Question about Canon CLC 1180 Copier
Canon 1180 error code E005 200 - Canon CLC 1180 Copier
    Top Expert:
  • Canon Master
  • 11,573 Answers
Posted on Aug 09, 2016
    Sergeant:
  • 236 Answers
Canon imageCLASS D1120 Basic Operation Manual: Error Codes (d1180/d1170/d1150) http://www.manualslib.com/manual/275603/Canon-Imageclass-D1120.html?page=261
Posted on May 06, 2015
  • 5 Answers
SOURCE: error code E00072-0202 on canon imageRunner clc1180
change the brush,cleaning
Posted on Dec 24, 2008
  • 168 Answers
SOURCE: canon clc 1180 error code 073-0003
this is an error for the transfer unit or its cleaning section not in proper place slide out the unit as far as it will go.. look inside to the lower left rear frame. there are 2 halfmoon gears sticking out reach in and turn both of those clockwise till they stop . slide unit back in close doors see if it resets good luck
Posted on Dec 29, 2008
  • 168 Answers
SOURCE: canon clc 1180 error code 071-0007
k you may have several problems you may take some canned air and blow out the connectors on the tx unit and the inside frame particularly the connectors on the lower right rear frame wall .. when you pull out the tx unit you may also want to turn the two cam gears on the lower left rear frame all the way clockwise then slide unit in
Posted on Jan 10, 2009
  • 170 Answers
SOURCE: my canon 1180 is E000 0105 error code. please help
that error is from fixing unit try to reset that error to reset that error press * 2&8 * then select copier then select function then press clear then select erro then press ok then turn off/on the power switch
Posted on Dec 11, 2010
  • 13 Answers
SOURCE: Canon 1180 erro e 061 Problem
You need to give subcode for E061
Posted on Oct 31, 2011
Service manual
Code error E 020, 0173
Jul 09, 2013 | Canon CLC 1180 Copier
Canon error jam
for this case you must call technician for chek it.
because the technician have to detail to chek it.
- position of paper.
- condition of paper.
Feb 27, 2013 | Canon CLC 1180 Copier
Error e020/04e0 for clc 1180
You need to Reset Code From Function_Clear_Err_OK. Check Dens_K in Display_Dens if it is to less i.e. bellow -2.5 Check Whether Black toner is present in hopper or replace Black developer
Oct 24, 2011 | Canon CLC 1180 Copier
Solution for canon 1180 clc error code E021 0401
Most Probably Your Black Color Developing asssembly is overloded with excess black toner and might not be rotating. Check it
Oct 15, 2011 | Canon CLC 1180 Copier
I have this error codecode e000 and 0105 under when i turn on my Canon CLC 1180. where was the fuser user in the CLC? How can i check it?
I think the 1180 is close to the 1120 copier I know. The error code is indicating an upper heater open circuit. The fuser is the very left item when the main drawer is pulled opened to remove a paper jam. There are two handle grips front and rear to remove the assembly. You have to check continuity of the heat lamp, fuses, etc.
Jun 13, 2011 | Canon CLC 1180 Copier
My canon 1180 is E000 0105 error code. please help me
Dec 09, 2010 | Canon CLC 1180 Copier
Problem for Canon CLC 1180 Copier E-804 0101
• The operation of a fan (indicated by detail code) is faulty. • The CPU PCB is faulty. • The DC driver PCB is faulty
0001 The electrical unit fan (FM8) has stopped to rotate in error check fans for dirt and it is ok
Aug 12, 2010 | Canon CLC 1180 Copier
What is error code C-1180?
What is the model? Bizhub 180???? with a C-1180 error code could not find that code in service manual, please check again
Jul 03, 2009 | Minolta Office Equipment & Supplies
Canon CLC 1180 Copier Logo
137 people viewed this question
old marine
old marine
