Question about National Little Tikes Hummer Yellow
Where online can I order a battery and charger for a 4931 hummer h2 suv vus
5 Suggested Answers
SOURCE: Gear problem
If you hear the motors turning, remove the seat and check to see if the motors are securely tightened to the transmissions. They are easily tightened, if loose but the transmissions must be removed to gain access to the screws. The hardest part of the job may be the removal of the 'press nut' that holds on the wheel. The wires to the motors will also need to be cut. Please be very careIful not to break off the contacts at the motor. They are soldered on and cannot be pulled off so don't try. That's why the wires need to be cut. If the motors are tight then open one of the transmissions. One of the 3 gears in the reduction gearset may have seen its axle break out of the bosses. This happened to me. The gear was fine. The axle is 7/16th' diameter. Buy a 2 1/2 inch long shoulder bolt where the shoulder is 2 inches long and the last half inch is thread. Drill a 7/16 hold through the cases from inside out using the center of the broken bosses as a guide, reassemble the cases using the bolt as the new axle for the gear. Tighten securely but not overtight. I used modest amount of locktite to prevent loosening. Now all runs like new. $3.16 for bolt, nut, washers. I also found replacement trans on Ebay for $44 plus ship. Your choice.
Posted on Dec 19, 2009
  • 1702 Answers
SOURCE: Hi, I am having trouble
Hi, Go to Radio Shack or a store like that to get an adapter kit. Good luck.
Posted on Jul 13, 2011
OriginalEQ
  • 6 Answers
SOURCE: Our 4931 Hummer is not
I'm currently overhauling one I bought from a yard sale. I've seen on forums the gear switches get all mucked up and don't make contact (like mine here). They can be cleaned or replaced. http://www.shopjandl.com/kids---baby-ride-on-toys-little-tikes.html
I'm an electrician so most parts can be tested to see if they work by 'continuity'. You might need someone to test the battery, then motors in the back and then the switches for you to find your problem.
Posted on Dec 01, 2011
adamfjeld
  • 1508 Answers
SOURCE: battery charger
is it 12v or 6v battery? check the battery and let me know the volts and the amp hour, i can ship you a charger for $10 plus shipping
Posted on May 14, 2012
When I connected diagnostic/testers to the OBD-II connector on my 2007 Hummer H2 SUV, they did not work at all, does anyone know why ? What are the exact pinout of this connector on Hummer H2 ?
Data Link Connector (DLC) Pin
Wire Color
Circuit No.
Function
Not Used
PU
1132
Class 2 Serial Data
Not Used
BK
1050
Ground
5
BK/WH
1851
Ground
6-15
Not Used
16
OG
640
Battery Positive Voltage
Dec 26, 2014 | 2007 Hummer H2 SUV
How to find location for H2 SUV fuel filter 2006 model
The Hummer has its fuel pump and filter inside the tank
Aug 24, 2014 | 2006 Hummer H2 SUV
Hummer h2 language change
use the info button on the steering wheel and cycle through the options. You should be able to find the one that allows you to change the message language back to English.
Feb 26, 2013 | 2007 Hummer H2 SUV
Battery charger
May 12, 2012 | National Little Tikes Hummer Yellow
Where do you plug the charger on little tykes H2?
The charger will plug directly into the battery, but it must be a specific little tikes battery charger because the connectors are slightly different than other battery connections.
The battery is usually located under the hood in front. I try to charge my batteries up at least 18 hours.
Hope this helps.
Apr 20, 2009 | National Little Tikes Hummer Yellow
National Little Tikes Hummer Yellow Logo
56 people viewed this question
Top National Toys Experts
romney2012
Joseph Hoffmann
Candy Beggs
Candy Beggs
Level 1 Expert
Are you a National Toy Expert? Answer questions, earn points and help others
