Water keep running on my LG T1117TEFTO - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
You need to replace the water inlet valve.
Posted on Nov 27, 2012
LG Washer wm2496hwm water keeps running in and over flow on to floor
The water level sensor is defective and or clogged, have it replaced.
Nov 08, 2016 | LG Washing Machines
I have an lg washer i replace the water pump but the water pump keeps on running when is washing
check that you have put the correct wires on the right terminals of the water pump
May 06, 2015 | LG Washing Machines
Water keeps running into machine even when power is switched off
failure of the inlet valve. You can find this in the inlet pipe section, remove and check if dirt had accumulated to jam the valve. If not the valve is faulty and must be replaced.
Apr 03, 2014 | LG Washing Machines
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Sticks water does not stop
Hi. I has lg refri sometimes water keep running none stop .Do you know what wrong? Thankyou...
Sep 13, 2010 | LG LSC27910 (265 cu ft) Side by Side...
Hooking up water line to LG LRSC26920TT - water runs great through line, but once connected to fridge, no water runs through line in fridge - no water comes out when trying to fill a glass. No water...
dissconnect water line coupling behind lower kick plate under door. push water dispenser; and sell if water flows out line. keep a towel handy. it there is water; then, the problem is in the door itself. of course, make sure the water solenioids are working.
Apr 17, 2010 | LG LRSC26925 Side by Side Refrigerator
Water keeps draining LG WF-561SPP top loader
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Apr 02, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
You have a jammed open water valve in the machine and it will need to be replaced.  Call a qualified LG technician to service this problem.
May 25, 2008 | LG WM1814CW Front Load Washer
LG WD-8074fhb
Your problem is either in the control board or the water level switch.  The computer can't tell if the water has drained or the control board is stuck in the 8 minute drain cycle.  Recommend pulling the plug and wait 5 minutes to reset the computer.  If the problem persists, it will require an LG experienced tech to see what's going on.
Mar 14, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
