Question about Husqvarna Sewing Machines
Husqvarna S215 needs new bobbin case
Tension on the bottom thread is completely off, might need new bobbin case- are they available for this model, S215
  • Husqvarna Master
  • 7,365 Answers
SOURCE: Singer Concerto sewing machine model 9217 - bobbin thread problem
This problem is common in sewing machines with plastic bobbin cases. The new case you've ordered will most likely solve your problems. I might suggest checking the point of the rotating hook, to be sure it is burr free.
Posted on Feb 01, 2008
SOURCE: Husqvarna Viking #1plus bobbin problem
I have changed stabalizers and the type of bobbin thread i am using (invisible poly) and it seemd to have solved the problem. Note: wind invisible thread very slowly and carefully it is like fishing line
Posted on Dec 16, 2008
SOURCE: Brother Window Matic Model HA3-B5
I believe this is the manual that you need.
http://gotoes.org/sales/BrotherSewingMachineManuals/ViewInfo.pl?Brother=1&Sewing_Machine_Model=window-matic
Posted on Jan 01, 2009
SOURCE: I have a Bernina Virtuosa 155 and use it daily. Without
In checking I can either adjust the tenion screw and if that does not work, purchase a new bobbin case.
Posted on Oct 28, 2009
  • 371 Answers
SOURCE: viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
My husqvarna 870 fix but stays on causing the machine not stitching
What you have is commonly called "bird nesting" or "thread nesting" and is usually caused by the upper thread. Most times the thread is not seated in the tension disk, the machine is not threaded correctly (sometimes the thread will jump out of the take-up lever or a thread guide), or the upper tension is too loose.
1. Install a brand new needle.
2. Remove the thread from the machine.
3. ALWAYS RAISE the presser foot and rethread from the beginning. Verify that the thread path is correct.
4. Load the bobbin in the bobbin case (make sure it is spinning the correct direction), thread the bobbin case, and install it in the machine.
5. Set the upper tension to the midway point.
6. Test your machine. You may need to tweak the tension a bit, but tension is not static and should always be tested and adjusted for the fabric, needle & tension of every project. The tension is correct when the upper and bobbin threads meet in the middle of the fabric.
If it continues to be a problem, you may consider taking it for service.
Jun 07, 2016 | Husqvarna Sewing Machines
How can I repair the top thread from tangling in the bobbin stopper for the Husqvarna Viking Emerald 118?
Thread nesting in bottom usually means that top thread is either not threaded correctly or top tension dials has lint caught in it. Use canned air to blow it out. Also change needle.
Dec 10, 2014 | Husqvarna Sewing Machines
Bobbin tension Viking Freesia 425
Take a look at www.sewingpartsonline.com and check out bobbin case for your model. Does yours look the same? If so, look up how to adjust bobbin case tension on www.youtube.com.
Dec 10, 2017 | Husqvarna Freesia 425
Bobbin tension
Difficult to say.
Might try installing a brand new needle.
Remove the top thread, ALWAYS RAISE the presser foot and rethread from the beginning.
Set the top tension to the midpoint and retest the machine. Tweak the top tension as needed.
Understanding Thread Tension Threads
However, if you believe something is broken in the machine, you may need to order replacement parts.
I need to adjust the bobbin/lower thread tension on my Freesia Viking sewing machine.... Now I know why it was sold. I sew lots... but am at a standstill on how to remove or get to it to adjust it..
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 08, 2011 | Husqvarna Freesia 415
Husqvarna Model 215: My t-shirt material got jammed. I cut it out and then lifted out the needle, cover plate, bobbin and metal plate over the teeth. Then I took out the casing or whatever it's...
Good day!
Good day!
May 24, 2011 | Husqvarna Huskystar 215 Sewing Machine
How do i thread my friends machine. It jams every time she starts sewing. Its a husqvarna 200
I can't find a threading diagram for the 100 but this one is for several other husq models, so could be very close for your friends.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Viking_Sewing_Machine_threading/Viking_150_185_190_Threading_Diagram.htm
Make sure that the bobbin is going into the bobbin case as per the diagram and is into the tension spring. The bobbin needs to turn anticlockwise when you pull on the thread tail when looking at the bobbin inside the case.
There is also a little springlatch on the bobbin case, you need to hold this to release it from the rotary hook to take out. If this isn't working correctly, it will pop out so you'd need to replace the bobbin case.
Now check the top threading too. ALWAYS raise the pressure foot to open up the tensions. And turn flywheel towards you until needle is at highest position. Now follow the threading diagram ensuring the thread does into each eyelet, then down the needle bar and into the needle eye.
Check tension knob number, should be between 4-6, usually 5.
Raise bottom thread manually through the needle plate by holding top thread tail and turning flywheel towards you through one revolution, catching the bottom thread and pulling it up through the hole in the needle plate.
Make sure that you have a new needle in, flat shank to the back, and the right size for fabric you wish to sew, sharp for wovens, ball point for knits.
Now select your stitch, place fabric under foot, lower pressure foot and while holding both threads behind the foot, start stitching. Hopefully, it will now sew for you.
If you can't get the bottom thread to come up at all then its likely that the timing is out and it will need a service.
May 24, 2011 | Husqvarna Sewing Machines
I wound a new bobbin and now I can't get it on the bobbin winding spindle. I have the exact same problem with a husqvarna 400
When you wind a bobbin on a Husqvarna and you leave the machine threaded to wind the bobbin through the needle, you must take the thread down below the foot (a metal foot only) before you take the thread up to the bobbin winder. If you take the thread directly from the needle it creates too much tension on the thread and crushes the center of the bobbin so that either you can't get the bobbin off the spindle or in some cases it damages the bobbin completely.
Some threads, the kind that can stretch slightly when pulled, shouldn't be wound through the needle at all. Instead go through the first guilde and then straight down to the little metal "button like" guide and then to the bobbin. It will create much less tension on the thread and wind it much better.
Oct 11, 2009 | Husqvarna Designer I
As Iam quilting with my macine the top stitches are ok, but back of quilt the thread is all boggled up-Tension ??
yes, this is a tension issue. Check your bobbin area. Make sure you have put the bobbin in the case with the H logo up and the thread pulls off the spool in a counter clockwise motion. Make sure the bobbin is sitting in the case and threaded through the "catch" on the bobbin case. Then leave a long piece of thread from the bottom, holding the end of the top thread, lower the needle for one revolution using the handwheel. Does the top thread catch the bobbin thread and pull it to the top? This is done without fabric. Your checking to determine if the top thread catches the bobbin thread and pulls it to the top. IIf it does not, it is most likely hook/needle timing. f it does, gently pull on the bobbin thread and determine if it pulls through with a little resistence (checking bobbin tension). Make sure you are using correct needle -- Schmitz or Inspira needles are recommended (Universal size 80 is standard). Make sure you are using Husqvarna Viking made for your machine -- original ones were green but there are some new colored ones but all have the Husqvarna logo on them. Otherwise take it to an authorized Husqvarna Viking dealer. You can find your closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck
Sep 23, 2009 | Husqvarna Viking 1
Bobbin on a Viking #1+ sewing machine
Could be the bobbin case tension is too tight--are you using a thicker thread than usual? Also, check to make sure that it is the correct bobbin for your machine--several are very similar but if not exact, will not sew properly. Also, if the thread is not evenly wound on the bobbin, there would be problems. Check to make sure the bobbin thread is threaded through the bobbin tension. It may help to tighten the top tension, but if the bobbin case tension is too tight, adjusting the top tension will not completely resolve the problem. The tension is correct when the top and bobbin threads meet in the middle of the fabric--this means that whenever you start a different project, you may need to re-adjust the tension.
Learn the Ins and Outs of Troubleshooting Sewing Machine Tension
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Jun 19, 2017 | Husqvarna Viking 1
Sewing Machines Logo
140 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
