Question about Air Tools & Compressors
Titan LX-50 spray gun removed filter housing I then remove the plastic nut that is screwed into the housing that turned out to be a tube with a spring and a ball bearing along with looks like a round brass part that holds the ball bearing. Then this other round part with a hole in the middle fell out when I turn the gun over but not sure if it came out of the tube along with the other parts. This is what I need to no in what order does it all back into the tube. thank you Robertfor the Help.
SOURCE: Removal of spinner (it turns the spray arm) on top of pump housing.
If your talking about removing the bottom, main spray arm for the MDB7100AWB, in the middle there's the little hole with a plastic cog, button, whatever you want to call it that you can grab in pull up and spin, but this is just a spray jet and has nothing to do with removing the arm. But, around that hole in the middle is a disc that is somewhat flat and only sticks up about an 1/8 of an inch from the arm, this is what you need to unscrew to remove the arm. It almost looks like part of the arm (especially if it's caked with detergent), but it's actually the screw fastener that holds the arm on.  Just muscle that disc, turning counterclockwise, and it should unscrew, then you can remove the main arm unit.
For the top arm, it just pulls straight down and pops out.  You feel like it's about to break, but then it just pops out.  To put it back in, it just snaps in when you push it in.
Hope this helps.
Posted on May 31, 2008
  • 2712 Answers
SOURCE: spray gun tips
RECOMMENDED SPARE PARTS FOR EACH GUN * Air nozzle, needle and tips * Packing and gaskets * Hoses and fittings * Gauges * Proper lubricants * Filter screens * Diaphragms for pressure regulators
Posted on Aug 27, 2008
  • 9 Answers
SOURCE: Repair cartridge in Moen Monticello single handle lavatory faucet
After some additional experimenting, contrary to information I was previously able to gather, I discovered that the white plastic retainer doesn't (in this type of Moen faucet) actually screw off but rather is held in place by a spring clip inserted from the rear of the retainer (toward the wall side of the basing). Simply sticking a small screwdriver in the opening (approx. 45 degrees downward) and tipping the screwdriver toward the front of the faucet, snaps the spring clip out through the opening.
The plastic retainer than lifts off. Note: the flat sides on the retainer suggest that a wrench will be needed but such is not the case.
Posted on Nov 28, 2008
  • 35 Answers
SOURCE: Spray painting operation advice for Binks mach 1 hvlp spray gun
Hey paul its paul. I posted on here so hopefully you will give me some feedback. That is a very nice gun. One of my favorite. I'm guessing you know how to use a HVLP gun but if not here are a few tips. Make sure it is clean. Very clean. Your gun probably came with a manual, you should read it. It will help you greatly. First off, you want to have a regulator, about 40 psi is what i start with. You need a space you can practice some painting before laying down a new coat on the corvette. Haha. So next you will have a pressure adjustment knob, you want to start with this all the way closed and with the trigger pulled, just half way so just air is coming out adjust the air until it sounds even. Next you can try to spray. If it seems like the Fan, like the width is not enough you can adjust the fan, another knob, closer to the back of the gun, you ussually want about 5-6 inches of fan, if you are spraying at the normal 6-8 inches back from the piece. Last adjustment is the fluid adjustment, you want to put on a decent amount of paint, clear or primer, and not cause runs. This is going to take some practice because everyone moves at a different speed.
So you are going to have to play with your gun and figure out which knob does what. After that these instructions should get you a bit further, with some practice you will be laying down a nice paint job in no time.
Paul.
Posted on Feb 26, 2009
emissionwiz
  • 76691 Answers
SOURCE: 1998 Jaguar XJ8 front wheel bearing
it does press out/in, but they can get stuck. u are using a hydraulic bearing press?
Posted on Mar 20, 2009
Need manual to put back ball and spring back into the gun triger housing .
You may have to contact Titan and request an assembly diagram.
Jul 18, 2017 | Air Tools & Compressors
Need gasket at spray gun handle for tti lx-80
You can get them at a paint store or you can make one i have serveral LX80s and i rebuld them all the time . If you have a build up of paint clean it with laquior thinner its a simple seal and it never wares out Ihave these guns that are 20 years old and the olny time i ever had a problem with this seal was when i used a torch to clean the gun before rebuilding it So keep it clean and you could use it every day and rebuild it every 5 years
Apr 05, 2011 | Titan Air Tools & Compressors
Dishes in the top rack not getting clean. Bottom rack is fine.
Your filter/chopper is clogged. You have to clean it out and that will restore water pressure to the top rack.
  1. Remove the bottom rack.
  2. Remove the top rack
  3. Remove bottom Spray arm (turn top nut clock wise)
  4. Take off the delivery tube by turning it clock wise over the heating element ( undo the two clips one at the back and one on top)
  5. Take out the screw for the top screen and remove top
  6. Take one screw out for chopper housing and remove
  7. Remove chopper and clean or replace chopper if broken
Reinstall all parts and test.
That should help please rate your experience. Thanks
Dec 11, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
How to remove the Prime/Spray assembly on the Wagner Paint Crew. The Prime/Spray knob is held on by a retaining clip which I can't figure out how to remove without resorting a hammer and pry bar and risk...
You can unscrew it without removing the plastic part - just use thin vice grips and get a piece of the metal nut, unscrew down (counter clockwise) and it should come off with average pressure. I checked mine, not much to go wrong there, then screwed back in. I have similar problem with pressure, it is likely a worn O ring. Seems to be in the outlet valve as I replaced some of the inlet valve rings and same effect. Research says the outlet valve is the problem if paint comes out of the squeezed nozzel while in Prime mode, which mine does, and is likely not building the pressure as some paint is flowing back through the worn outlet parts.
Aug 06, 2010 | Wagner Power Products 0154842 Medium Spray...
Wagner paint crew won't build pressure or shut off. Can I test the outlet valve or the inlet valve? Or just start buying parts and hope I get the right one. ??/ Thanks..
1. Does it pump paint in PRIME position. If yes, then the outlet valve assembly may be stuck or bad.
2. If it won't pump paint in the PRIME position, the inlet valve may be stuck, just poke your finger down the inlet hole (machine off) . It is spring loaded and should move about an 1/8".
3. The worst option is the pump piston if froze. To check: remove the plastic hopper assembly, comes off with about 4 screws from underneath. The whole thing just pulls off. Now you can see the inlet assembly with two O rings. Use the white plastic hex shaped tool comes with the spray, and stuck on the lower base of the unit. Unscrew the inlet assembly. If clean enough, you can see the end of the piston. It's about a 1/4" diameter. Turn the machine on for a moment and you shoud see the piston move back on forth. If it doesn't the piston is froze. Good Luck with that.
Dec 08, 2009 | Wagner Power Products 0154842 Medium Spray...
Dishwasher won't drain
Check the piston and nut assembly. This is located inside the tub at the very back, behind the spray arm. There is a filter and frame that does not allow you to see it so you have to remove it. To do so first remove the filter frame, (4 1/4 in hexhead screws). Once you have remove all 4 screws then you will see a circular yellowish colored piece of plastic. This is your piston and nut assembly. To remove, just loosen it counter-clockwise. If you can't loosen it by hand, then try taking needle nosed pliers and opening them slightly, enough so that each tip of nose can grab each ridge in the plastic nut. When you get this out, take a close look. You should see a spring and inside, a piece of rubber(off whitish color). If you were to take your hand from the bottom and compress the spring, and view to part from the top, you should see that whitish rubber gasket create a seal. If it does not then that part needs to be replaced. Only about 15.00 or so and they are notorious for going bad in time. If it looks like the seal is ok, then I would check your drain line, disposer, house plumbing for clogs. There is a remote chance that a piece of debris may have gotten into your collection chamber, but thats very rareI'm betting that its a bad piston and nut assembly though. No auxillary drain pump on that model so I would say we most definately have a bad piston and nut assembly, but still check it first. Takes less than 5 minutes for avg person to check. Good luck!
Apr 04, 2009 | GE Nautilus 24" Built-in Dishwasher
AL2340 will not prime. Motor runs but cannot get it to prime
I worked at a tool rental center when I was going to college and learned many useful tips / tricks about airless sprayers. Airless sprayers have two check valves/balls that can stick on their seats or stay open due to chips of paint on seat. Easy method to prime is to remove intake filter from machine, tilt the machine back far enough so that the pick-up tube is pointing up high enough to pour water in tube until full; hold in this position and turn on machine. If water is sucked in turn off machine and tilt machine into pail of water and restart to check for prime. If it still will not prime remove water from pickup tube and use air pressure into tube with bypass valve open. Air pressure will attempt to release the stuck lower check ball. If air pressure does not release stuck ball you may have to use physical pressure against ball. If lower check ball was stuck you can assume that the upper check ball is probably stuck also. An aid to loosen stickey valves is to pour solvent into pickup tube with machine tilted back as before leave overnite. Enjoy
Dec 09, 2008 | Campbell Hausfeld Airless Spray Guns &...
New boiler and o-rings
Do you have any type number on the machine?
Dec 07, 2007 | Saeco Incanto Rondo Fully Automatic Coffee...
Small plastic top and mid spray arm do not turn, bottom does
decrete, you want to get down to the chopper and screen. If the screen is plugged up with gunk there won't be enough pressure to reach the top spray arms. Check out the posted pics. Remove the lower spray arm. Rotate the rear feed arm to the right until it unsnaps from the tube going up the back. See the 4 torq screws holding the filter on. Remove them. Lift the filter up. Now you will see the chopper inlet cover. 1 torq screw holding it in. Lift it up and there's the chopper and screen. Catriver..post back
Apr 09, 2007 | Whirlpool GU2400XTPS Built-in Dishwasher
Air Tools & Compressors Logo
110 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
