Question about Dryers
Hampton Bay ceiling fan light clicks and then light turns off
I installed a Hampton Bay Miramar II ceiling fan in my master bedroom a couple of years ago and it has worked great up to this point. I have it wired to use the remote and mainly use it to turn the light/fan on and off. I also use the switch at times. Recently the ceiling fan light stopped working properly. When I try to turn on the light, it comes on for a couple seconds, makes a clicking/popping sound, then the light turns off. I have to hit the remote button again to turn it "off" and then again to try again with the same results. I haven't tried anything yet, but it seems to be that some kind of overcurrent regulator is killing the light or something. What are some good troubleshooting steps?
  • heath chapman Jan 13, 2013
    I have the exact same problem. I think I must bypass the remote with th elight only to keep function. Have you had any luck alternately?
  • Preston Lee Aug 19, 2013
    Anyone solve this? Mine doesn't have a remote. :(
  • 736 Answers
SOURCE: hampton bay ceiling fan stopped lights work
you can test the light switch by temporarily hooking up the light bulb to where the fan normally goes ....the bulb will only work on the highest speed setting but can prove if the switch is bad or not . turn power off before woking in there ... if you know someone with a volt meter then they could quickly test the switch for you .. they can also test the motor for continuity .. .. most of the time the trouble is simply bad connections inside the wire nuts ... like insulation not skinned properly or wire not in the wire nut properly ..you can remove and inspect each connection (power off of course) ... sometimes there is a seperate power line for the fan and light ... so they can be independently controlled externally ... thats not needed when the pull chains are the only off on method ...
Posted on Apr 16, 2010
jharvey572
  • 447 Answers
SOURCE: I have a Hampton Bay Windward II ceiling fan. Fan
sounds like there is a lose or broken conection from were the feed to the balast slits from the main fan conection try rewireing from the live imput to the balast see if that solves it.
Posted on Jul 30, 2011
catriver
  • 878 Answers
SOURCE: reset button and fuse for GE Profile Harmony
Hawk, the good news in looking at your warranty information on this dryer, it states that you have a 2 year warranty on parts only. You would have to pay the labor. There are a few possibilities here, but the pop doesn't sound good. Courtdate is probably right in his post. You would have to get into some detailed testing on the electronics to make the correct diagnosis, which we can do, but I suggest you call for factory service so you don't make any more trips to the ER. Catriver.
Posted on Jan 18, 2008
SOURCE: Fisher & Paykel ED52 electronic
I found advice on the Fisher Paykel web site that suggested the problem could be the door lock. In fact the catch had not properly engaged & when I fixed that the dryer worked.
Posted on Jun 19, 2008
SOURCE: Whirlpool duet dryer will no start...the "sensing" light comes on when you hit start; it makes the click noise in the door when you hit start, it counts down, but it does not tumble or anything
you have a blown thermal fuse. you can get one where they have parts it is about 5 dollars.
Posted on Oct 02, 2008
My Hampton Bay ceiling fan has been making a sound - like a clicking noise - during every revolution of the fan, and at each of the 3 different speeds ever since it was installed.
Try a bit of chewing gum on each of the blades separately, it seems to be out of balance.By trying each individually and turning on each time you should find the imbalance.Cheers Michael....Australia
Jul 21, 2017 | Hampton Bay Dryers
Www gpwarranty com
for the Problem with Hampton Bay 54 in. Windward II Brushed Steel Ceiling Fan check the manual
http://lightingworldbay.com/windward-iv-52-indoor-brushed-ceiling-fan-manual/
Apr 25, 2013 | Hampton Bay 54 in. Windward II Brushed...
I have a Hampton Bay Miramar 60 in ceiling fan, when you try to turn it on the upper light just blinks and nothing else happens. You can't even turn the blinking light off. HELP!!!
Turn off the breaker that controls power to the fan. Remove the batteries from the remote and press the buttons in case one is stuck. Reinstall batteries or new ones. Turn on the fan breaker and try using the remote again
Dec 16, 2012 | Universal Remote Control Hampton Bay...
Trying to remove cover that houses the ball and pipe that hangs the fan. There is no screw to hold the ceiling mount cover to the ceiling mount. I tried pushing up and twisting but no luck. Could someone...
There should be a couple of small screws at the very top on the side of the canopy...you will need to loosen these a few turns and then turn the canopy and drop it down...
This link will help you they had the same problem as you...
http://www.askmehelpdesk.com/electrical-lighting/hampton-bay-ceiling-fan-removal-25673.html
heatman101
Apr 29, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
We have a hampton bay ceiling fan model 54cvt. We cant figure out how to change the light bulb or change the direction of the blades. We dont have a manual for the fan.
This fan is also known as the Hampton Bay Covington 54 Ceiling Fan. You need to turn the globe anti clockwise until it comes out. The full instruction manual can be found here.
http://lightingworldbay.com/hampton-bay-covington-ceiling-fan-54-cvt-manual/
If you have another fan model other than the Hampton Bay 54CVT then try here
http://lightingworldbay.com/hampton-bay-ceiling-fan-manuals/
Jun 28, 2009 | Hampton Bay 52 In.Carriage House II in...
My home is pre wired for a ceiling fan in the master bedroom. There are two light switches that control the pre installed wires. One for the light on the fan and one for the fan. There are four wires
The usual wiruing for these fan/light circuits is that the black wire on one switch is for the fan and the red on the other switch is for the light. If you are using a remote set up for both fan and light, then hook the remote wires to the black and white wires in the ceiling, You can cap off the red wire in the ceiling as this will not be used.
Apr 24, 2009 | Hampton Bay 24002 Ceiling Fan
Can't figure out how to reverse the Hampton fan with the remote
I have the Hampton Bay Windward II Ceiling Fan SKU 523-127. I have replaced various parts over the years including the ballast, light shade, 9" 30 Watt Circline bulb and the remote.
Hampton Bay Windward II Ceiling Fan SKU 523-127 was sold by Home Depot, and manufactured by King of Fans.
King of Fans website is: http://www.kingoffans.com
This fan can be seen by clicking on Products --> Ceiling Fans --> Click on page 9 (at the bottom of the webpage) then click on the Windward II fan picture, then you will be able to click on Download Owner's Guide.
Mar 11, 2009 | Dryers
Hampton Bay remote for ceiling fan caused an electrical fire
We just installed this fan and within 1 day the electrical wires in the receiver burned and would have caught fire had it not been caught!!!
Jan 07, 2009 | Universal Remote Control Hampton Bay...
Fan cuts off for no reason
It could be the capaciter, found in the light fixture area.
Aug 19, 2008 | Hampton Bay 04379 Madison Avenue Ceiling...
Bought a monte carlo ceiling fan. removed old fan and found 3 white and 3 black wires, plus grounds. Cannot figure out how to connect the unit up. breaker controls all ceiling lights in master bath,2nd...
Try this:
* All 3 black together, with black and blue from fan
* All 3 white together, with white from fan
* All grounds (earths) together, with all greens from fan
Apr 28, 2008 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
882 people viewed this question
Top Dryers Experts
