Connecting Panasonic SC-PT550 to TX-L42E5B
Have just bought Panasonic TX -L42E5B and want to connect it to my 5:1 panasonic SC-PT550 home cinema system when it arrives on Friday. My prevoius Panny tv (TX-32LXD70) had phono sound outputs and these together with an HDMI cable into tv ARC input worked well to the home cinema system. The new TV does not have phono outputs. Will the opto do the 5:1 job with the HDMI lead for the Viera link?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
I have a pansonic tv that i brougt last winter ,All you have to do to get audio from it is use a optical cable,
Posted on Nov 26, 2012
  • Alan Gilmour Nov 27, 2012
    Hi Greg, Thanks for the reply. Is the signal via optical 5:1 as my SC-PT550 manual seems to say that it is only stereo that is received thru the optical link. Regards, Alan
4 Suggested Answers
SOURCE: cant get my viera linked panasonic to play through surround sound
I had the same problem, so i contacted panasonic, I am including the email they sent me.
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Posted on Dec 17, 2008
  • 85 Answers
SOURCE: I have an LG TV
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Posted on Jan 07, 2011
  • 569 Answers
SOURCE: I have a Panasonic Model TC-p42X1 TV hooked up to
It's possible that you have the wrong type of HDMI cable. You need one that has Audio Return if you want to feed your Home Theater system with audio from the TV. There are several types of HDMI cable,some with audio return and some without. The two basic types (not including Ethernet) are described below - you need the High Speed version, which does have Audio Return.
hdmi-standard.jpgHDMI Standard This is the most basic HDMI standard which all cables have to meet. Cable should contain all the connections required for HD transmission, and have to deliver at least a resolution of 720p, (Video mode of 1280 x 720 meaning 720 Horizontal lines). These cables do not contain an Ethernet connection, or audio return.
hdmi-high-speed.jpgHDMI High Speed HDMI High Speed cables will support higher resolutions of 1080p. This means at least 1080 Horizontal lines, and cables rated at this specification may well support high resolutions of up to 4096 x 2160 (2160 Horizontal lines), check individual cables specifications for this data. Cables in this specification will also support a data transfer speed of 10.2Gbs (not to be confused with ethernet data speeds which are different), and a clock speed of 320Mhz. These cables do not contain an Ethernet connection, but do include an Audio Return Channel.
Posted on Feb 03, 2011
Panasonic TX-L42E5B tv sound working but screen is black
It can also be the YMain board or the back light inverter board or a capacitor or fuse has blown on the power supply board. Which you usually lose sound before you lose both sound and picture. Try to hard reset is for about 4-6 hours by completely unplugging it.
Mar 25, 2014 | Panasonic VIERA TX-L42E5B 42" LED TV...
Panasonic home cinema connection issues
What other audio/video outputs does the TV have? Does it have an HDMI port? If so, connect TV to your home theater using HDMI to HDMI.
Jun 07, 2013 | Panasonic SC-BTT490 5.1 3D Home Theater...
My Panasonic DVD Home Theater player will not
Check and correct the speaker cable connections.
Aug 20, 2009 | Televison & Video
Panasonic sc-pt460 home cinema system not getting
1 of your ics could be blown causing the amp shut down
Jul 15, 2009 | Audio Players & Recorders
No sound through the Panasonic cinema surround sound on TV
Had a similar problem mate. I solved it by connecting the tv to the PT460 system with a scart lead. You then have to have the AV channel selected on the PT460 system to listen to the tv. You will always have to have the AV channel on the PT460 selected to listen to any sound transmitted through the tv - be it playstation/xbox or any other device that you may connect in the future with HDMI leads or otherwise. Hope this helps
Jan 04, 2009 | Panasonic Home Theater System System
No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Dec 10, 2008 | Panasonic SC-HT75 System
Having just bought a Panasonic TX-37LZD80 television and a panasonic sc-pt460EB-K home cinema system, I connected the 2 together using a HDMI Cable and all works well except that I cannot get the sound...
When I purchased the television iI was told that I would only need a HDMI cable to connect the devices together, this is not true as the HDMI only provides 1 way transmission, to get the sound to go from the television back to the home cinema you need to use either a Phono Lead or Optical lead, plug them in and Hey Presto it works.
Jun 23, 2008 | Panasonic Televison & Video
Television and dvd home cinema surround
How are you connecting the DVD to the TV? What input are you using?
Dan
Mar 26, 2008 | Panasonic SC-HT70 System
Hook up
well u cannot hook almost any devices with the SC-HT500.
I have this homecinema system for 5 years now, and i had to buy another stand alone DivX player to hook it up, but can't get the sound in dolby from the standalone player since the panasonic SC-HT500 has only 2 analog stereo RCA ports (audio in) in the back and a scart (A/V out) and component video (Video out).
At that time it was a very good system, but since i have bought a Full HD LCD tv with 1080p capabilities, I realised that my home cinema system i.e the Panasonic SC-HT500 is kind of useless, in the sense that you cannot even change the player for another one since the whole spaker and power connections are made trhough a special cable from the subwoofer. :(
best solution is that put the system back in a corner and get a new system which is not an all-in-one system. Preferrable get home cinema systems that come with a receiver, separate dvd player and speakers and subwoofer hooked to the receiver.
you asked how to hook these devices to your tv,, well the panasonic dvd recorder is better if you connect it via HDMI cable if you can. In the other case, connecting them with a scart cable would be another solution.
Dec 02, 2007 | Panasonic SC-HT500 System
355 people viewed this question
 Grubhead
Grubhead
