Question about Dometic Rooftop RV Air Conditioner
Duo Therm Model 59516.531 RV Airconditioner not cooling
This unoit is just blowing ambient temperature air regardless of the thermostat setting. Can anyone give nme some clues as to what to look for in resoving this problem? I'd also appreciate advice as to what gas thse units use please
  • 108 Answers
The refrigerants in these units is R-22 But there is no reason to think the system has a leak. You need to confirm that the comprerssor is running. This requires an ammeter. If you don't have one call a technician.
Ray
Posted on Jan 10, 2009
Duo therm rv air conditioner repair
Sounds like thermostat is failing. There is a factory set resistor that helps the thermostat keep a 2 degree accuracy. Second possibility is that you have a fan or direct airflow from the cooling system, being devirted, that is allowing the cool air hit the thermostat on the wall.
Aug 17, 2013 | Heating & Cooling
Rv ac unit blowing warm air not cool air
if fan is on auto and on cool bad cooling unit
Jul 06, 2012 | Dometic Rooftop RV Air Conditioner
Duo therm rv airconditioner pulls 17 amps, with compressor running. It cools very well though.
Check incoming voltage first to make sure it's not dropping under load, or low to begin with. Any poor voltage or long runs of extension cords could be causing voltage to drop, thus raising amperage draw.
Jul 04, 2011 | Dometic Rooftop RV Air Conditioner
Installing rv roof airconditioner heat strip
I see what you see also in the manual. The difference is the Heat Strip package that part is optional and the 600212-001 with the optional heat strips becomes the new 600315-001 I talked to Dometic Duo-Therm and the models are the same but they both are not heat pumps but the new heat strip package comes on when told to go into heat mode when you change the thermostat to heat. The part you purchased will fit both model numbers you listed for your roof top air conditioner. Thanks, Sea Breeze
May 09, 2010 | Heating & Cooling
When set to cool and thermostat turned down all it does is blows hot air Duo-Therm model # 59146-331
Check to make sure the compressor and condenser fan are working. If the are you may need to have the charged. If not you need to find out why.
May 02, 2010 | Dometic Rooftop RV Air Conditioner
How many amps does ac draw?
Im taking this is a RV Heater and Air.
Amps 14.7 cooling (at 95 degrees ambient), 12.7 Heating w/optional heat strip
Jan 20, 2009 | Dometic Heating & Cooling
Duo Therm Quick Cool A/C fan motor cycles from low to high
sounds like the motor is either wired incoirrectly and getting 1/2 power all the time or it is going to ground. check out the woiring real good and duse your ohhm meter to check for gounds.
Dec 20, 2008 | Dometic Rooftop RV Air Conditioner
Duo therm ac problem
Same problem. I have a 2005 on a Rockwood Roo. Worked fine in October 2009. Not working June 2010. Problem is not a freon leak, compressor went bad. I banged the compressor gently with rubber mallet then with a hammer but that did not work. The fan runs, the compressor runs but gets hot. Also no indication of freon moving through system as everything gets warm from the compressor outward.
Aug 25, 2008 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
921 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
