Question about Keurig Platinum B70 Coffee Maker
Wont brew no water , lines plugged or what
  • 1,511 Answers
Yes, use needle to clean ports.
Posted on Jan 31, 2014
My Keurig mini sounds like it is brewing, but nothing comes out.
Could be a clog. Open the brew head a insert something small (like a paper clip) into the water output shaft. Swirl it around to break up any deposits there and then run again (without a k-cup). If water comes out but not correctly, repeat cleaning. Also, check to see if hot water is being deposited back into the tank. This will indicate a clog in the output line (line or, more likely, the head). If cleaning the head does not work, then reset the machine by unplugging and plugging back in.
Aug 16, 2014 | Keurig B30 Mini Coffee Maker
Water gets hot, enters the brew cycle. There is a humming noise but no water comes out
Mar 12, 2014 | Keurig B30 Mini Coffee Maker
Only delivers3/4 of a cup
Clean it out. Replace the filter in the water tank if needed. Clean water output in brew head. Make sure water is not pumping back into the tank during the brew cycle - this indicates a clog (or partial clog) in the water line to the brew head (most likely place is at the water output shaft in the brew head).
Mar 03, 2014 | Keurig Coffee Makers & Espresso Machines
I while connecting plug on the electric and
Hi.Great Machine. Your brew unit has a blockage. The brew unit is bypassing the water because the valve wont shut off. Remove the brew unit and try cleaning it. May have to take it to a repairer. Dazza REPAIRER
Sep 23, 2011 | Franke Saphira Espresso & Coffee Maker
Water is hot but it does not brew the coffee.
Hi. How do you know that the water is hot if it wont brew coffee. They have different boilers to do each function. Hot water function. steam function and brew funtion. Sounds to me that you have a clogged brew unit. If hot water is coming from the water outlet, the you do have a fault with the brewing side of things. Dazza REPAIRER
Sep 23, 2011 | Keurig Elite B40 Coffee Maker
Wont start brewing and display wont turn off just says brewing
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 22, 2011 | Keurig B60 Coffee Maker
My krups 4055 that is less than 2 mos old suddenly wont brew. it brewed about 2 cups and stopped. water still in resevoir & turning it on & off & unplugging doesn't help.
Dec 13, 2010 | Krups KM4055
Keurig Special Edition that will not brew
all the lights are blinking its clean, descaled, filled with water and the power button and all the buttons just blink and it wont brew just had this machine less than 6 months and the machine will only quit blinking when i unplug it and yes ive tried different outlets when i plug it back in all the lights start blinking again and it wont brew i want a solution to this problem and i dont want to be sent to another site where they charge me to answer a question the $119 i payed for the thing should be enough im ready to throw it out the window im so frustrated with it
Mar 17, 2010 | Keurig Special Edition B60 Coffee Maker
Not brewing full pots of coffee
Check the in line water fliter. It may need to be changed.
You can try this also.
Put the brew basket in place with no coffee in it, put an empty decanter under the basket. take a full decanter and pour it in the water fill screen at the top of the unit. When the wtaer stops dripping and the unit is back up to temp, try a full brew cycle.
If it works OK, it just got low on water in the tank
Could be caused by a plugged up filter or lime scale build up.
Dec 28, 2009 | Bloomfield 8572 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
