Question about Dell Latitude E6400 Laptop
Pantalla parpadea desde que la enciendo.. la pantalla parpadea..y conectada a un monitor no lo hace.....
    New Friend:
Tengo el mismo problema. compre toda la pantalla excepto la pantalla lcd. le puse todos los cables nuevo toda la parte de atras y me siguio haciendo lo mismo. ahora voy a cambiar la pantalla. de servir te dejo saber!
Posted on Dec 11, 2012
2 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: buenas noches, apenas enciendo mi
Use a floppy disk or USB memory key to create a password reset disk using the following Microsoft instructions: How to Create a Password Reset Disk
The easiest way to recover from a lost password situation is to use a password reset diskextlink.gif. If you have a reset disk, follow these steps:
  1. At the Windows logon screen, click Reset password.
  2. Insert the recovery diskette or USB key.
  3. Follow the instructions on-screen to create a new password.
  4. Log onto the account using your new password.
new_note.jpg Note: Password reset disks are valid for the account they were created on. If you use a password reset disk to recover your password, you do not need to create a new reset disk afterwards.
Issue 3: Resolve Error: The User Profile Service Failed the Logon
The following Microsoft Knowledge Base Article provides instructions on how to resolve The User Profile Service Failed the Logon. User profile cannot be loaded error.
"Error message when you log on to a Windows Vista-based computer by using a temporary profile: "The User Profile Service failed the logon. User profile cannot be loaded"extlink.gif Article ID: 947215.
Issue 4: If You do not have a Password Reset Disk
If you have lost or forgotten your password, and a password reset disk is not available, reinstalling the operating system is the only recourse. For information on reinstalling Windows, refer to Dell Knowledge Base Article, How To Restore or Reinstall Microsoft® Windows® on a Dell™ Computer
Posted on Nov 07, 2010
MI COMPUTADORA DEL DIMENSION 5150 CUANDO LA ENCIENDO LA PANTALLA SE QUEDA EN ***** Y ME DA UN ERROR DE FLOPPY DISKETTE SEEK FAULURE STRIKE THE F1 KEY TO CONTINUE, F2 TO RUN SETUP UTILITY, SI LE DOY A...
Entre a F2 como lo indica y continue con lo que le indica.Usualmente puede dar un "Repair" pues lo otro seria instalar de nuevo el sistema operativo.
Vuelva por mas ayuda o si esto le resolvio el problema deme un "Dedos arriba o un testimonio de lo resulto.
Suerte!
Aug 04, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Si levanto la pantalla de mi notebook no muestra nada, al bajarlo ante de cerrarlo muestra bien el contenido. mi notebook es compaq prsario c700.
Llevelo a servicio autorizado HP porque lo que presenta es problemas con el Flex (cable plano) que lleva la señal desde la placa madre debajo del teclado hacia el monitor LCD en la parte superior, Mientras, tal vez pueda conectar un monitor externo al laptop por el momento. pero es un error serio que debe ser atendido por personal calificado por HP
Mar 12, 2011 | Compaq Presario C700T Notebook
Hola amigos tengo un problema con un Tv Sony wega modelo kv-29fa515 chassis BA6/9 el tv me enciende osea arranca bien imagen, color y sonido pero alcabo de cinco segundos se me cae la imagen osea queda la...
por favor si alguien tiene informacion que me sirva para arreglar esta falla,le agradesco de corazon.el tv enciende y la pantalla queda oscura,el filamento enciende y los voltages de catodo estan elevados(192v) si aumento el escren, aparece imagen muy al fondo,la pantalla tiene lineas de retorno y cambia de azul a verde.
Jan 12, 2011 | Televison & Video
ERROR SCANNER 22 EN IMPRESORA HP LASERJET ML1120 MFP
REMOVE THE SOFTWARE AND FRESH INSTALL WITH THE DRIVERS CD
Dec 02, 2010 | HP LaserJet M1120 MFP All-In-One Printer
Cuando enciendo mi tv no da imagen solo parpadea una luz de lamp y se apaga de nuevo lo hace tres veces y se desconecta el solo
usted nesecita una lampara nueva le recomiendo que habla a samsung , ya que biene toda la lampara comple i con isntrucciones como reemplazar la lampara
Sep 03, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
Abri mi terminal Verifon vx510 para darle mantenimiento pero cuando la volvi a cerrar solo parpadea la pantalla, creo que se activo el tamper como lo desbloqueo o restauro, algun switch activa esto
buenas tardes lo que debes de checar son unas gomas que tiene adentro son las que activan el parpadeo o si necesitas ayuda mandame tu correo el mi es dawer_2010@hotmail.com
Jun 09, 2010 | VeriFone VX510
Tengo el problema q de mi portatil extensa 5230 series el encendido de la pantalla y el encendido del teclado me han quedado inutilizados, y no me deja utilizarlos en modo normal pido por favor un concejo...
Primero, se prende su computadora normalmente? Que hace su teclado cuando la computadora esta prendida? Hay algun error que aparece un su pantalla? Desde cuando tiene este problema? Installo algun programa antes de que pase este problema??
May 17, 2010 | Acer Computers & Internet
Polaroid mp3 mpa-200115
mi polaroid modelo MPA-200115 al tratar de encenderlo , me dice q tiene un boot error 2, shutting down y no lo enciende y no se q hacer
Nov 07, 2008 | Polaroid MPA-20011S Digital Media Player
Dell Latitude E6400 Laptop Logo
538 people viewed this question
Alun Cox
