Question about Kenmore Elite Oasis ST 6807 Dryer
I have a kenmore elite oasis model 110.67032600 that will not run. Did a load ,put in the next load and no go.i got lights on my panel,yet no error codes. Help
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Check the thermal fuse for continuity.
Posted on Nov 27, 2012
Testimonial: "Thanks richard the probelm was the thermal fuse. Replaced for less than 20 bucks. Saved a ton of money on service call.thanks again you guys are great."
  • Richard Roth
    Richard Roth Nov 28, 2012
    Thank you and thanks for using FixYa!
SOURCE: Kenmore Elite Oasis Electric Dryer, Model #110.6708*, 6709*
Hi, my Kenmore Oasis Elite electric dryer has a poor fitting lint screen which allows for a large build up of lint in the bottom of the motor housing. This lint has also become blackened as if exposed to high heat. Some electric wires also show evidence of the plastic coating turning black and over heating. I get the feeling this unit is a fire hazzard. Model # C6704 A few days ago there was a distinct odour of electrical burning. This unit was purchased new in Dec. 08. Anyone else have this experience?
Posted on Apr 27, 2010
SOURCE: Kenmore Elite Oasis Dryer with Airflow problem
same problem removed back cover cleaned lint found pulley had unscrewed and belt was off.installed pulley rev threded and put belt back on.
Posted on Apr 07, 2008
SOURCE: Kenmore Elite Oasis Dryer 6705 not start
I take the timed approach with appliance problems. If they occur 10 years after purchase, I buy a new one. If five years, I call a repair service and measure the cost of repair against the purchase of a replacement. If one year or less after purchase, I pile the expensive, offending, useless lump of an example of the decline of American workmanship into the back of my pickup and push it out on the doorstep of the store where I purchased it.
I find this method to be the most cost-effective and least troubling. And costs me about the same as calling the repair service.
In fact, right now I'm loading up my Kenmore Elite Oasis 6705, purchased March 13, 2007, (note that the problem began one month AFTER the warranty ran out) in the back of my pickup and I will make at quick stop at Sears to push it off the back of my truck (I find if I don't stop, but keep the truck rolling it makes for a much louder and attention grabbing drop off) then find the nearest hardware store so I can purchase some strong nylon line to string across my backyard so I can dry my clothes. I also purchase a bit of extra line so that I have enough to string up any Sears or Kenmore representatives who might stop by to inquire about the appliance they found on their doorstep.
Posted on Apr 12, 2008
SearsTechToo
  • 261 Answers
These are awesome solutions, L1 or the black hot wire supplies the lights and one leg of the heater while L2 the red power wire completes the circuit for the heater and powers the board. A great test is this, if the light is on and the load doesnt go, bad load. In this case trace the L2 line and find where the power stops, the first is the interface and the same goes for Frigidaire. I would also get the part number from Sears, tell them you will wait for money and then look for other local sources, it is worth the wait to save 80 dollars for a back order.
Posted on Sep 13, 2008
SearsTechToo
  • 261 Answers
SOURCE: Kenmore Elite Oasis error code F41
I don't see this code often although I can steer you in a good direction, F41 to F47 is error codes for dual motor problems on oasis.
Kenmore elite oasis st model #110.68062801 won't run.
First check the breaker. You may have one leg out. Then check the starter switch. Also check the door switch. It could be broken or mislodged. When it is fully engaged, it will start up. Lastly the motor could be burned out. If it is an older model, then consider a new one. However, the repair on this is not that high if you can do it yourself.
Apr 26, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
My Kenmore Elite Oasis washing machine has error code "UL" while in rising cycle and stop. Can you tell me what is the problem and how to solve it.
My Kenmore Elite Oasis washing machine will drain but not spin and it keeps jumping back and forth to different time cycles. It continually reads "UL" and I keep trying to adjust and balance the load but it does not help.
Jun 25, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have a model 27096 top load kenmore elite oasis he washing machine that keeps flashing code F2 and keeps turning itself on. Help
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
Apr 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis Elite---110-27086601
This error only shows in diagnostic mode, with power off choose any buttons except stop and power, press in intervals 5 seconds on and 5 seconds off until 88 appears and all light light up. If the user panel is faulted F 2 will flash in the display, press the same button you used to start diagnostics to jump to the next error code and once through 88 will flash and diagnostics will start. Sometimes once F2 flashes and the machine has not been repaired it will stick at that mode.
Aug 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis ST 6807 Dryer Logo
845 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
