Question about Refrigerators
Samsung sr s20 fridge freezer fan rattling
A fan in the back of the fridge is rattling constantly. This fan stops for a while after opening the fridge door.
  • 4 more comments
  • Rietveld Nov 27, 2012
    SR-2028C it says as model number in the frisge compartment. The electric circuit tag says DA68-00484A
    I don't see any real east way to open the back of this machine. I guess Samsung doesnt want me to either :-)
    east=easy
  • Richard Roth
    Richard Roth Nov 27, 2012
    You are talking about the fan in the freezer section correct?
  • Rietveld Nov 28, 2012
    Richard, no. It is a fan behind the fridge. When I bang on the back of the fridge part (lower middlesection of the machine) the rattling lessens a bit for a while. Like I am banging the ice off the fan.
  • Richard Roth
    Richard Roth Nov 28, 2012
    Do you see ice on the back panel of the freezer or behind it? You may need a new defrost thermostat.
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number listed on the refrigerator?
Posted on Nov 26, 2012
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
  • 69 Answers
SOURCE: noisy F&P fridge freezer
Most of f&p make this noise its most annoying, but could also be ice buildup on the fan blades, creaking and cracking is normal as the pipes expand and contract is these thin foamwall fridges, not nice fridges, insulation has been compromised to lower cost, they work twice as hard at keeping cool
Posted on Sep 23, 2007
zeusfaber
  • 247 Answers
SOURCE: Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Posted on Feb 28, 2008
  • 3 Answers
SOURCE: Problems with my samsung fridge/freezer SR-L36/SR-L39
is whisker growth like ***** hairs?
Posted on Jun 04, 2008
  • 2920 Answers
SOURCE: fridge left open all night and wont cool but the freezer still works.
time for a new fridge
Posted on Aug 27, 2008
Hello, we hv the samsung SR-C31NMO samsung fridge. from 2 days the freezer is not working. Same thing had happened few days back, but automatically it became normal. I can hear some sound behind the...
It sounds like the evaporator fan is not working properly. If the fan is stopping and starting it can cause the freezer to become a block of ice.
The fan motor may need replacing
Mar 31, 2011 | Samsung Refrigerators
Samsung Fridge Noise
Hi Laura. Welcome to FixYa. I am Kelly.
What your hearing is a fan motor usually an evaporator fan motor in the freezer compartment. More often than not when this symptom appears there is ice build up on the evaporator coils due to an automatic defrosting problem. The fan blade can also be damaged so that the fan motor gyrates wildly in the mounting bracket or the fan bearings could be faling.
Having mention all of the above here is a way you can determine of you have defrost problem or not.
1. Unplug the unit at the wall
2. Remove the freezer contents
3. Place a fan blowing into the freezer section for a bit over 2 hours. Mind you this will make a constant water mess so be ready to tend to the drips and minor puddles.
4. After the manual defrosting session with the fan reload the freezer contents.
5. Plug the unit in at the wall outlet
6. Check for normal temps after about 4 hours
and
7. There should be NO FAN NOISE.
If the fan noise ceased due to your manual defrosting of the unit then you can probably expect the ice build up to repeat in 3 to 4 days along with decreasing performance of your refrigerator.
IF the ice comes back... you have an automtic defrost problem that will need serviced.
Kelly
Apr 20, 2010 | Refrigerators
Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Jun 28, 2009 | Refrigerators
GE Profile - Fridge Doesn't Cool But Freezer Works Fine
Had a similar problem with my Kenwood Fridge Freezer
If you're mechanically minded you could check if there's an opening and motorised flap (usually behind a cover) at the top of the fridge - Cold air from the freezer enters the fridge through this flap) The Sound you heard could have been the motor trying to open / close this flap. This flap can become frozen in the closed position - so cold air is unable to enter the fridge compartment) My fix was to thaw it with a hairdryer and reassemble. Another fix would be to empty the freezer and open the doors - it might take more than 24 hours but once completely defrosted if the flap is the issue it will have defrosted. Once plugged in again the door will open and cold air will start to flow into the fridge compartment. I had a quote for €195 for a call out / repair
I fixed it myself in an hour - Hope it works for you ...
Sep 20, 2017 | GE Profile PDS22MHR Bottom Freezer...
Flashing freezer temp on Samsung SR S22
how to remove cover from twin cooler samsung sr-s20-s22
Mar 25, 2009 | Freezers
Fan is rattling on zanussi fridge freezer how can i get at it or ny suggestions as to what the problem is
might be ice on the fan.....when its completely frozen your fridge part will stop working.
Feb 28, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
Constant and fairly loud noise
thats typically an air circulating fan thats either faulty or something is touthing the blade. open up and see.
Jan 09, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
We have a fridge/freezer model srs758dp 12 months old tongight has started making a huge rattling sound from the back of the unit on certain cycles goes for a fair while when we open freezer door it stops,...
this sounds occurs due to fan & frost inside the coil
check weather evap.cover has fitted properly.if frost is there defrost the fridge for at least for 24hrs it will work properly
Jun 10, 2008 | Samsung Refrigerators
Refrigerators Logo
167 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
