Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Mystery part Bissell 1699-P. I removed the top cover and a part came tumbling out (from the rear of the machine - towards the handle area). I have no idea were this part belongs. I have a schematic of the cleaner but I can not locate the part on it. I tried to copy and paste a picture of the part but that isn't working so I will attempt to discribe the part: There is nothing stampted on the part that I can see. It is plastic(white), 2" long, 3/16" in diamater. One end is U shaped (u-shape is 1/4" wide and 1/4" deep), 1/2" from the u is a circle projecting around the shaft (1/4" total diameter of 'circle'). The other end tapers down to a noched end - 1/4" long, 1/16th thickness, with a barb (for lack of the proper name) on the outside edge of it. Since opening the cleaner and having this part fall out I have not attempted to use the cleaner! So I can not tell you what it is and is not doing. Please help!!!1 Thank you Thank you for any help you may offer.
  • 2 more comments
  • stefff4788 Jan 12, 2009
    I can email you a picture of the part and a link to a scamatic for the 1699
    No I did not see the part in those pictures!
    Thank you
  • stefff4788 Jan 13, 2009
    Is there anyone of the 'experts' who has actually taken one of these apart? If so this should be an easy part to identify.
    I have not used the cleaner since this part 'fell out'. I will try the cleaner today and get back to you on if it works properly or not.
    Brigadier General:
  • 5,158 Answers
One question... you haven't mentioned that the vacuum doesn't work now... as hard as this is to accept... if it doesn't effect the function... forget about it.... i could very well have been something you vacuumed up along the way.
Robert
Posted on Jan 13, 2009
  • 115 Answers
Posted on Jan 12, 2009
    Genius:
  • 1,239 Answers
Hi
  • Cleaning performance decreases quickly as the permanent cloth filter becomes clogged with dirt.
  • Airflow forces 100% of all vacuumed dirt directly against the permanent cloth filter – no cyclonic air path or separation is achieved. The result is dirtier filters for greater clogging potential and less vacuum power.
  • Debris is not released from the permanent cloth filter until the vacuum system is turned off. This helps to unclog the filter, but a dirt film remains – reducing original performance.
  • Permanent cloth filter systems can not be restored to like new condition once dirt and dust are embedded in the filter. Coatings like GORE-TEX® and Teflon® help reduce embedded dirt, but do not eliminate it.
Posted on Jan 11, 2009
  • ABHISHEK.C
    ABHISHEK.C Jan 11, 2009
    HI REFER THIS
  • ABHISHEK.C
    ABHISHEK.C Jan 13, 2009
    email me that picture part abi3@in.com
  • 15,935 Answers
Sounds like a hose retention clip?
Is it cyllindrical like a tube?
Does the heat light on the front come on?
  • blueextc3221
    blueextc3221 Jan 11, 2009
    An item with a barb usually indicates it is supposed to be secured in a hole, and not meant to come out. Look for a hole to put the barbed piece in. It may have just gotten dislodged accidentally.
  • blueextc3221
    blueextc3221 Jan 13, 2009
    Is there a schematic available online?
    Without actually seeing the piece, it is hard to say - could be a broken part off another piece.
    Sergeant:
    Scholar:
  • 199 Answers
Http://www.bissell.com/Products/ak/replacementparts/p/proheat+upright+deep+cleaner/product.aspx?%23=Detail#Detail
just click this link and check out is the paRT which you r reffering ;listed in the diagrams.
  • 10,594 Answers
I will try to help you out but I need schematics and picture of that part. You can email at welcomejee at yahoo.com Thank you.
Cleaning my bissell 1699 and diverter came off when lifting the cover off. How do I re-install it? Thank you!
You may want to contact a BISSELL Authorized Service Center to have a qualified technician inspect your machine.
Here's a quick link to locating one. http://www.bissell.com/service-centers/?cid=ccsocial
Jan 04, 2013 | Bissell 1699 ProHeat Clear View Upright...
Wear do you put the water
Inside the main tank is another container for clean water.
To fill it, lay machine all the way down. Lift handle and remove container. Take to sink, turn handle, and remove lid. Fill with hot, clean water. Replace and lock the lid. Place container back into tank and put handle down.
Sep 29, 2010 | Bissell 1699 ProHeat Clear View Upright...
Using machine..
Here's the link for Bissell 1699
http://www.bissell.com/images/UserGuides/7901_1008.pdf
If it is a different model here is the main page:
http://www.bissell.com/Product_Search.aspx?Criteria=1699
This should help you.
Mar 01, 2009 | Bissell 1699 ProHeat Clear View Upright...
Where do I put the water.
1. Release the handle and lay the machine
handle back to access the tank.
2. Remove the tank from the base of the
machine by lifting the tank carry handle.
3. Carry like a bucket to the sink. Rotate the handle forward
to unlatch the lid. Lift off and set the lid aside.
4. Fill up the bladder with clean hot tap water.
*Do not boil or microwave water as it can
destroy the bladder.
5. Replace the top of the tank by matching the
lid and tank edges. Handle must be in the
forward position in order to replace lid. Rotate
Note: Remember to secure the lid and test to make
sure it is secure before picking up the Tank.
6. Place tank into machine base, seating firmly in place.
Rotate tank handle back into latched position. Bring
machine handle back into upright position.
You can download the manual from the Bissell website www.bissell.com
Jan 28, 2009 | Bissell 1699 ProHeat Clear View Upright...
BISSELPRO HEAT CARPET CLEANER
With the top part of the handle off, lay the handle back and at the top in the middle, there is a catch, just push it in to release it and the front of the handle will come off.
Jul 21, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View uses very little soap.
The valve at the bottom of the soap tank may have gone bad, Also try running a mix of water and vinegar(not on carpet) to see if it will clean the system out. The system may just need cleaning out.
Jun 06, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell
Do you mean the handle? If so, there are 2 screws and nuts holding the top part of the handle on, remove these then pull off the top part. Then on the back, near the bottom, are 2 holes that go in aways and there is a screw in each one, remove them and the two halves of the handle will come apart and you can get to the heater and lines.
May 04, 2008 | Bissell 1699 ProHeat Clear View Upright...
I have misplaced the directions for the Bissell powersteamer powerbrush. I need the directions for filling the u tank etc.
Release the handle and lay the machine handle
back to access the Tank.
2. Remove the Tank from the base of the machine by
lifting the Tank carry Handle.
3. Carry like a bucket to the sink. Rotate the Handle
forward to unlatch the lid. Lift off and set the lid aside.
4. Fill up the Bladder with clean hot tap water.
destroy the Bladder.
5.
Replace the top of the Tank by matching the lid
and tank edges. Handle must be in the forward
position in order to replace lid. Rotate the handle
to the carrying position to latch the lid.
make sure it is secure before picking up the Tank.
6.
1.
Lift the formula Tank up and out of the machine base.
2. To fill the Formula Tank, first unscrew the Cap
and Insert. Always use genuine BISSELL formulas
to maximize cleaning and for the safety of your
machine. Fill formula up to the line and replace the
Cap and Insert. Place Formula Tank back into the
base of machine, making sure it is seated securely.
Note: If bottle leaks, check for proper positioning
of red gromment and straw.
Apr 29, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
