Question about Ecoquest Breeze AT Living Air Purifier
Purifier doesn't go on and keeps blowing fuses when turned on
The plates have been cleaned and replaced.
The off and on switch has been tested and is charging.
The make we have is Breeze at by EcoQuest
serial # is 132409
  • 31 Answers
If the machine keeps blowing fuses there is a short in the electrical circuit and it needs to be looked at by a certified repair center.
Make sure the fuses you replace are the same as the original
100,110 volt models use the 1.0 amp slow blow fuse
220 volt models use the 0.5 amp slow blow fuse.
I hope this helps
Eric
Posted on Feb 02, 2009
Came home and unit was off and cannot turn back on. No response at all. Cleaned it and still nothing happens
Check to make sure the screen is pushed down in the back to activate the failsafe button. Sometimes the button can get finicky. Take off the screen and push it down with something. See if it does anything, if not, check the fuse and the plate, if it cracks, it's blow the fuse later.
Jun 08, 2011 | Ecoquest Breeze AT Living Air Purifier
Living Air XL (no smell)
TEST THE CONTINUITY OF THE BULB AND THE WIRING AND THE PARTS INSIDE.
DOES THE UNIT STILL WORKS NORMALLY ASIDE FROM THE BULB?
Sep 25, 2008 | Alpine Air XL-15 Air Purifier
Every time I clean the filter and the plate the ozone doesn't come on. I usually can fiddle with it and it will come on, but this time it didn't. What am I doing wrong and how can I fix it? this...
The plate is going bad. Sometimes it's just a bad part of the plate that has corrosion under it, try turning the plate and sliding in again. Sometimes that's all it needs. Sometimes it just needs to be brushed well, cleaned, and then blow-dried.
May 30, 2011 | Ecoquest Living Air Classic Air Purifier
When I turn on the unit it imeadiately blows the little fuse in it.
The problem can be one of several things. 1) Make sure the fuse is the EXACT size required. 2) Check the metal contact points (fingers) that press into the plate. If they aren't firmly in place, you may need to turn the white posts, or bend them slightly. 3) Make sure the plate is clean and not damaged in any way. If you see black marks, broken screen strands, loosened glue, discoloration, or cracked background at all, you need a new plate. Call the company (New name Vollara) 800-989-2299 to order new plates. Give 16618 as the dealer referral number. The company is no longer manufacturing or repairing the Breeze, but if none of the above suggestions work, you also can email us at fredandmb@frontier.com and we may be able to help you.
Feb 07, 2011 | Ecoquest Breeze AT Living Air Purifier
Will not turn on Have checked switch under filter Have checked continuity of the fuse plates are making contact Ecoquest Breeze AQ
Have you checked the fuse? It is located in back of the Breeze in the fuse holder next to where the plug connects to the purifier. It uses a 1.0 Amp slow blow for 110 volt models and 0.5 Amp slow blow for 220 volt models.
Oct 28, 2009 | Ecoquest Breeze AT Living Air Purifier
Every time I try to turn the purifier on it says install plate
The suplier switched to different electrical parts during the 3rd to 4th yr of Fresh Air manufacturing. The electrical connectors to the plate would rust and so would the screws! (Especially when you don't keep the lint screen clean! The oxidizers stay inside and try to oxidize the metal parts.) That makes for a bad connection and creates a "plate" readout. Suggest you clean the visible electrical connectors first to the plate assembly, all the way to the touching of the plate. They may just fall off. Been there! Easy to fix.
Sep 23, 2009 | Ecoquest Fresh Air Air Purifier
Install Plate Displayed
Call toll free 1-877-710-0057 and they will gladly help you.
Jun 03, 2009 | Ecoquest Fresh Air Air Purifier
Fresh air 2.0: Unit cycles on and off.
The problem is dust or moisture on one or more of the circuit boards, in the bottom of the unit. The problem is usually caused by resetting the cleaning reminder without actually cleaning the machine. ;-) It hasn't been difficult for me to solve so far. Remove the filter. Remove the two screws that hold on the plate where the rear switch is located. The wires are long enough that they don't need to be removed from the switch. Use a blow dryer or dry compressed air to blow off the circuit boards. ****Keep your face out of the way!!! Be sure not to get the blow dryer too close or too hot. If you have a Warm setting, use that. Good luck!
Sep 30, 2008 | Ecoquest Fresh Air Air Purifier
No smell
clean plates and blow out guts with compressed air. clean plates with mix of water and amonia!
Sep 28, 2008 | Ecoquest Flair Air Purifier
pull out the plates and clean contacts that touch plates with rubber eraser then put plates back in check switch on back of screen to make sure its making contact.
~~~creekkid~~~
Dec 19, 2007 | Alpine Air XL-15 Air Purifier
Ecoquest Breeze AT Living Air Purifier Logo
354 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
