Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fisher and paykel dishwasher top draw does not unload water after the wash
  • Fisher and P... Master
  • 3,247 Answers
The pump is faulty or the drain hose is blocked. You need to take the pump rotor out from the base of the drawer and inspect the sump for blockages. Usually a seed or chicken bone stuck between the drain sump and the pump rotor sump.
Posted on Jan 27, 2013
  • 784 Answers
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Posted on Dec 29, 2009
  • 713 Answers
SOURCE: I have a single draw Fisher and Paykel dishwasher.
ok , F1 means your flood switch has activated, which is underneath the drawer. now they show the F1 fault because of 2 reasons.1st there is still water underneath drawer causing switch to activate. 2nd your activator board which has the flood switch attached is faulty reading your posting it has been about 15 days since the fault happened. the water should have dryed around switch by now. if there is power to the unit and it is still coming up with F1 fault then possibly you have damaged the activator board. please reply and tell me if you have power on or off at the present time. to fix the problem it is alittle bit involved but i can guide you thru it when you reply .good luck
Posted on May 07, 2010
  • 3247 Answers
SOURCE: Need to know how to take the see through cover off
I think you are referring to the wiring cover at the bottom of the drawer. I will assume you know how to get the drawer out.
To remove the wiring cover
1. Carefully release the four wiring cover clips from the front
lower section of the tub taking care not to damage them.
2. Release the three clips on the underside of the tub which
retain the wiring cover.
3. Pull the tub fully open and lift it up at the front (this makes it
easier to remove the wiring cover from the rear of the tub).
4. The wiring cover may now be carefully moved forward to
release it from the rear of the tub.
5. To reassemble first ensure that the wiring harnesses, drain
hose and fill hose are clipped into their correct position.
6. Then refit in reverse manner
Please rate this solution if this is what you were after. Otherwise post a comment and fixya.com will try to help you.
Posted on May 31, 2010
  • 3247 Answers
SOURCE: top draw beeping delay and water not draining
Not sure what you mean by beeping "delay" I am not sure if there is any such light on the dishwasher. The HRS DELAY is displayed on the LCD when dishwasher has been set in delayed start mode. Are you seeing this flashing in an orange background? There could be several reasons for water not draining. Does the beeping go away if you press the power on/off button? Also does the delay flashing stop. Have you checked to see nothing is blocking the drain pump which is the same rotor that drives the washer arms.. What about the kitchen down pipe - is it clear? If you think you have to take the drawers out to reach the drain hose then follow instructions on page 7 step 2 of the installation manual. It is for a later model but your one should be similar. Make sure you turn the mains power off when working inside the dishwasher.
Posted on Jul 08, 2010
ginko
  • 19396 Answers
SOURCE: Hi the top draw of
Hi Vicki.
F2 means that there is a problem with the rotor attached to spray arms on one side, and to impeller pump on the other. The electronic control detects rotation thanks to a hall sensor located at the base of the rotor. If rotation is not regular you get F2.
The problem is usually given by debris stuck in the rotor mechanism, and it is fixed taking apart and reassembling the rotor and arms. The sensor can also be faulty, but this happens quite uncommonly. Usually the problem gets fixed disassembling, cleaning and reassembling rotor and arms.
The video below shows how to disassemble upper part of the rotor. If cleaning that area does not fix the problem, sensor and part underneath must been accessed. At that point the repair will become more complicate and you may require a professional. Try cleaning the rotor, most of the time that is enough to fix the problem.
Regards.
Ginko
http://www.youtube.com/watch?v=UXzuJvKIIgU
Posted on May 25, 2011
F& P bottom dishwasher draw won't drain. Top dish draw draining fine?
Excess water in
the DishDrawer
Drain hose(s) bent or
kinked.
Straighten the drain hose(s).
Blocked filters and/or drain
hose(s).
Clean the filter plate/drain filter. Unblock
the drain hose(s). Refer to the user manual
Aug 28, 2014 | Fisher and Paykel Dishwashers
I have a Fisher Paykel DD24 dishwasher and when using top drawer after wash cycle is complete there is always water in drawer. Top drawer is unable to drain water after wash cycle is complete...what can I...
If the cycle is complete and dishes are clean, then you need to worry. Try to pull the drain hose up a bit under the sink. Also buy a Finish dishwasher cleaning kit and run dishwasher as per instructions on the kit. That should clean any obsrtuctions in the drain side.
Nov 20, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
DD603 top draw cycle getting stuck on 73min??????
Normally if you started the rinse cycle with water already in the base of the dishwasher it will immediately go into circulating the water through the wash arms. Do you hear the wash arms running when the washer is stuck at 11mins? Also when the washer is stuck at 73 mins are the wash arms running all the time or do you hear the pump operate at some stage?
If you have the dishwasher manual available make sure the water pressure setting is at HI or LO depending on your rated mains water pressure.
Apr 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
My Fisher Paykel DD603I top draw whines when it is first turned
The lid seal on the top drawer is faulty and needs replacement. It might be cut or damaged and is obstructing the drawer from closing. THis also may have caused the flood switch to trip as water can leak if drawer is not sealed.
Nov 29, 2012 | Fisher and Paykel Dishwashers
Top draw beeping delay and water not draining
Jul 06, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher and paykel dd603
Flood switch is at the very bottom underneath the bottom draw in the base floor.Unplug cord.Open bottom draw all the way & squeeze a towel or sponge under the draw & soak up the water..The washer should work now..Why did it flood in first place?
Check that dishes are not stacked higher than top edge of the draw otherwise it can't seal.this can happen when children are asked to stack the dishwasher.Another cause is some models the seal is an inflatable tube that seals the top edge of the draws,it gets cut or sliced buy a plate that was stacked to high when you closed the draw.there should be no clunk of dished hitting when the draw is closed.
May 30, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
I've got Fisher and Paykel Excellence Top loader 7.5 My problem is, it won't unload or drain water. What do i have to do?
Hi, The washer wont unload or drain water until the drain pump is working. Get the pump off and look for debris. To remove the pump you unlock the tab and twist the pump a hair. The pump is on the bottom of tub.
Apr 13, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
The dish draw doesn't seem to drain out the water
I can talk you through the fix for this on live chat. cheers
Mar 11, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
153 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
