Question about Cameras
Vivitek 6.36 digital camera gives error code ZL0020 when turned on then goes off immediately-Why?
I get error code ZL0020 when I turn it on and nothing else. It shuts itself off immediately after giving the error code.
SOURCE: Camera Experience an error 00000018-4489-957-000
I also spent some time fixing this error. the reboot thing as suggested in the manual did not work! Then I smacked it gently on the metal part of the camera, then again more strongly. Suddenly it started to work! Never thought of that way repairing the camera from HP... Try it but not break it!
Posted on Dec 25, 2007
t00nz
  • 4738 Answers
SOURCE: Error Code: Lens Error 113,0,0,0
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 03, 2008
the q guy
  • 393 Answers
SOURCE: camera turns itself off immediately even though it is fully charged
are you using rechargeable batterys or cheap ones
you have to get batteries specifcly designed for digital cameras or they wont power the camera properly.. try using different batteries !!
Posted on May 22, 2009
tahir_afzal
SOURCE: system error 0013 benq DC E610 DIGITAL CAMERA
i had the same problem but now i have solved it.........its not a software problem..... the lens in fornt of the camera is not able to come out......just hit the camera 3-4 times on a table it will start working.......hope your problem is solved
Posted on Jul 28, 2009
  • 11967 Answers
SOURCE: Camera turns itself off immediately after turning it on.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 28, 2010
Cod zl0020
no code in my book..zl0020..sorry tried
Sep 22, 2009 | 2002 Nissan Sentra
When i turn on my camera, the lens goes in and out about 3 times, and finally turns on. when it finally turns on, it says turn off and turn back on immediately! i can look at pictures and videos, but cant...
The lens of your camera has been stuck.
You need to go to Canon authorised service center. They will replace the optical assembly.
OR
You can give it to an expert for repair, he can repair it without replacing the optical assembly.
Aug 10, 2009 | Canon PowerShot A540 Digital Camera
Camera immediate shuts off after turning it on
try using lithium or nimh rechargeable batteries. I had the same problem and switched out the batteries and put in eveready nimh batteries and it works fine now. Guess the old cheap ones weren't doing the job. And they were brand new batteries.
Oct 12, 2008 | Nikon Coolpix L11 Digital Camera
When i switch on my camera the word access appears on the screen ,i cannot take any pictures?
when i switch on mycamerathe word err_code:zl0020 appears on the screen and gets turn off
Jun 29, 2008 | Cameras
Lzoom lens goes out and in, immediately, then camera turns off
Pull the battery and plug the charger into the camera. It should turn on and take pics now. If it does, you need a new battery!
Yeah, I know, the battery shows fully charged but it's weak and old so it really doesn't have the current to drive the lens.
Try to clean the battery terminals with an abrasve pencil eraser, (old red eraser #2 pencil from grade school) and wiggle the battery in the camera (gently) to clean the terminals inside the camera.
Let the camera charge the battery completly, (not in the dock!) and see if it turns on.
If it does, you will probably find that it discharges VERY quickly.
Buy a new battery! That extra battery that you have had since you bought the camera is probably also shot! They do have a shelf life!
If the camera does not turn on with just the charger, (no battery) then it's probably a lens error, but you should see an error code if it is.
Ned
Apr 09, 2008 | Kodak EasyShare V550 Digital Camera
Sony DSLR-A100, error code 0x5b
Same here. My camera gives me the same error code unless I shoot with the largest aperture/smallest F-number.
Mar 28, 2008 | Sony Alpha DSLR-A100 Digital Camera
Cameras Logo
59 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
