Question about Xerox Office Equipment & Supplies
What does error 012-267 mean ona xerox 7328 copier?
  • 2072 Answers
SOURCE: Xerox 7328, error 018-543 Shared name error in server
Prerequisites:
  • The printer must be connected to the network.
  • The IP address of the printer is required.
  • The HTTP option must be enabled on the printer. To obtain the IP address or to confirm if the HTTP option is enabled, print a Configuration Report. See the Related Items below for additional information.
  • A user account for the scanner must be created (account needs full control access rights).
  • A directory to be used as a repository for the scanned files must be created. The directory must then be shared.
  • The Hostname of the workstation must be known.
Scan to File is set up in several steps:
  1. The first step is to make sure the scanning service is enabled on the printer.
  2. The second step is to set up the scan file repository.
  3. The third step is to create any necessary templates.
  4. The final step is to configure the template with the required settings.
NOTE: This solution assumes Microsoft Internet Explorer is being used as the web browser. Other web browsers may vary.
  1. Make sure the SMB port is enabled. Print a Configuration Report to verify this setting. See the Related Items below.
  2. Open an Internet browser window.
  3. Enter the IP address of the printer in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services window will be displayed.
  4. If prompted, enter the username and password in the fields provided, and then click [OK].
    NOTE: The default username is "11111". The default password is "x-admin" and must be entered in lower case letters. If the username or password has been modified or forgotten, contact your System Administrator.
  5. Click on the [Properties] tab. The Properties options will be displayed.
  6. Click on the [+] next to Services on the left side of the window to expand the options.
  7. Click on the [+] next to Network Scanning.
  8. Click on [File Repository Setup]. The File Repository Setup window will be displayed.
  9. Click on [Edit] in the Default File Repository section. The File Destination screen will be displayed.
    NOTE: A maximum of five file repositories may be configured. Generally, just the default repository is configured for scan to file.
  10. Select [SMB] from the Protocol menu.
  11. Enter a descriptive name in the Friendly Name field.
  12. Enter the IP address or Hostname of the computer where scanning will be setup in the Hostname / IP Address & Port field.
    NOTE: The default SMB port is 139. Generally this port number does not change.
  13. Enter the Share name in the Share field.
  14. If necessary, enter the scan path in the Document Path field.
  15. Click on the [Prompt at User Interface] or [System] radio button from the Login Credentials to Access the Destination section.
  16. Enter the scan user name in the Login Name field.
  17. Enter the scan user password in the Password and Retype Password fields.
  18. Click on [Apply]. A “Settings have been changed” message will be displayed.
  19. Click on [Reboot Machine]. A "Do you want to reboot?" message will be displayed.
  20. Click [OK].
  21. Close the browser window.
  22. Test scan to file using the default template. See the Related Items below.
  23. If necessary, create scan templates.
Posted on Dec 16, 2008
SOURCE: xerox DC12 copier system error 3-315
re install halftone pcb
Posted on Jan 09, 2009
goodgold
  • 389 Answers
SOURCE: XEROX COPIER XC865 HAS AN H4 ERROR CODE HOW TO
H4Fuser temperature too low. Must be reset in diagnostics
Posted on Dec 19, 2009
  • 5370 Answers
SOURCE: Xerox DocuColor 3535 Copier Problem
116-325 RAP An error occurred in ESS fan rotation:---------Try reset procedure:-- to correct your issue:
Simultaneously press and hold the 1, the Stop, and the Power Save buttons on the Control Panel.
If the problem persists try:
Hold the 6, the Stop, and the Power Save buttons.If still it comes again,---------
Hold the 4, the Stop, and the Power Save buttons .If still it comes again ,-------
Hold the 3, the Stop, and the Power Save buttons .If still it comes again then there is internal problem with cooling fan .The ESS fan module has to be replaced.The part number for ESS fan module is
127K32920.To order this part you can order it from online website.click this link directly to order the parts:---
http://www.iteminc.com/parts_docucolor_1632_2240.htm
this will help.Thanks.Helpmech.
Posted on Jan 21, 2011
Xerox 7328 touch screen not taken
I share a links, so read it and follow instructions. If not understand then contact printer support technician and check it why your printer touch screen not working.
Read more..http://www.office.xerox.com/latest/W73EG-01U.pdfand Xerox Printer Support
Thanks,
Sep 05, 2014 | Xerox WorkCentre 7328 Multifunction laser...
CODE 006-382 XEROX...
The error means that the interval of the ROS (C) signals exceeds the specified value. The normal problem is a bad mcu board. Measure the value between PJ401 on the MCU board and and ground for +5vdc. If you get +5 then replace the MCU board. Part number 960k31352. http://www.iteminconline.com/itemdesc.asp?ic=960K31355&eq=&Tp=
Aug 25, 2014 | Xerox WorkCentre 7328 Multifunction laser...
Fault code 008-164 for xerox workcentre 7328
Xerox 7346
What is the problem of error code 008-164
Nov 07, 2012 | Xerox WorkCentre 7328 Multifunction laser...
Xerox 7328 error code 026-717
Make sure the DNS info is properly configured.
http://www.support.xerox.com/support/workcentre-7328-7335-7345-7346/support/enus.html
Jun 23, 2012 | Xerox Workcentre 5225 / Copier, With...
XEROX WORKCENTRE 7328 IS RUNNING SLOW WHILE PRINTING PDFs
Are you printing to the printer using the Xerox Global Print Driver PCL6? If so, this will be the cause of your problem. Earlier versions of the driver werent as bad when processing PDF documents. I would suggest that you download the Workcentre 7328 PCL6 driver and try that - the problem should clear.
Cheers
Jon.
Dec 17, 2010 | Xerox WorkCentre 7328 Multifunction laser...
Our xerox workcentre 7328 shows fault code 004-346
I don't have that manual, but similar manuals say IBT Home Sensor Error. Check your accumulator belt for damage. You may also have a dirty sensor.
The belt PN is 604K20891and is rather expensive and fragile
Whit
Item, Inc.
Aug 06, 2010 | Xerox WorkCentre 7328 Multifunction laser...
1,028 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
