Question about Welding Tools
Instruction manual precision gold A55KJ soldering iron
DIGITAL SOLDERING IRON
  • 2712 Answers
SOURCE: soldering iron tips
It is very tempting to start soldering components onto the circuit board straight away, but please take time to identify all the parts first. You are much less likely to make a mistake if you do this! 1. Components stuck onto paper Stick all the components onto a sheet of paper using sticky tape. 2. Identify each component and write its name or value beside it. 3. Add the code (R1, R2, C1 etc.) if necessary. Many projects from books and magazines label the components with codes (R1, R2, C1, D1 etc.) and you should use the project's parts list to find these codes if they are given. 4. Resistor values can be found using the resistor colour code which is explained on our Resistors page. You can print out and make your own Resistor Colour Code Calculator to help you. 5. Capacitor values can be difficult to find because there are many types with different labelling systems! The various systems are explained on our Capacitors page.
Posted on Aug 27, 2008
CarlGehrke
  • 169 Answers
SOURCE: what kind of soldering iron??
For general soldering of wire and electronic components I use a 60 watt Weller iron.
What you should use depends very much on what you want to solder.
Posted on Dec 10, 2008
  • 508 Answers
SOURCE: Can't change tip on soldering iron
use small vise grips on edge of screw!
Posted on Jun 24, 2009
Dissolu
  • 221 Answers
SOURCE: repair wiring on weller soldering iron model ec1002
If the coil wire is snaped then you will need to replace all the coil. usually the power from the outlet goes stright to the coil and connects to both ends of it's windings
Posted on Jul 24, 2009
sivaranjini
  • 241 Answers
SOURCE: iron is not heating up hot enough stained glass soldering iron:
hi friend,
check this out
Consider the wattage of the soldering iron. A good soldering iron will have wattage of 80 to 150. A wattage of lower than 80 is not ideal for stained glass. You need a soldering iron that will melt the solder fast enough for your project. Consider the type of temperature control you want. Some irons will have a temperature control built in the tip. When the temperature drops, it will turn on and when the temperature is reached, it will turn off. Other soldering irons have a built-in rheostat. You control the temperature by turning the dial up or down. A separate rheostat can be purchased to plug your soldiering iron into. Rheostats are highly recommended. This lets you match your temperature to your soldering style and allow you to do decorative effects.
  • Step 2 Consider the heating element. There are two types of elements, ceramic or wire-wrapped. Ceramic core irons maintain heat more efficiently than wound wire heaters. In a ceramic core, the heater core extends into the tip for faster heat transfer. This will keep the tip hot for a longer period so you can work quickly and faster. Ceramic irons maintain their temperature longer and heat up within 30 to 60 seconds.
  • Step 3 Consider the weight of the soldering iron. You want a soldering iron that is lightweight and balanced. You will have less fatigue when using a lightweight soldering iron at long stretches of time. Check to see if it fits your hand comfortably. Check to see if it has a good rubber cushion for your hand.
  • Step 4 Check for the ease of changing tips on your soldering iron. When soldering stained glass, you want to match your tip to the technique you want to use. There are a variety of tips on the market for soldering irons, and you want to be able to change them easily.
  • Step 5 Check the soldering iron to see if it has a heavy-duty cord and a three-prong plug. You want a grounded three-prong plug to prevent the possibility of shock.
  • hope this helps u
    please rate me......................
    thank u for using fixya
    regards
    sivaranjini
    Posted on Nov 25, 2009
    Where does the gauze go in a soldering iron and whats it for?
    If the gauze came as part of a kit with the soldering iron it is de-soldering gauze. You put it on a joint, heat it up with the soldering iron and it soaks up the solder so you can remove the item from the circuit board.
    Apr 17, 2016 | Welding Tools
    What is the uses of an iron stand ?
    Hello, the iron stand is used to keep the soldering iron from tripping over that reason why it so heavy. The coil spring is used to hold the soldering iron and dissipate heat. The with some water will help keep the soldering tip clean. GB...stewbison
    Jun 22, 2011 | Trisonic NEW SOLDERING IRON STAND HOLDER +...
    Having trouble with solder sticking with metal to metal applications
    Soldering is intended for soldering alloys together such as copper, silver, gold....solder does not stick well to steel and aluminum...also, you need to use a flux when soldering...this flux cleans the connections of impurities and allows the solder to stick to the metals to be joined...Judging by the iron that you have...it looks like it is mainly used for very small soldering applications where not too much heat is required...If you want to solder larger items(such as soldering to a metal chassis) then I would recommend using a soldering iron or soldering gun with more wattage
    Jan 16, 2011 | Weller Bp860mp Battery Powered Soldering...
    I just bought the soldering gun but the instructions on the package aren't very useful how do i use the gun?
    A soldering gun is used much the same as a soldering iron for melting solder mainly to connect electronic components to circuit boards. To use it you plug it into the electricity mains and press the trigger. This causes the metal tip to heat up. Allow a minute or so for it to reach full heat and press it to the components you want to solder together. When they heat up press the solder against them. The solder melts and runs on and between them forming a bond. Remove the soldering iron and release the trigger. Once the trigger is released the gun starts to cool down again.
    If you've used a soldering iron before you'll probably find the gun more awkward as it cools down every time you release the trigger. It's really only useful for quick jobs where you're not going to need it every few minutes. For other jobs where a lot of soldering is involved a soldering iron is better. The advantage the soldering gun has over the soldering iron is that it heats much faster for quick jobs.
    Dec 04, 2010 | Cooper Industries Weller 7200PK 75 Watt...
    Iron is not heating up hot enough stained glass soldering iron:
    hi friend,
    check this out
  • hope this helps u
    regards
    sivaranjini
    Nov 25, 2009 | Weller Welding Tools
    What kind of soldering iron??
    Dec 09, 2008 | Welding Tools
    Soldering Question
    # Never touch the element or tip of the soldering iron. They are very hot (about 400°C) and will give you a nasty burn. # Take great care to avoid touching the mains flex with the tip of the iron. The iron should have a heatproof flex for extra protection. An ordinary plastic flex will melt immediately if touched by a hot iron and there is a serious risk of burns and electric shock. # Always return the soldering iron to its stand when not in use. Never put it down on your workbench, even for a moment! # Work in a well-ventilated area. The smoke formed as you melt solder is mostly from the flux and quite irritating. Avoid breathing it by keeping you head to the side of, not above, your work.
    Aug 27, 2008 | CRL Soldering Iron Temperature Control
    Soldering iron problem
    Solder contains lead which is a poisonous metal. Wash your hands after woking with it.
    Aug 27, 2008 | Black & Decker Black Decker Dualtemp...
    Welding Tools Logo
    1,167 people viewed this question
    Top Welding Tools Experts
    Bill Boyd
    Are you a Welding Tool Expert? Answer questions, earn points and help others
