Question about Refrigerators
Fridge is warm. No cooling
No fans are running on it at all?
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number?
Posted on Nov 26, 2012
SOURCE: Not cooling or cold
The REFRIGERATOR WAS MOVED TO ANOTHER SITE. AND IT HAS NOT GOTTEN COLD SINCE MOVE, PLUB UP 2 DAYS AGO. iT WAS UNPLUG AND CLEAN 2 DAYS BEFORE MOVE. COULD IT NEED ANTI-FREEZE?
Posted on Sep 07, 2008
BNewberry
  • 93 Answers
SOURCE: fridge/freezer not cooling
I will be more than happy to help you out with this.  I am a factory authorized servicer for Frigidaire.
Read this Article first on Frigidaire Refrigerators not Cooling.  Then if you have any more questions about this ask me on Frigidaire Tech Support.
Thanks, Bill
Posted on Nov 08, 2008
  • 833 Answers
SOURCE: Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Posted on Nov 20, 2008
  • 306 Answers
SOURCE: fridge section runs warm. Freezer ok it seems.
Sounds like the inside fan is getting worn out. Should vary in speed. Try replacing the fan and see if that fixes it. I'd bet it will. ken
Posted on Jan 12, 2009
Greg20
  • 149 Answers
SOURCE: Problems with Whirlpool 21.0 cu. ft.
checklist: freezer fan running, compressor fan running, compressor running, any frost buildup on back wall of freezer. you may have to take a rag and touch the compressor to feel if its vibrating to see if its running unless you can hear it. please reply
Posted on Jun 14, 2009
The refrigerator side is cool, but not cold. The freezer side is frozen, but melting. The ice in the ice maker melted, but created one big ice cycle that has not melted. The fan underneath is running,...
I just ran into this problem this year. Is it very warm underneath your fridge? If you remove the cover in the back, you may find that you compressor is so hot you can't touch it. You can first try blowing out your cooling fins in the back of your fridge. A fan is connected to it and it should be next to the compressor. For my case that did not work. I then replaced the fan for the cooling fins and now my fridge works fine.
Nov 10, 2012 | KitchenAid KSRS25FG
Hot point Manufactured by GE MD# HSS25GFPE WW Not Cooling Fridge or Freezer.
Is compressor (black canister)running? It should be very warm if it is. If not, motherboard is most likely bad.
Oct 20, 2017 | Hotpoint HSS25GFP Side by Side...
The outside of the top freezer of my refrigerator has been getting very, very warm. It remains warm for maybe 30 min., then cools off, and then gets very warm (almost hot) again about an hour later, only...
That is usually caused by the evaporator fan not running. It's located under the fridge accessed from the back behind the cardboard cover. The fan should run when the compressor runs.
Jul 26, 2010 | Frigidaire Refrigerators
We have a Dometic 2310 - freezer works well, fridge seems inconsistent. Top of fridge gets very warm. Is it helpful to add a cooling fan?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 24, 2009 | Dometic RM2652 Refrigerator
Nov 20, 2008 | Kenmore 64802 Top Freezer Refrigerator
Fridge not cooling
evidently the fan that runs in the freezer and blows air into the main fridge has a circuit issue or the fan is frozen, but if the bulb does not work then its a circuit issue. likely on the same circuit as fan.
Mar 20, 2008 | Refrigerators
Warm fridge
how is the freezer side check theese and get back to me hold the rating till we are done is the freezer fan running as the freezer cools both sides is there heavy frost on the back wall of the freezer down toward the bottom is the compressor running is the fan that cools the compressor running are the coils underneath the unit clean is the ice cream to soft milk too warm
Mar 02, 2008 | Amana ASD 2624 Side by Side Refrigerator
LG fridge suddenly stopped cooling.
If the fan inside the freezer is running and the compressor behind the fridge is running and is hot to touch, you have a gas problem or the compressor is inefficient. This can only be confirmed by connecting refrigeration gauges to the gas system and should only be performed by a fridge tech.
Nov 04, 2007 | Refrigerators
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
