Washer both fills and drains at the same time
My washer both fills and drains the water from the tub at the same time when set to over half fill without reaching the cutoff level. I have just rendered the wall behind the washer and am suspicious some mortar has been flushed down the line when reconnected and might be blocking a valve. Does this seem like a good starting point to look from? I would appreciate any advise you can provide.
  • 640 Answers
Your drain hose is to low ,,its called the sphion effect,,just lift drain hose up height of machine before it can go down,,,onthejob
Posted on Jan 10, 2009
    President:
  • Washing Mach... Master
  • 2,651 Answers
If your unit is both filling and draining this is usually from a siphoning action, caused by improper drain lines, you should drain the unit into a standpipe at lleast 36inches from floor, and have an "air gap" so as to prevent "siphoning"
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
The water, there was no water left in the tub of the washer, but the clothes were dripping wet; and the cycle was showing to be complete. I had to re-set the dial to the spin setting inorder to completely...
What has happened is that your water pump has gone out and it cannot pump the water out of the washers tub. This is a common issue and replacing the pump is not that hard assuming you have the time, effort, tools and energy.
Jan 23, 2011 | Kenmore 24962 Top Load Washer
Unit is filling up half way or so and just keeps running, but will not fill up all the way almost like water is draining and running at same time
Tub keeps filling does not overflow.
Solution:
Drain hose must be 36 inchs above floor level to prevent siphoning.
Dec 26, 2009 | Roper RAS8445KQ Top Load Washer
Washer will not fill up!
The water is siphoning out as it fills. Your drain hose is too low or has a air block. Remove the drain hose from the drain. Set the washer to fill. Hold the drain hose up higher than the washer. If it fills correctly and starts agitating,correct the drain hose problem.
Sep 23, 2009 | Admiral AW22 Top Load Washer
When tub filling, it drains out at the same time.
The outlet of the drain hose must be higher than the water level inside the tub--normally the pump inside removes the water when needed. Get a plumber to install a proper height drain pipe for you.
Jul 16, 2009 | Haier XQBM22-C Top Load Washer
Keeps filling with water, but draining at the same time!
be sure your drain is nearly to the top of the washer if it is you may need to try a siphon break
Apr 24, 2009 | Washing Machines
Washer will only fill halfway
hello, 1 possable problem a pretty common problem and the solution is blindingly simple. It’s caused by the drain hose siphoning water out of the washer tub. There are two common causes for siphoning and I’ll explain both of them below.
drain-min.jpgOne cause for siphoning is simply that the drain hose discharge is below the fill level of the washer tub. This picture shows the minimum drain height needed to avoid siphoning.
Another common cause for siphoning is not having an air break between the drain hose and the drain stand pipe. Usually, this isn’t a problem since the drain hose diameter is usually much smaller than the diameter of the drain stand pipe. But sometimes folks will inadvertently remove the air break by duct taping the drain hose to the stand pipe. They might do this because the drain hose keeps popping out of the stand pipe when the washer pumps out the tub. Other times, the drain hose might fit into the stand pipe with a tight interference fit.also check your water inlet valve filter/screen make sure its not clogged.
Apr 09, 2009 | Kenmore Washing Machines
Tub fills only 1/2 full but water keeps running as if the tub is not full. If the water level is set to 1/2 or less, tub fills 1/2 full and begins to cycle. The water is running into the tub but not...
Check the drain hose to make sure you have a high loop, ie. make sure the drain hose loops above the height of the washer lid before going to the drain pipe.
Also make sure the drain hose is not going too far down into the drain pipe.
You may be getting a siphon effect.
Feb 20, 2009 | Admiral AAV7000A
Washing Machines Logo
138 people viewed this question
Top Washing Machines Experts
