Question about LG 37LC7D 37 in. LCD HDTV
THE ON AND OFF SWITCH CLICKS AWAY CONSTANTLY RED STANDBY BUTTON FLASHES NO PIC ON TELLY
  • 1,684 Answers
That is a very common symptom of a failure of the filter capacitors in the power supply board. You can either purchase a new power supply board which runs about $75-85 or you can rebuild your board for less than $20. If you want to rebuild your board you will need to replace the defective capacitors on the board. Here is a link to information showing where the capacitors are located on the board and the values needed to do the replacement.
http://www.ccl-la.com/catalog/product_info.php?products_id=214
I hope this helps you out,
BuddyMc
Posted on Nov 26, 2012
3 Suggested Answers
  • 8457 Answers
SOURCE: When I turn it on (with remote) it goes from
Power supply board is dead.Replaced the power supply board will solved this problems.Tries websites Shopjimmy.com,Ebay.com for a refurbish power supply board for the replacement.
Posted on Mar 02, 2010
amarie99
  • 7 Answers
SOURCE: my lg telly has no sound or picture power button just flashing red
There are red,white,and yellow wires at the back of the T.V. Make sure
that the yellow wire is plugged into the yellow plug in hole, white wire has to be plugged into the white plug in hole, and the red wire plugged into the red plug in hole.Sometimes for the red wire you have to plug it in a black plug in hole. Make sure your T.V. is connected to you reciever. If this doesn't help I'd try calling somone to fix it for me.
Posted on Jun 24, 2012
Lcd tv light flashing but no picture or sound
If you removed power by turning off power itself to the set instead of turning it off by turning the set itself off---that is not a good thing to do.
When power is restored a surge can and likely hit the power supply in your set---time for a tech or shop to open it---I suspect they will find the standby or main power supply is damaged or now bad.
Dec 06, 2012 | Bush Televison & Video
The iron will not steam and the standby button is constantly flashing
Always switch off the unit and allow to cool before cleaning or storing. .... If your steam generator does not work, check the following points: ... working temperature, the LOW STEAM ICON will flash whilst the heating cycle takes place ... steam. 9 When ironing is complete, press the POWER. STANDBY button.
Jul 27, 2011 | Morphy Richards Jet Stream 42271 Iron
When you switch telly on the blue standby button just flashes, and telly will not go on.
some start up circuit problem occur in your tv, problem is in power supply section.
Feb 08, 2011 | Beko Televison & Video
My plastation 3 works when i hook it up through the hdmi cable but not the regular cables that come with the consol. is there a setting i need to change?the cables are not broken nor are the hookups on my...
Ok, you need to reset the PS3 back to standard video settings by doing the following :
Step 1. Turn the PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later. Release the power button when you hear this second beep.
Step 3. Wait for the display to initialize.
Hope this helps
Nov 25, 2010 | Sony Playstation 3 (PS3) Console
Telly on but no sound orpicture
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL2100 you can find it here http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click=48173 .Have a blessed one!
Apr 20, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Panasonic TX-32LXD60 won't switch on. Red standby light flashes quickly and then becomes constant. TV Clicks and slight flicker then nothing. Can anyone help please ?
U have sound at all?Yes,than ur LCD INVERTER backlight board it dead.If power LED light keep flashing nothing on,sound or picture.Than the power supply board is dead.Must replaced the power supply board.Tries Websites Shopjimmy.com,Ebay.com to buy these refurbish boards.
Feb 26, 2010 | Panasonic TX32LXD60 32 in. LCD TV
Code for 32 in lg tv to work with sky control
TV
RED + SELECT
TV
0056
try the power button if this switches off your telly press select to save the code if not repeat TV and then Power until it does... remember to press select once it knocks your telly into standby.
if you have not joy with this then you are going to have to get a newer sky remote. if you take the battery cover off the back of the remote you will see a sticker on there saying REV 4,6,8 the higher the number the newer the remote. then do the process again.
0056 is the manufacturers code for LG
Cheers
Little Dish Fitter
Mar 09, 2009 | LG 32LG30 32 in. LCD HDTV
Thomson DT!6300-16 has stopped working
Usually to fix most odd problems on the Thomson digi box you should do a hard disk format every couple of months, select menu, setup, help,
press green button on remote
this shows advanced menu, press blue button, warning should show,
press green button to proceed
takes about 2mins you lose all recorded programs
If the problem is the box stays at red, and won't switch on,
pull the mains plug wait a few secs then push and hold the the standby
button on the main box (not remote) then insert mains plug, as soon as the
red light flashes release the standby button and very quickly press
menu and OK in that order, don't hang about, it has to be done very quickly
I had to do it several times before I got it right, this loads a preloaded firmware
and the box will come alive again the box will upload new firmware in a couple of hours.
good luck from Ron.........
Dec 04, 2008 | DTK PRM-0031I Motherboard
Tv switches itself off to standby
Sounds like a fault in the remote receive circuit or power supply. ambient electrical noise is getting into the circuit somehere. As it is not a new TV, I would suspect power supply capacitors, as they dry out with heat and age. Probably best to take it to a repair shop that gives free estimates/quotes, as there may be more on its way out and this is the first symptom.
Nov 29, 2007 | Philips TV Tuner Video Capture PCI Card -...
LG 37LC7D 37 in. LCD HDTV Logo
41 people viewed this question
Computer Repairing
Computer Repairing
