 29, 2010 | Home
I I have a 3 way bath/shower/overhead shower mixer valve to fit and am not sure where the pipes should go, there is a hot and cold feed in, but only 2 feeds out, I need feeds for 1. bath filler, 2....
When installing a flexishower head, install it in front of the actual shower head with a diverter switch. If you try to operate two shower heads at once, you may suffer poor water pressure. There are handheld shower sets sold which are installed to existing shower assemblies with ease. Rememer to use plumber's tape and protect your stainless steel by wrapping you pliers teeth in electrical tape.
Jan 15, 2010 | Delta 3 Function Showerhead & Grail...
Moen kitchen faucet. I changed the cartridge but
Single or dual lever? A new ball if single lever. Home Depot or Menards will carry them. Teflon tape if dual cartridge. Stay away from moving parts
Aug 14, 2009 | Moen & One Handle Tub & Shower Faucet
Hi, Advice please, my shower when on hot comes normal out of the shower head but when water temperature normal it stream out of the bottom of the wall fitting, gainsborough shower 2 years old approx....
If you are taking about then neck of the shower head this is what you must do. its no need to turn the water off to the house or to the bathroom first you will need a pair of channel locks and some Teflon tape. first remove the shower head if you dont want to scar the nut on the shower head place cloth between the pliers and the fitting, once removed (very important) turn the channel locks upside down stick one side of the blue handle up in the neck of the shower and rotate to your left to loosen if you are having a leak leak there it should already be semi loose, once removed wrap the threads with the Teflon tape and re-insert making sure it is tight, then wrap the the outer end of the neck with Teflon tape and place the head back on.The reason it leaked is because the plumber who installed it did not tighten it up completly because he wanted it to look straight coming out of the wall and the additional water pressure causes it to leak wheras the hot water causes it to expand and seal
Jul 08, 2009 | Water Pik Wall Mount Shower Head
Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Nov 28, 2008 | Water Heaters
Home Logo
63 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
